HomeMade Modern DIY Concrete Nesting Tables
26,465
415
12
Published
Introduction: HomeMade Modern DIY Concrete Nesting Tables
About: HomeMade Modern is an online design source that publishes easy-to-follow, DIY recipes for creating modern home furnishings. We provide creative ideas for making affordable alternatives to pricey designer ho...
I made these concrete nesting tables using nothing but Quikrete and LEGO bricks. I love how these concrete tables show the texture from the LEGO. I was skeptical about how well this idea would work, but everything went smoothly and Lego formed concrete is my new obsession.
Step 1: Supplies + Tools
LEGO Bricks
Available at Amazon
I used the classic LEGO bricks to make the mold. I raided my parent's attic to retrieve my childhood stash and purchased a few new sets. Purchasing all new bricks for this project might be a bit expensive, so I'm working on a post showing how the nightstand could be cast in sections to reduce the amount of LEGO needed.
3/4" Melamine Board
Available at the Home Depot
Melamine board is particle board with a smooth laminate surface. It's a great product for making a concrete form work. I bought a 4' by 4' sheet and had four 2 1/2" strips cut at Home Depot.
Quikrete Countertop Mix
I prefer the Commercial Grade Quikrete Countertop Mix for these type of projects but Quikrete 5000 will work just fine as well.
Hot Glue Gun
I used a hot glue gun to glue the LEGO bricks to the board. Don’t worry – the glue will peel off later.
Step 2: Layout the Mold
Build the mold up brick-by-brick. When you get to the top, place some support braces to keep the walls from bending out under the weight of the concrete. I used a single, large Lego baseplate, but this was a mistake. Use a bunch of smaller plates that will be easier to remove.
Step 3: Mix + Pour the Concrete
Mix the concrete and spoon it into the form. After you have put in about 3 inches of concrete, use a stick to push the concrete into the corners and vibrate the air bubbles out of the concrete. Repeat this process until the mold is full.
Step 4: Level + Smooth
Don’t worry about this too much because the bumpy Lego texture of the mold will be the front.
Step 5: Let the Concrete Cure
Let the concrete cure for at least 20 hours before removing the mold.
Step 6: Remove the Mold
Removing the LEGO bricks can be a bit time-consuming. Remove the a few of the upper layers and flip the block over to start removing the bottom bricks. It's easier to remove the bricks from the bottom. You can use long nose pliers to remove the bricks from the bottom, but be careful not to scratch or bend the plastic bricks.
Step 7: Clean the Legos
Most of the dried concrete flakes off the LEGO bricks. Some small pieces can be scraped or brushed off with a toothbrush. Only use cold water and mild, non-abrasive soaps to clean the bricks. If you have a mesh bag for laundering delicates, you can place the bricks in the bag and wash it in a washing machine with the water temperature set to cold. Do not use hot water or you will warp the bricks.
Step 8: Finished (+Bonus Project)!
Good luck making your own concrete nesting tables and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more DIY ideas and projects, visit us as HomeMade Modern.
BONUS PROJECT!
8-bit video games and LEGO remind me of my childhood. This mini project was an experiment in making molds for concrete inspired by 8-bit graphics.
Get Complete Visual Step-by-Step Instructions at Stellar.
Concrete & Casting Contest
First Prize in the
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    12 Comments
    Congratulations on being a finalist in the Concrete and
    casting contest! Best of luck to you!
    Not only is the project cool, but your video is really well done. You inspired me to have a go too.
    Making two tables in one go is very smart.
    You could use a lego/ wood hybrid. Seems like alot of work to only have a pattern on the one side. Almost all the pattern is from the grey piece on the bottom that connects all the legos. I do like the idea of an almost infinitely reusable concrete mold. I'm wondering if you could use the foam for the sides like you used in that one project with the big planter with the drain in it.
    NOBODY PANIC!
    he used the lego's again to make the nightstand..
    this looks really cool and I absolutely adore nesting tables.
    congratulations homemademodern on an awesome instructable.
    A V.E.R.Y. light dusting of the legos with a vegatable oil cooking spray and a wipe down with a paper towell will make them come free of the concrete instantly. It works on highway paving forms so it ought to on leggos
    For those in JCook20's camp...Sloshing the afore mentioned oiled leggos in a pan of water with dish detergent and rinsing them well will probably have the leggos much cleaner that they were in the toy box. One should also investigate the colors Sakcreet has available. Red, blue, yellow, brown, & black are a few that are available. Using the fiber mix cement will make a much stronger unit.--when cured use a torch to clean off the fuzzies
    How is this a waste of Lego? He clearly retained the bricks used and could use them again or simply play with them. The tables are also quite clever, so again, why the negativity? Pointless criticism is beneath you, or it should be.
    Can this be done with hypertufa?
    This is awesome! You should enter it in the concrete and casting contest that's going on right now! https://www.instructables.com/contest/concrete2014/
    Hahah cool how you did this with lego!!!
    That's a lot of hard work and the nesting tables turned out great!
