HomeKit HomeBridge Siri Enabled Arduino ESP8266 NodeMCU Based PIR Motion Sensor for HomeKit Automation
21,787
182
26
Published
Introduction: HomeKit HomeBridge Siri Enabled Arduino ESP8266 NodeMCU Based PIR Motion Sensor for HomeKit Automation
About: I'm a lot of things. Galen Wollenberg https://hackaday.io/projects/hacker/246423 https://www.hackster.io/LagunaComputer
by Galen Wollenberg
Build custom Motion Sensors for home automation via Siri / HomeKit / HomeBridge using NodeMCU/ESP8266/arduino microcontroller, and a HC-SR501 PIR Motion Sensor.
I can put one of each of these in each room, and then use the iOs 'Eve' app to publish automatic HomeKit Automation rules and triggers. I.E.: "if is motion detected in the bedroom, automatically turn on the Bedroom lights".
This can be combined with my CurrentAmbientLighLevel plugin, and the DS18B20 or DHT11/DHT22 plugins (or HttpTemperatureHum plugin) to make a super room sensor for HomeKit / HomeBridge.
Step 1: ​Install HomeBridge for HomeKit on a Raspberry Pi
Test that HomeBridge and HomeKit is working on your iPhone.
See: https://github.com/nfarina/homebridge
https://github.com/nfarina/homebridge/wiki/Runnin...
Ensure these plugin are installed. It may be installed by default in the newer versions:
https://github.com/lucacri/homebridge-http-temper...
https://github.com/lagunacomputer/homebridge-Motio...
sudo npm install -g https://www.npmjs.com/package/homebridge-MotionSensor
Step 2: Parts Needed:
Parts Needed:
1x HomeBridge installed on a Raspberry Pi and working.
1x NodeMCU module
1x HC-SR501 PIR motion sensor
1x DHT11 or DHT22 temp/humidity sensor.
1x 10k ohm Photocell resistor
1x 4.7 k resistor (5k potentiometer used here to adjust light input sensitivity)
1x 2"x1.5" perf board
1x small piece of wire
1x 5v USB charger (i find the iPhone adapters to be the smallest and best)
1x usb cable end with exposed wires
Step 3: Build It
Build it
Pictured above is a sample connection of the motion sensor and a NodeMCU. We want to use a different pin than pictured above (or change the Arduino IDE code). see below.
Pictured above is a few sensors I have made with the addition of a photocell and potientiometer to adjust the light sensor sensitivity. Also pictured is an optional DS18B20 temperature sensor module. See my other Instructables if you are interested in adding the other sensors.
HC-SR501 data pin goes to NodeMCU D4 pin. check the sample Arduino code to make sure it matches the pin used in the code. For the older code, NodeMCU Digital Pin 1, set the Arduino Code to "int pirpin = 5" . This is because the NodeMCU pins map out to different GPIO#'s in reality. Google Images search "nodemcu pinout" to see a chart with the correct PIN to GPIO mappings.
USB cable +5 & HC-SR501 VCC goes to NodeMCU Vin pin
USB cable -GND & HC-SR501 GND goes to NodeMCU GND
Photocell to A0
Step 4: Edit the HomeBridge /var/homebridge/config.json File on the Raspberry Pi HomeBridge
Edit the HomeBridge /var/homebridge/config.json file on the Raspberry Pi HomeBridge
the file may alternatively be in /home/.homebridge or /root/home/./homebridge.
read the docs from the github link
Ensure this plugin is installed. It may be installed by default in the newer versions:
https://github.com/nfarina/homebridge https://github.com/lagunacomputer/homebridge-Curr...
Program the NodeMCU using the Arduino IDE.
Upon powering up (5V!) it should be seen on the network.
Try something like http://192.168.1.101/ .
You should get a webpage returned.
Assuming your NodeMCU pulls a DHCP ip of :192.168.1.101 (you should probably set a DHCP reservation on your router, for each ESP8266 you add) add this code to the config.json file.
( sudo nano /var/homebridge/config.json) etc:
"bridge": {
"name": "HomeBridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "",
"accessories": [
        "accessory": "Motion",
        "name": "Motion Sensor",
        "url": "http://192.168.1.101/?light",
        "sendimmediately": "",
        "http_method": "GET"
"platforms": []
mind the last comma, you may or may not need it if you have other accessories, or Homebridge is crashing on load.
Step 5: Program NodeMCU / ESP8266 / Arduino With Code
Program
*NEW IMPROVED CODE NodeMCU / ESP8266 / Arduino IDE ( faster, lighter, better, stronger):
Use digital Pin d4 for the motion sensor, D6 for DHT, and photocell=A0 with this code:
<p>#include <br>byte mac[] = { 0x5C, 0xCF, 0x7F, 0xC1, 0x1A, 0x33 };</p><p>int photocellPin = 0;     // the cell and 10K pulldown are connected to a0
int photocellReading;     // the analog reading from the analog resistor divider</p><p>#include
#define DHT11Pin D6</p><p>/////////////////////////////
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 30;        </p><p>//the time when the sensor outputs a low impulse
long unsigned int lowIn;         </p><p>//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;  </p><p>boolean lockLow = true;
boolean takeLowTime;  </p><p>int pirPin = 4;    //the digital pin connected to the PIR sensor's output
int ledPin = 13;</p><p>#include </p><p>IPAddress ip(192, 168, 1, 147);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);</p><p>const char* ssid = "IWILLSTEALYOURMONEY";
const char* password = "namnamnewnew";</p><p>// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);</p><p>DHT dht(DHT11Pin, DHT11);
unsigned long previousMillis = 0;        // will store last temp was read
const long interval = 2000;   </p><p>/////////////////////////////
//SETUP
void setup(){
  Serial.begin(9600);
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(pirPin, LOW);</p><p>WiFi.begin(ssid, password);
//WiFi.config(ip, gateway, subnet);
while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    //WiFi.begin(ssid, password);
    //Serial.print(".");
  //Serial.println("");
  //Serial.println("WiFi connected");
  // Start the server
  server.begin();
  //Serial.println("Server started");
Serial.println("");
  // Print the IP address
  Serial.println(WiFi.localIP());</p><p>  //give the sensor some time to calibrate
  Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++){
      Serial.print(".");
      delay(1000);
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    delay(50);</p><p>  }
 </p><p>  // get humidity
  float humidity = dht.readHumidity();
  // get temperature as C
  float celsius = dht.readTemperature();
  // get temperature as F
  float fahrenheit = dht.readTemperature(true);</p><p>// prepare a web page to be send to a client (web browser)
String prepareHtmlPage()
  //gettemperature();
  String htmlPage =
     String("HTTP/1.1 200 OK\r\n") +
            "Content-Type: application/json;charset=utf-8\r\n" +
            "Connection: close\r\n" +  // the connection will be closed after completion of the response
            "Refresh: 5\r\n" +  // refresh the page automatically every 5 sec
            "\r\n" +
            "{" + "\"lightval\":" + String(analogRead(A0)) + "," + "\"pirval\":" + String(digitalRead(D4)) + "," + "\"temperature\":" + float(dht.readTemperature()) + "," + "\"fahrenheit\":" + float(dht.readTemperature(true)) + "," + "\"humidity\":" + float(dht.readHumidity()) + "}" +
            //"</p><p>" +
            "\r\n";
  return htmlPage;
}</p><p>////////////////////////////
//LOOP
void loop(){</p><p>readPhotocell();</p><p>//delay(10000);
  // get humidity
  // print results
  Serial.print("Humidity: "); Serial.print(humidity);
  Serial.print(" Celsius: "); Serial.print(celsius);
  Serial.print(" Fahrenheit: "); Serial.println(fahrenheit);</p><p>     if(digitalRead(pirPin) == HIGH){
       digitalWrite(ledPin, HIGH);   //the led visualizes the sensors output pin state
       if(lockLow){
         //makes sure we wait for a transition to LOW before any further output is made:
         lockLow = false;
         Serial.println("---");
         Serial.print("motion detected at ");
         Serial.print(millis()/1000);
         Serial.println(" sec");
         delay(50);
         takeLowTime = true;
       } ////high</p><p>     if(digitalRead(pirPin) == LOW){
       digitalWrite(ledPin, LOW);  //the led visualizes the sensors output pin state</p><p>       if(takeLowTime){
        lowIn = millis();          //save the time of the transition from high to LOW
        takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       //if the sensor is low for more than the given pause,
       //we assume that no more motion is going to happen
       if(!lockLow && millis() - lowIn > pause){
           //makes sure this block of code is only executed again after
           //a new motion sequence has been detected
           lockLow = true;
           Serial.print("motion ended at ");      //output
           Serial.print((millis() - pause)/1000);
           delay(50);
       }    //low</p><p>  WiFiClient client = server.available();
  // wait for a client (web browser) to connect
  if (client)
    Serial.println("\n[Client connected]");
    while (client.connected())
      // read line by line what the client (web browser) is requesting
      if (client.available())
        String line = client.readStringUntil('\r');
        Serial.print(line);
        // wait for end of client's request, that is marked with an empty line
        if (line.length() == 1 && line[0] == '\n')
          client.println(prepareHtmlPage());
          break;
    delay(1); // give the web browser time to receive the data</p><p>    // close the connection:
    client.stop();
    Serial.println("[Client disonnected]");
  }</p><p>
  }   //loop</p><p>void readPhotocell(){</p><p>photocellReading = analogRead(photocellPin);
 Serial.print(WiFi.localIP());
  Serial.print(" Analog reading = ");
  Serial.print(photocellReading);     // the raw analog reading</p><p>  // We'll have a few threshholds, qualitatively determined
  if (photocellReading < 10) {
    Serial.println(" - Dark");
  } else if (photocellReading < 200) {
    Serial.println(" - Dim");
  } else if (photocellReading < 500) {
    Serial.println(" - Light");
  } else if (photocellReading < 800) {
    Serial.println(" - Bright");
  } else {
    Serial.println(" - Very bright");
}</p><p>/*
void gettemperature() {
  // Wait at least 2 seconds seconds between measurements.
  // if the difference between the current time and last time you read
  // the sensor is bigger than the interval you set, read the sensor
  // Works better than delay for things happening elsewhere also
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis >= interval) {
    // save the last time you read the sensor
    previousMillis = currentMillis;
    // Reading temperature for humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
    humidity = dht.readHumidity();          // Read humidity (percent)
    celsius = dht.readTemperature();     // Read temperature as Fahrenheit
    fahrenheit = dht.readTemperature(true);     // Read temperature as Fahrenheit
    // Check if any reads failed and exit early (to try again).
    if (isnan(humidity) || isnan(fahrenheit)) {
      Serial.println("Failed to read from DHT sensor!");
      return;
}</p><p>*/</p><br>
NodeMCU / ESP8266 / Arduino IDE Code version:
<p>#include <br>//#include </p><p>//byte mac[] = { 0x5C, 0xCF, 0x7F, 0x24, 0x84, 0x3D }; //physical mac address
byte mac[] = { 0x5C, 0xCF, 0x7F, 0x24, 0x66, 0x69 }; //physical mac address
//byte ip[] = { 192, 168, 1, 133 }; // ip in lan
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
//EthernetServer server(80); //server port</p><p>String readString; </p><p>#include
#include </p><p>/*-----( Declare Constants )-----*/
#define ONE_WIRE_BUS D4 /*-(Connect to Pin 2 )-*</p><p>*-----( Declare objects )-----*/
/* Set up a oneWire instance to communicate with any OneWire device*/
OneWire ourWire(ONE_WIRE_BUS);</p><p>/* Tell Dallas Temperature Library to use oneWire Library */
DallasTemperature sensors(&ourWire);</p><p>/*-----( Declare Variables )-----*</p><p>/////////////////////</p><p>int photocellPin = 0;     // the cell and 10K pulldown are connected to a0
int photocellReading;     // the analog reading from the analog resistor divider</p><p>boolean pirReading = false;
int calibrationTime = 30;</p><p>//the time when the sensor outputs a low impulse
long unsigned int lowIn;</p><p>//the amount of milliseconds the sensor has to be low
long unsigned int pause = 5000;</p><p>boolean lockLow = true;
int pirPin = 4;    //the digital pin connected to the PIR sensor's output</p><p>#include </p><p>IPAddress ip(192, 168, 1, 133);
WiFiServer server(80);</p><p>#include
dht DHT;
#define DHT11_PIN D6</p><p>void setup(){
Serial.begin(115200);
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  //Ethernet.begin(mac, ip, gateway, gateway, subnet);</p><p>WiFi.begin(ssid, password);
    delay(500);
  // Start the server
  server.begin();
  //Serial.println("Server started");</p><p>  // Print the IP address
  //server.begin();
  //enable serial data print
  //Serial.begin(9600); </p><p>sensors.begin();</p><p>  pinMode(pirPin, INPUT);  ///PIR
      Serial.print(".");
      delay(1000);
    delay(50);
}</p><p>void loop(){
readPIR();
readPhotocell();
//int chk = DHT.read11(DHT11_PIN);
//Serial.print(DHT.humidity);</p><p>float temperatureIndoor;
  float temperatureOutdoor;
  float humidity;
  sensors.requestTemperatures(); // Send the command to get temperatures
          temperatureIndoor = (sensors.getTempCByIndex(0));
  delay(100);
  // Create a client connection
  //EthernetClient client = server.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();</p><p>        //read char by char HTTP request
        if (readString.length() < 100) {</p><p>          //store characters to string
          readString += c;
          //Serial.print(c);
        } </p><p>        //if HTTP request has ended
        if (c == '\n') {</p><p>          ///////////////
        </p><p>   /////original code for dht
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: application/json;charset=utf-8");
          client.println("Server: Arduino");
          client.println("Connnection: close");
          client.println();
          //sensors.requestTemperatures(); // Send the command to get temperatures
          //temperatureIndoor = (sensors.getTempCByIndex(0));
          //temperatureOutdoor = (sensors.getTempFByIndex(0));
 //Serial.print(sensors.getTempCByIndex(0));</p><p> humidity = (DHT.humidity);
          client.print("{");
          client.print("\"temperature\":");
          client.print(temperatureIndoor);
          client.print(",");
          client.print("\"humidity\":");
          client.print(humidity);
          //client.print("}");
          //client.println();
         client.print(",");
          //client.print("{");
          client.print("\"lightval\":");
          client.print(photocellReading);
          client.print("}");
          client.println();
*/</p><p>          client.println("HTTP/1.1 200 OK");
          client.println();
          client.print("{");
          client.print(",");
          //client.print("\"humidity\":");
          //client.print(temperatureOutdoor);
          //client.println();
          //client.print(",");
          client.print(",");
client.print("\"pirval\":");
          client.print(pirReading);
//client.print("True");</p><p>
          client.print("}");
          client.println();</p><p>          //stopping client
          client.stop();</p><p>          ///////////////////// control arduino pin
          if(readString.indexOf("?on") >0)//checks for on
            Serial.println(readString.indexOf("on"));
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");</p><p>          }
          if(readString.indexOf("?off") >0)//checks for off
            Serial.println(readString.indexOf("off"));
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          if(readString.indexOf("?temp") >0)//checks for off
            Serial.println(readString.indexOf("temp"));</p><p>            temperatureIndoor = (sensors.getTempCByIndex(0));
            //digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("temp sent");
          if(readString.indexOf("?light") >0)//checks for off
            Serial.println(readString.indexOf("light"));</p><p>
            Serial.println("light sent");
          }</p><p>
          //clearing string for next read
          readString="";</p><p>//sensors.requestTemperatures(); // Send the command to get temperatures
//Serial.print("Device 1 (index 0) = ");
//Serial.print(sensors.getTempFByIndex(0));
//Serial.println(" Degrees F");</p><p>        }                     ///c=n
      }                //client available
    }             //client connected
  }         //if client
  } else {
}</p><p>void readPIR(){
  Serial.println(pirReading);     // the raw analog reading
 if (digitalRead(pirPin) == HIGH) {
    //digitalWrite(ledPin, HIGH);   //the led visualizes the sensors output pin state
    if (lockLow) {
      lockLow = false;
      Serial.print(millis() / 1000);
      delay(50);
    takeLowTime = true;
pirReading = true;
    //alarmTriggered();
  }</p><p>  if (digitalRead(pirPin) == LOW) {
    //digitalWrite(ledPin, LOW);  //the led visualizes the sensors output pin state
pirReading = false;
    if (takeLowTime) {
    if (!lockLow && millis() - lowIn > pause) {
      lockLow = true;
      Serial.print((millis() - pause) / 1000);
      delay(50);
  }</p><p>}</p>
<br>
Arduino Mega with Ethernet Shield Code version:
//byte ip[] = { 192, 168, 1, 101 }; // ip in lan
int photocellReading;     // the analog reading from the analog resistor divider</p><p>#include </p><p>IPAddress ip(192, 168, 1, 101);
dht DHT;
  //start Ethernet
    delay(500);
  // Start the server
  server.begin();
  //server.begin();
}</p><p>void loop(){</p><p>readPhotocell();
  float humidity;
  delay(100);
  if (client) {
          readString += c;
          //Serial.print(c);
          client.println();
          client.print("{");
          client.print(",");
          //client.println();
         client.print(",");
          client.print("}");
          }</p><p>
  }         //if client
  } else {
}</p><br>
ok
Step 6: Test the New Accessory in IOS HomeKit App
Test the new Accessory in iOS HomeKit App
Test the new Accessory in iOS HomeKit App and Siri
Check out my Light Sensor plugin for HomeBridge / HomeKit !
Step 7: Create HomeKit Automation Rules and Triggers Within the IOS 'Eve' App From the App Store.
Create HomeKit Automation Rules and Triggers within the iOS 'Eve' app from the App Store.
You could create a Scene that uses the Motion Detected Trigger to turn on the Living Room Lamp.
Using the Triggers feature in the Eve iOS App (i assume you can do the same with an Apple TV4)
Step 8: Optional - Basic 3D Printable Box
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    26 Comments
    Hello. That link for temperature sensor plugin is dead as well that one :
    https://github.com/lagunacomputer/homebridge-Curre...
    Please update - wanted to start project but don't know which one plugin is suitable for ur ESP code.
    Cheers. Nice project. Looking as well for code for CarbonOxide sensor - just for detecting signal on GPIO from sensor. And proper display in Homekit App.
    Sensors are working well when i connect. I use dht11 and for light sensor i used more accurate photodiode from sparkFun.
    https://www.sparkfun.com/products/8688
    working very good and i getting proper readings on com port log.
    when i connect DHT it working well ( before i connected but forgot about pullup resistor and had readings only 10-15 seconds but after put in pullup 4.7kohm
    everything working well) except motion. I getting motion detected and motion ended in com log but something is wrong in connection to homebridge.
    Ill connect everything tommorow and check it out again.
    Let u know the results.
    Thx for help :)
    Regards
    The HomeBridge install version has likely changed/updated by now, you may want to try an older version.
    Hello.
    I don't know why there is so big difference - when i compiled code with selected board Wemos D1 i had many errors as below and when selected generic 8266 i stil have errors but much less. But still can not compile.
    Arduino Log:
    WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
    Build options changed, rebuilding all
    MotionSensor:28: error: 'D4' was not declared in this scope
    #define ONE_WIRE_BUS D4 /*-(Connect to Pin 2 )-*/
    /Users/jerry/Documents/Arduino/MotionSensor/MotionSensor.ino:32:17: note: in expansion of macro 'ONE_WIRE_BUS'
    MotionSensor:19: error: 'D6' was not declared in this scope
    #define DHT11Pin D6
    /Users/jerry/Documents/Arduino/MotionSensor/MotionSensor.ino:85:9: note: in expansion of macro 'DHT11Pin'
    Multiple libraries were found for "OneWire.h"
    Used: /Users/jerry/Documents/Arduino/libraries/OneWire
    Not used: /Users/jerry/Documents/Arduino/libraries/DallasTemperature
    exit status 1
    try fixing this:
    Thanks for help.
    I succesfully solved problem with libraries which was differtent each other - i dont know why. With one of these i compiled succesfully.
    Now another problem:
    i ve put in my config these lines:
    the result in my homebridhe log:
    [Test Motion Sensor] Requesting motion on "http://192.168.0.30/?light", method GET, timeout 3000
    [2018-2-18 17:47:05] [Test Motion Sensor] HTTP successful response: {"lightval":8,"pirval":0,"temperature":nan,"fahrenheit":nan,"humidity":nan}
    [2018-2-18 17:47:05] [Test Motion Sensor] Received value is not valid. Returning "false"
    [2018-2-18 17:52:02] [Test Motion Sensor] Requesting motion on "http://192.168.0.30/?light", method GET, timeout 3000
    [2018-2-18 17:52:03] [Test Motion Sensor] HTTP successful response: {"lightval":14,"pirval":0,"temperature":nan,"fahrenheit":nan,"humidity":nan}
    [2018-2-18 17:52:03] [Test Motion Sensor] Received value is not valid. Returning "false
    I dont have currently connected any sensors ( i had for few minutes but it changed nothing ).
    I have only wire which i do short to vcc. It looks that it works good in hardwarte side. Led is responsing to sensor state and even in log the 'value "pirval" getting "0" when motion is detected and "1" when doesn't.
    On iphone see sensor icon but never was activated.
    I think over :
    "url": "http://192.168.0.30/?light"
    why "?light" - in similar plugin example is:
    "url": "http://192.168.1.220/motionEndpoint?json=true"
    or
    "url": "http://192.168.1.210/motionEndpoint",
    i know that its depend plugin requirement.
    Anyway homebridge for some reason doesn't see motion activity.
    Where is the problem???
    Regards! Good job anyway!
    Hello. Arduino compiler showing many errors during compilation so compilation is impossible .
    Maybe the reason for that is some new library versions. Anyway i cannot overcome that. All needed libraries installed. What library versions did u use for build that project?
    Log window look like:
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::depower()':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:163: multiple definition of `OneWire::reset()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:143: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::search(unsigned char*, bool)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:197: multiple definition of `OneWire::write_bit(unsigned char)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:177: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::read_bit()':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:225: multiple definition of `OneWire::read_bit()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:205: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::write(unsigned char, unsigned char)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:249: multiple definition of `OneWire::write(unsigned char, unsigned char)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:229: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::write_bytes(unsigned char const*, unsigned short, bool)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:263: multiple definition of `OneWire::write_bytes(unsigned char const*, unsigned short, bool)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:243: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::read()':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:277: multiple definition of `OneWire::read()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:257: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::read_bytes(unsigned char*, unsigned short)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:287: multiple definition of `OneWire::read_bytes(unsigned char*, unsigned short)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:267: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::select(unsigned char const*)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:296: multiple definition of `OneWire::select(unsigned char const*)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:276: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::skip()':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:308: multiple definition of `OneWire::skip()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:288: first defined here
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:314: multiple definition of `OneWire::depower()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:293: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::reset_search()':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:328: multiple definition of `OneWire::reset_search()'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:308: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::OneWire(unsigned char)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:145: multiple definition of `OneWire::OneWire(unsigned char)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:125: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::target_search(unsigned char)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:343: multiple definition of `OneWire::target_search(unsigned char)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:323: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::crc8(unsigned char const*, unsigned char)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:526: multiple definition of `OneWire::crc8(unsigned char const*, unsigned char)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:502: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::crc16(unsigned char const*, unsigned short, unsigned short)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:568: multiple definition of `OneWire::crc16(unsigned char const*, unsigned short, unsigned short)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:540: first defined here
    libraries/DallasTemperature/OneWire.cpp.o: In function `OneWire::check_crc16(unsigned char const*, unsigned short, unsigned char const*, unsigned short)':
    /Users/jerry/Documents/Arduino/libraries/DallasTemperature/OneWire.cpp:562: multiple definition of `OneWire::check_crc16(unsigned char const*, unsigned short, unsigned char const*, unsigned short)'
    libraries/OneWire/OneWire.cpp.o:/Users/jerry/Documents/Arduino/libraries/OneWire/OneWire.cpp:534: first defined here
    collect2: error: ld returned 1 exit status
    exit status 1
    Error compiling for board WeMos D1 R2 & mini.
    Hi there!
    Thanks for this nice instructable.
    I was looking for a solution to connect a WeMos D1 mini with a HC-SR501 PIR motion sensor to a Raspberry Pi 3 running Homebridge.
    So, actually pretty much what the title of this instructable says, but all the plugins and programs include temperature and light sensors related code. The required hardware also includes a temperature sensor and a photocell resistor. (confusing, as your previous instructable was about those sensors)
    I just need the motion sensor in Homebridge/Home-Kit and don't want to hook up additional sensors to the Arduino or install any unrelated plugins in Homebridge.
    How would the plugin, program and homebridge config look like just for a motion sensor setup?
    Could you please provide examples/sample code for the PIR motion sensor only?
    Thanks again,
    Dan
    Dan, I'm pretty sure you can just ignore the temp and light sensor parts, code and hardware. It will just return 0 for values for those. Then can have the Arduino/ESP8266 code just call out for shorter http get request, i.e. Just one ?motion= In the get request . I will check the code in a few hours and see if I can send you a stripped down version. So basically chop the Arduino code to only make one request, and forget about installing the other plugins.
    Thank you so much for the reply and the customized code!!!
    I actually ordered the WeMos D1 mini on purpose, because you used the the same board and sensor in your Fritzing Pinout-Scheme. :)
    The code looks nice and clean. I'm thrilled and can't wait to start this project the next weekend! – I'll keep you in the loop.
    Thanks again – I really appreciate your help!
    Cheers,
    Dan
    Hi Dan, try this, I basically commented out all the Light and Temp sensor stuff. Remember to edit your MAC and WIFISSID and WIFIPassword, and not sure about the WeMos stuff, might have to change pins for the motion sensor.
    Send me your email if you cannot get it to compile, it seemed to compile fine on my end. Good Luck.
    // HomeKit/Homebridge v3 NodeMCU/ESP8266 Code with HC-SR501 PIR
    // https://www.instructables.com/id/HomeKit-HomeBrid...
    // requires the homebridge-MotionSensor plugin by Galen Wollenberg https://github.com/lagunacomputer/homebridge-Moti...
    // Copyright 2017 Galen Wollenberg LagunaBeachComputer.com - ok to use for personal projects or testing only. No Commercial use.
    #include <SPI.h>
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
    //int photocellPin = 0; // the cell and 10K pulldown are connected to a0
    //int photocellReading; // the analog reading from the analog resistor divider
    //#include <DHT.h>
    //#define DHT11Pin D6
    //VARS
    int ledPin = 13;
    #include <ESP8266WiFi.h>
    const char* ssid = "yourwifissid";
    const char* password = "yourwifipassword";
    //DHT dht(DHT11Pin, DHT11);
    //SETUP
    void setup(){
    Serial.begin(9600);
    delay(500);
    // Start the server
    server.begin();
    Serial.println("");
    Serial.print(".");
    delay(1000);
    delay(50);
    // get humidity
    // float humidity = dht.readHumidity();
    //float celsius = dht.readTemperature();
    //float fahrenheit = dht.readTemperature(true);
    //gettemperature();
    String htmlPage =
    "Content-Type: text/html\r\n" +
    "\r\n" +
    "<!DOCTYPE HTML>" +
    "<html>" +
    "Analog input:" + String(analogRead(A0)) + " PIR input:" + String(digitalRead(D4)) +
    //+ " celsius:" + float(dht.readTemperature()) + " fahrenheit:" + float(dht.readTemperature(true)) + " humidity:" + float(dht.readHumidity()) +
    "</html>" +
    "\r\n";
    return htmlPage;
    //LOOP
    void loop(){
    //readPhotocell();
    //delay(10000);
    // get humidity
    //float humidity = dht.readHumidity();
    // print results
    //Serial.print("Humidity: "); Serial.print(humidity);
    //Serial.print(" Celsius: "); Serial.print(celsius);
    //Serial.print(" Fahrenheit: "); Serial.println(fahrenheit);
    if(lockLow){
    lockLow = false;
    delay(50);
    takeLowTime = true;
    } ////high
    if(takeLowTime){
    lockLow = true;
    delay(50);
    } //low
    if (client)
    Serial.print(line);
    break;
    client.stop();
    } //end of void loop
    //void readPhotocell(){
    //photocellReading = analogRead(photocellPin);
    //Serial.print(WiFi.localIP());
    //Serial.print(" Analog reading = ");
    //Serial.print(photocellReading); // the raw analog reading
    //if (photocellReading < 10) {
    //Serial.println(" - Dark");
    //} else if (photocellReading < 200) {
    // Serial.println(" - Dim");
    // } else if (photocellReading < 500) {
    // Serial.println(" - Light");
    //} else if (photocellReading < 800) {
    // Serial.println(" - Bright");
    //} else {
    // Serial.println(" - Very bright");
    //} //end of void readPhotocell
    return;
    Hello!
    It looks so good and looks works but the code for ESP send lot of error in the program Arduino when I want to upload.
    Could you upload the original code please. It would help a lot.
    Thank you in advance.
    just strip out the HTML tags and be sure to install libraries like DallasTemperature
    </p><p> change these to carriage returns or Enter key new line
    It doesn't work for me.
    Pls upload the ino files.
    Many thanks :)
    strip out the formatting the instructables website added to the code:
    </p><p>
    Can you please share the .INO files? The code is a mess the way you shared it. Can't get it to work.
    Thanks in advance!
    </p><p>
