loading
Our partner RYOBI asked us to do an Earth Day project that would demonstrate how eco-friendly tools like their 18 Volt ONE+ Cordless Chainsaw could be used to transform waste into usable home furnishings.
The log lounger is a great way to turn yard waste that would end up in landfills or a fireplace, into sturdy outdoor furniture.
We had a lot of fun trying out our new 18 Volt ONE+ Cordless Chainsaw and are proud to present an affordable, modern piece of furniture that was made sustainably with clean-running electric tools.
Step 1: Supplies + Tools
Logs 3" - 6" in diameter
Reclaimed landscaping waste
I got these birch logs from a landscaping company that had been hired to clear a piece of land. I recommend using logs between 3” and 6” in diameter. Larger diameter logs can be used but can be difficult to drill through and connect. They also can get pretty heavy.
Lag Screws 6” and 9”
Purchase at Home Depot
I used zinc-coated lag screws to connect the logs together. The lag screws are the most expensive part of this project. I used ¼” lag screws 6” long for most of the logs and a couple 9” long ones for the bigger logs. 3-4 screws per log will do the trick. If you are using smaller logs, you can get away with using cheaper deck screws.
Brackets and Deck Screws
The brackets are used to strengthen the floppy parts of the . Just screw them on the underside of the with deck screws.
RYOBI 18 Volt Chainsaw
The RYOBI 18 Volt Chainsaw is my new favorite tool! It's lightweight, easy to handle and runs on the same battery packs as my other RYOBI tools. More importantly, it doesn’t produce toxic emissions like gas-powered chainsaws and runs much quieter than traditional chainsaws, which is great for working on projects indoors.
RYOBI 18 Volt Cordless Drill
The drill is used to drill both the 1 ¼” counter sunk holes as well as the ¼” pilot holes for the lag screws. You can also use a hex attachment to drive the lag screws.
1 ¼” Drill Bit
Long lag screws are expensive and difficult to drive into the wood. Partially Drilling into the logs with a large drill bit allows you to use shorter lag screws.
Extra long ¼” Bit
I used an extra long bit to drill pilot holes through the logs I attached. This isn’t completely necessary but it makes driving the lag screws easier and reduces the likelihood of them breaking.
RYOBI 18 Volt Impact Driver(Optional)
In addition to a drill, an impact driver makes this project go a lot faster. You can drill the holes and drive the screws without switching bits.
Step 2: Cut logs
I cut the logs into 18” long segments. Feel free to cut longer segments if you have enough material to work with.
Step 3: Layout the design
I used blue painter's tape to mark an outline of the design on the floor. If you'd like a PDF of the template I used, feel free to email me. Do a test layout with your cut logs.
Step 4: Drill holes
Use the 1 ¼” bit to drill large holes about 1-2 inches into the log. These holes allow you to use shorter lag screws. You'll want the holes to be deep enough to allow the screws to go into the second log at least 2.5 inches. Use the long ¼” bit to drill pilot holes through the first log only.
Step 5: Screw the logs together
Use a socket wrench or an impact driver to drive the lag screws and connect the logs. Use 3-4 lag screws for each log.
Step 6: Flip it over and test
Flip the lounge upright and see where it wobbles. You can also do a little bit of shaping at this point.
Step 7: Brace it with brackets
Use steel brackets and deck screws on the back side of the lounge to strengthen and stiffen the weak and wobbly parts.
Step 8: Finished!
Happy Earth Day! Good luck making your own log lounger , and please email or tweet photos to @benuyeda or ben@homemade-modern.com. For more detailed instructions, dimensioned drawings and different variations of the project, check out our soon-to-be-released book.
<p>I wonder If I can make it from large diameter PVC pipes ?!!</p>
<p>Surely.</p>
<p>The only way that thing could be more uncomfortable looking is if you drove 8 inch nails at one inch intervals from underneath...more of a sculpture than a resting spot, methinks.</p>
<p>I loved it! That's exactly what I was looking for. Btw, you have a pretty smile. Keep smiling, please ;D</p>
Beautiful and (fairly) simple. Would look great in our backyard. I'm thinking too that lounger cushions would be needed if one were to actually sit on these - you'd need at least a pair!
Anyone worried about sap/bark/splinters can buy a chaise lounge cushion at any garden center. <br> <br>Nice Instructable. Good job explaining and illustrating. Thanks for sharing!
I think this qualifies more as a lawn sculpture rather than furniture. Can't imagine actually &quot;lounging&quot; on it, but it'd make a nifty rustic something-or-other.
Seems it would be really dirty and uncomfortable.
yeah maybe better for a porch or screened in area - half outside :)
or basically as a lawn chair....more practical
In most cases, but since it mostly depends on the bark of the wood that you use you might chose the proper kind or even go as far as to remove the bark.
It looks awesome - yet I am allergic to birch!! :)
hey, this is an awesome idea, but to some of us, a log is not waste... it is our only way to keep warm in the winter....
And what better way to store it indoors
What did you do to the logs to keep them clean? I cannot imagine sitting on this as I enjoy wearing my clothes sap-free...
Well he was using Birch which doesn't have any lingering sap after it has been seasoned. Using Pine in this way would be ill advised because of the sap.
Seeing how much it flexed, I would like to see it in use. <br>
Yop me 2
love itttttttt
OK, I can agree with chuckclackberry... <br> <br>&quot;What did you do to the logs to keep them clean? I cannot imagine sitting on this as I enjoy wearing my clothes sap-free...&quot; <br> <br>Solution: <br> <br>Rip the logs so the center is exposed, apply danish oil...and done <br> <br>what do you think? <br> <br> <br>
I'm thinking you could bend some rebar into the 2 curves you need and just drill holes in the wood. You might have to get creative on the end chunks of wood but would be less drilling.
totally amateur done
amateur is the point of it all...
Awesome job, you've got my vote! Good luck in the contest.
I need to get myself a log... Thanks for sharing!
Compost<br/>
Very nice, soon to sky-rocket in the views department
Wow! it looks so rustic and beautiful! such a cool ible :)
About This Instructable
90,277views
1,150favorites
License:
Bio: HomeMade Modern is an online design source that publishes easy-to-follow, DIY recipes for creating modern home furnishings. We provide creative ideas for making affordable alternatives ... More »
More by homemademodern:HomeMade Modern DIY Outdoor Sofa HomeMade Modern DIY Conference Table HomeMade Modern DIY Copper Tiki Torches
Add instructable to:
