3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Wired SONY ALPHA DSLR Remote (by Brad Justinen)
I created this simple but powerful shutter release remote for my Sony DSLR. With some random junk (or trip to goodwill) you can create one too.
Step 1Find your items from old computers/electronics
Needed Materials.
To ON/OFF Buttons (I used a flip button and a push button)
Wire
Small Computer Connector (will explain more in next step)
Some kind of housing or enclosure (i used clear, flexible pvc hose - but you could use a film canister or pill bottle)
Needed Tools:
Soldering Iron
Solder
Sander (or sandpaper)
Exacto Knife
Wire Cutters
Wire Strippers
18 comments
Jan 23, 2010. 6:21 AMPGunn says:
Nice article have you tried adding one of these or something similar? http://www.sparkfun.com/commerce/product_info.php?products_id=666
I would give it a shot but having no electrical background I would be afraid of killing the camera somehow. I'm looking for a way to use my netbook to allow timed photos and using what you have coupled with one of these would be a way to get around not having that ability built into the A200.
Jun 8, 2011. 5:31 PManonymouse197 says:
Hmm... I lie apparently! I didn't think of using a simple Relay with the Arduino - making operating a switch like this very easy. A relay detects a voltage, and closes a physical switch using electromagnets, so the Arduino code could be written to close two separate relays; one controlling the auto focus, and one firing the shutter. I will play around with this for a little longer, until I have something more specific to bring to the table. I will be making an instructable on this if you don't mind me doing so, and I would love to collaborate if you are still interested in a year old topic!
Jun 8, 2011. 5:16 PManonymouse197 says:
I would also be very interested to see how something like this might work. I have played a little with the Arduino Duemilanove but so far I cannot think of a way to do this using software. As far as I am aware it is very easy to send a voltage through an Arduino pin, but it is seemingly impossible to connect two pins. The only way that I could think of doing this would be by having a servo controlled by the Arduino swing across a metal paperclip and bridge two contacts or something of these sorts, but this would be a very ineffective way of doing it. The timing function would be very simple coding when the rest is complete, the only tricky part is connecting the wires. I will keep looking into ways of doing this, and I will notify you of any breakthroughs that I find. Fingers crossed, and thanks for the fantastic instructable - you have saved me a good £30!
Mar 24, 2011. 7:28 PMMinion71 says:
i made mine from epoxy and made a mold and the metal pin for contact at least it work hehe
I like your design
May 2, 2010. 3:57 PMClambo says:
Hi, this stuff is really great, I'm glad i found this site. My question is, I have a Sony cyber shot 8.1 mega pixel. Could I make this remote shutter for this camera. Thanks Clambo
Dec 5, 2009. 8:32 PMi_DI_Myself says:
I cant say enough about this, i had wondered as a pro photog if there was another way then buying sonys expensive foreign junk, and then i found some canon and nikon sites, then they led me here.
I changed up your idea a bit, but honestly if anyone is afraid to do this DONT BE, i own a Sony alpha A-350 and i even got it to work without auto focus by changing the wiring a bit (which is good considering the fact that most of the photos i would take at night wouldnt be able to be focused on anyway)
my mods are simple, i used a toggle switch off a fog light kit that never got installed, wired it to a cd out cable after doing the quick and dirty cutting of the connecter down to the three pins. once i wired it and tested it i was at a loss for a container, so i used a coca cola can, yeah i know, lol. I stuffed a sock inside for padding and ran the wire out the bottomm i also used a standard gauge telephone (4 coppers) outside wiring and made an extension elado n it. the whole thing is a coke can with about 4 feet of wire, then the lead allows me to hook another 200 feet to it (if i ever need to go longer that is) with a quick plug in sitatuation. ITs nothing special but when my shutter worked along with the manual focus ring i was THRILLED and i owed you a thank you!
I hope everyone on GOOGLE, YAHOO< MSN, and all the other engines picks this up BEFORE thy waste the 100 bucks on expensive cables, this is so much more fun
I am going to test it now and will provide a link to a photo taken with it soon!
FYI if you really want to see the device you can always click here!
thanks again
www.realityoneradio.com//ztek/stuff/wtf_lol.jpg
Nov 19, 2009. 7:40 PMsafebat says:
Just wondering why you even put the switch in for the autofocus as it must be on for the push-on shutter release to work???   Are you using it as an overall off switch or is there a problem with just making a direct connect of these first two pins and leaving them always on???  I'd like to build one for my alpha 100 and was thinking of looking at modding the Phone mic switch from the other Instructable.  Any thoughts on that?  direct to me is safebat @hotmail.com.....Thanks.
Nov 4, 2009. 3:29 PMplokko says:
I have a problem: i have modified the connector and now it fit perfectly in the a200 but the camera don't respond to the buttons,does i have to set something in the camera menu?i can't findi it in the manual!
Nov 5, 2009. 12:25 AMplokko says:
it's a connection problem,floppy connector sux,i tryed also fan or cd-in connectors but i can't find one working.
I also used a "double pushbutton" setup(one over the other to simulate the original remote)
Nov 11, 2009. 12:24 PMplokko says:
I DID IT,it fit perfectly on the socket and have also the anti inversion pin!!!
I used a 4 pin cd-in plug(not every cable have 4 pins),cut the left pin and the plastic on the top(not on the bottom,it fit perfectly as anti inversion pin).
I gluead also 2 buttons one in front of the other to obtain a "dual state" button.
IT WORKS PERFECTLY,like the original(don't have the on/off state only because i didn't want it)
Nov 4, 2009. 2:59 PMplokko says:
I LUV YOU!!!
i have a sony a200,a LOT of pc components,want a remote for my camera but don't want to spend money on it!
Jul 10, 2009. 3:26 AMgonhop says:
Make sure you don't take this thing on a bus or plane and pull it out. You'll get some baaaaaad results.
Jun 23, 2009. 10:51 PMScromple says:
It's pretty funny seeing this... It's the same type of plug as my 15 year old Pentax film camera. Just finished making a cable release for that.
There is a really brief description under the "F Cable Switch for PZ, ZX, SF & 645AF" heading at http://www.photosig.com/articles/1088/article
Jun 23, 2009. 10:52 PMScromple says:
Oh yeah... That is not my web site. Just where I had bumped into the info about the particular plug on my camera.
Dec 12, 2008. 10:50 AMfkuk says:
same thing for4 somy alpha 300 but remote plug is in different posistion same conections though
Oct 22, 2008. 4:19 AMhedgiehog says:
would this work with most slr's assuming that the connection pin thing is similar
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:sensoryhouse(Brad Justinen)
http://vimeo.com/justinen http://www.flickr.com/photos/bradjustinen/
