3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Wired SONY ALPHA DSLR Remote (by Brad Justinen)
Step 4Plug it into your camera and start shooting burr-free photos, etc.
Sorry i don't have more photos if you get stuck you can contact me and i will help you out.
Enjoy!!!!
6 comments
Jan 23, 2010. 6:21 AMPGunn says:
Nice article have you tried adding one of these or something similar? http://www.sparkfun.com/commerce/product_info.php?products_id=666
I would give it a shot but having no electrical background I would be afraid of killing the camera somehow. I'm looking for a way to use my netbook to allow timed photos and using what you have coupled with one of these would be a way to get around not having that ability built into the A200.
Jun 8, 2011. 5:31 PManonymouse197 says:
Hmm... I lie apparently! I didn't think of using a simple Relay with the Arduino - making operating a switch like this very easy. A relay detects a voltage, and closes a physical switch using electromagnets, so the Arduino code could be written to close two separate relays; one controlling the auto focus, and one firing the shutter. I will play around with this for a little longer, until I have something more specific to bring to the table. I will be making an instructable on this if you don't mind me doing so, and I would love to collaborate if you are still interested in a year old topic!
Jun 8, 2011. 5:16 PManonymouse197 says:
I would also be very interested to see how something like this might work. I have played a little with the Arduino Duemilanove but so far I cannot think of a way to do this using software. As far as I am aware it is very easy to send a voltage through an Arduino pin, but it is seemingly impossible to connect two pins. The only way that I could think of doing this would be by having a servo controlled by the Arduino swing across a metal paperclip and bridge two contacts or something of these sorts, but this would be a very ineffective way of doing it. The timing function would be very simple coding when the rest is complete, the only tricky part is connecting the wires. I will keep looking into ways of doing this, and I will notify you of any breakthroughs that I find. Fingers crossed, and thanks for the fantastic instructable - you have saved me a good £30!
Nov 4, 2009. 3:29 PMplokko says:
I have a problem: i have modified the connector and now it fit perfectly in the a200 but the camera don't respond to the buttons,does i have to set something in the camera menu?i can't findi it in the manual!
Nov 5, 2009. 12:25 AMplokko says:
it's a connection problem,floppy connector sux,i tryed also fan or cd-in connectors but i can't find one working.
I also used a "double pushbutton" setup(one over the other to simulate the original remote)
Nov 11, 2009. 12:24 PMplokko says:
I DID IT,it fit perfectly on the socket and have also the anti inversion pin!!!
I used a 4 pin cd-in plug(not every cable have 4 pins),cut the left pin and the plastic on the top(not on the bottom,it fit perfectly as anti inversion pin).
I gluead also 2 buttons one in front of the other to obtain a "dual state" button.
IT WORKS PERFECTLY,like the original(don't have the on/off state only because i didn't want it)
Nov 4, 2009. 2:59 PMplokko says:
I LUV YOU!!!
i have a sony a200,a LOT of pc components,want a remote for my camera but don't want to spend money on it!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:sensoryhouse(Brad Justinen)
http://vimeo.com/justinen http://www.flickr.com/photos/bradjustinen/
