Introduction: Home Made Usb From Stripboard
It is simple, cheap and a great way to spend your time.
Step 1: Materials and Tools
tools:
-saw
-soldering iron
materials:
-strip-board
-thick wire
-solder
Step 2: Step 1 First Kind
cut the board on the dimension of an father usb, check it (4holes)
cut the wire and insert it in which hole you want (I put it on the 4th)
Step 3: Step 2 First Kind
solder it at the ends
Step 4: Step1 Second Kind
I brought an chinese board and I had on it some cooper things and I used them to make an usb
I cut it at the right dimensions (3 things)and polished the middle thing because there are the data contacts on the mother plug
Step 5: Step 2 Second Kind
solder on the cooper part
Step 6: Result
2 kinds of usb
USB Contest
USB Contest
