HomeMade Modern DIY Geometric Doghouse
Introduction: HomeMade Modern DIY Geometric Doghouse
Despite its faceted, angular appearance, this modern doghouse is quite easy to construct.
Step 1: Supplies + Tools
¼” Sanded Plywood
Purchase at Home Depot
I used a single 4’ by 8’ sheet of ¼” birch veneer plywood. I had the nice people at Home Depot cut two 14” wide strips for me.
I used 2x3s and 2x2s to make the angled support blocks.
RYOBI 18 Volt Cordless Drill
RYOBI Circular Saw
Step 2: Pick a Size
The triangles should be about the same height of your sitting dog. Fletcher is about 14” tall sitting so I had the nice people at Home Depot cut two 14” wide strips of plywood for me.
Step 3: Measure, Mark and Clamp the Two Boards Together
The doghouse is made from equilateral triangles. Measure off the triangles and then clamp the 2 boards together.
Step 4: Cut the Plywood
Once the triangles have been marked, use the laser guide on your RYOBI circular saw to follow the lines and cut the triangles.
Step 5: Measure and Cut the Angled Blocks
There are 2 ways to cut the angled support blocks. If you only have a 5-1/2” diameter circular saw, measure and mark the 2x3s as shown in the diagram.
If you have a 7-1/4” diameter or greater circular saw, set the blade to cut at a 42 degree angle and cut the blocks.
Step 6: Sand the Edges
Use 200 grit sandpaper to smooth down the edges.
Step 7: Assemble
Screw the angled blocks to the plywood triangles and screw the pieces together.
Step 8: Cut the Pieces for the Entry
I cut several of the plywood triangles in half to make a nice doorway for Fletcher.
Step 9: Add Supports
Add in additional wood blocks to strengthen the dog house.
Step 10: Done!
Good luck making your own geometric doghouse, and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more detailed instructions, dimensioned drawings and different variations of the project, check out our soon-to-be-released book.
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Sweet! Want to build a guest house like this. Lovely! Or maybe a ....... dog house :-)
    Seriously, the way in which you utilize simplicity makes me want to burn down, throw put, or otherwise destroy everything i have so that i can declutter my life and make simplicity as beautiful as you do!
    So...im off to the store....plywood to buy!...in inches
    Am I missing something? The geometry teacher in me says your dimensions are not right if these sides are equilateral triangles. If they are 14" tall, then all three sides should be about 19.8" long. And since you used angles for the angle blocks, might just as well use 60 deg angles to double check the triangles.
    As another pointed out, it will likely roll pretty easily.
    If using Pythagoras theorem you must sqrt( (8 1/4'')^2 + (1'2'')^2) is almost 1'4 1/4'' of the hyphotenuse, then check the other sides and must be equal, therefore angles are of 60°
    Is there any way I could build these in a larger scale? I got two labs and a staffie, so I sorta need them to be strong...
    Buckminster Fuller approved!
    Just remember that Martian Climate Orbiter which was lost in 1999, Lockheed Martin engineers used numbers as American units rather than Metric. Even NASA has been fully metric since t 1990. Conversion is not a good solution - just use an error-resistant system from the start.
    This site lacks a Like button. Thank you! I think the same thing.
    Since y'all appear to have a problem with somebody who was just trying to be helpful, I've removed my original comment - have a nice day, unless you can find a problem with that, too.
