HomeMade Modern DIY Bloktagons
38,875
943
11
Posted in WorkshopMolds-and-casting
Introduction: HomeMade Modern DIY Bloktagons
About: HomeMade Modern is an online design source that publishes easy-to-follow, DIY recipes for creating modern home furnishings. We provide creative ideas for making affordable alternatives to pricey designer ho...
Faceted geometric forms are trending nowadays. While the simple, colorful, paper shape DIYs that appear all over Pinterest are fun and easy to make, the results aren't lasting. We wanted to create a series of free, downloadable templates that could be used as forms and/or molds to make more sustainable objects. Download and print our Bloktagon series on cardstock paper to create forms for wax candles or concrete coat hooks and vases.
Step 1: Supplies + Tools
FREE Bloktagon Templates
Download at Homemade-Modern.com
Candle-Making Stuff: Paraffin Wax, Candle Wicks and Scented Oils
Purchase at Craft Stores or Online at Amazon.com
Quikrete 5000 Concrete Mix
Purchase at Home Depot
QUIKRETE® 5000 Concrete Mix is a commercial-grade blend of stone or gravel, sand and cement that's specially designed for strength. It is available at Home Depot and typically comes in 80lb. bags. The hardest part about working with it is moving the 80lb. bag. Mixing the small quantity needed for this project is easy – all you have to do is add water and stir thoroughly.
Cardstock or Glossy Photo Paper
Purchase In-Store or Online at Staples.com
We used 110lb. cardstock from Staples but glossy photo paper will give concrete projects a smoother finish. Both types of paper will work with standard inkjet printers.
High Gloss or Eggshell House Paint
Standard house paint helps seal the exterior of the paper molds.
Glue
Simple craft or white glue will work.
Scissors, box cutter or Exacto knife
To cut out the paper templates.
Inkjet printer
To print the 8.5" x 11" downloadable Bloktagon templates.
Metal ruler or tool with a sharp, straight edge
Useful for creating perfect, scored folds.
Step 2: Download and Print the Templates
Download and print the bloktagon templates on cardstock paper. Glossy photo paper can be used to create smoother molds for concrete projects.
Step 3: Cut Out the Templates
Use scissors or an Exacto knife to cut out the templates.
Step 4: Fold the Templates
Use a metal ruler to help make perfectly scored fold lines on the cut out templates.
Step 5: Glue the Template Tabs
Glue the template tabs to the corresponding facet of the Bloktagon. To make things easy, we numbered the tabs to the corresponding facet it should be glued to. A pencil or popsicle stick can be helpful for applying pressure to gluing a tab that's difficult to reach on both sides.
Step 6: Paint the Outside
Brush a coat of house paint on the exterior of the assembled Bloktagon to seal the mold.
Step 7: Fill the Molds
We experimented with paraffin wax and concrete fillings.
Blocktagon Candles
For Blocktagon candles, we melted leftover crayons into the paraffin wax to add color and put a few drops of scented oils for an added touch.
Blocktagon Vases
To make Bloktagon concrete vases, we used Quikrete 5000 but took out the large pieces of gravel. We placed pens and candles in the wet concrete to form the openings for the vases.
If you want to make a simple coat hook or knob, just place a large hex head screw into the wet concrete and allow it to cure together
Step 8: Finished!
Good luck making your own Bloktagon objects, and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more detailed instructions, dimensioned drawings and different variations of the project, check out our soon-to-be-released book.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    11 Comments
    I just can say a big WOW....! TNX 4 SHARING
    interesting idea, thanks!
    I'd've said the REAL most difficult part might be designing the Bloktagons in the first place... nicely done!
    A "bolt-through" version could also be made for, say, a closet-style accordion-door, by embedding tee-nuts on the ends of bolts sheathed with heat-shrink (or Vaseline?)... kind of a big, cement "acorn nut/knob" on each end of an appropriately-cut length of th'rod.
    Very neat indeed, but shouldn't you use gloves?
    wau....nice
    Its good to use antiperspirant spray (that one with the talk) inside the mold for easier removal of the paper ;)
