Remove these ads by
Signing UpStep 1Find your items from old computers/electronics
To ON/OFF Buttons (I used a flip button and a push button)
Wire
Small Computer Connector (will explain more in next step)
Some kind of housing or enclosure (i used clear, flexible pvc hose - but you could use a film canister or pill bottle)
Needed Tools:
Soldering Iron
Solder
Sander (or sandpaper)
Exacto Knife
Wire Cutters
Wire Strippers
I would give it a shot but having no electrical background I would be afraid of killing the camera somehow. I'm looking for a way to use my netbook to allow timed photos and using what you have coupled with one of these would be a way to get around not having that ability built into the A200.
I like your design
I changed up your idea a bit, but honestly if anyone is afraid to do this DONT BE, i own a Sony alpha A-350 and i even got it to work without auto focus by changing the wiring a bit (which is good considering the fact that most of the photos i would take at night wouldnt be able to be focused on anyway)
my mods are simple, i used a toggle switch off a fog light kit that never got installed, wired it to a cd out cable after doing the quick and dirty cutting of the connecter down to the three pins. once i wired it and tested it i was at a loss for a container, so i used a coca cola can, yeah i know, lol. I stuffed a sock inside for padding and ran the wire out the bottomm i also used a standard gauge telephone (4 coppers) outside wiring and made an extension elado n it. the whole thing is a coke can with about 4 feet of wire, then the lead allows me to hook another 200 feet to it (if i ever need to go longer that is) with a quick plug in sitatuation. ITs nothing special but when my shutter worked along with the manual focus ring i was THRILLED and i owed you a thank you!
I hope everyone on GOOGLE, YAHOO< MSN, and all the other engines picks this up BEFORE thy waste the 100 bucks on expensive cables, this is so much more fun
I am going to test it now and will provide a link to a photo taken with it soon!
FYI if you really want to see the device you can always click here!
thanks again
www.realityoneradio.com//ztek/stuff/wtf_lol.jpg
First off, do you know if the a200 will take the same remote as the a100, I think it should.
I also used a "double pushbutton" setup(one over the other to simulate the original remote)
I used a 4 pin cd-in plug(not every cable have 4 pins),cut the left pin and the plastic on the top(not on the bottom,it fit perfectly as anti inversion pin).
I gluead also 2 buttons one in front of the other to obtain a "dual state" button.
IT WORKS PERFECTLY,like the original(don't have the on/off state only because i didn't want it)
i have a sony a200,a LOT of pc components,want a remote for my camera but don't want to spend money on it!
There is a really brief description under the "F Cable Switch for PZ, ZX, SF & 645AF" heading at http://www.photosig.com/articles/1088/article
