Homebrew PCB Etch Tank
5,974
18
Posted
Introduction: Homebrew PCB Etch Tank
For a while now I have been wanting to build my own PCB etch tank because I was a tad fed up messing on with a tray of etchant.  Somehow I always seemed to get it everywhere and stain everything in sight.  This is my first instructable, so please forgive the inevitable sucky-ness.  Apologies for my pictures appearing mid-way through the build.  I forgot to start snapping photos from the beginning.  I shall also include a link to the videos on my youtube channel.
For this build, I used the following items/materials:
>  1x silly named plastic food storage jar from Ikea (pack of 3 for £5-ish)
>  1x unbranded aquarium air pump, including 3m silicone airline, non-return valve and diffuser stone (ebay at £5 inc postage).
>  1x 6mm airline diffuser kit (£2.99 from local pet shop)
>  2x Flow control valves (£0.80 each from local pet shop)
>  Sugru - my most favourite thing in the world!
>  Green food colouring (to add to water during first pump test run)
Tools involved in build:
>  Bench drill w/4mm HSS drill bit
>  Elbow grease
>  Time
Step 1: Time to Drill!
To start, I marked on the bottom of the jar where I would like my inlet and outlet valves to go.  To ensure the hole is going to be the correct size, I measured the outer diameter of the valve port with a set of digital callipers.
For these parts, I needed a 4mm drill bit.  So, once I marked the jar with my trusty sharpie I began to drill.  (apologies again for lack of photos, I really should have started snapping sooner).  I drilled slowly and carefully to ensure that I did not slip or mank up the plastic, as I hate faffing around trying to clean up plastic once it has been messed up.
Step 2: Stuff the Valves in and Apply Copious Amounts of Sugru.
Ok, I keed I keed! I carefully inserted the valves and applied an appropriate amount of Sugru - which was allowed to cure for 24 hours before testing.  I love Sugru... so much nicer than using the original silicone sealant yucky stuff that I had originally planned to use.
As you can probably see by the pictures, I attached the inner pipe, non-return valve and inner diffuser tube prior to applying the Sugru. This was just to make things a tad easier in the long run.
Step 3: Adjust and Fix Diffuser Tube Position
At this point I now started to try and figure out the best position to place the suction cups that came with the diffuser tubing.  Although it may look a bit messy in the picture, this configuration worked better than when I placed the tube neater.  Once the tubing position has been set.... time for the first test to make sure everything is working....
Step 4: Test Run!
So... the time to perform a test with liquid has arrived.  Instead of jumping straight to the chemicals, I decided to test with water and a few drops of green food colouring to make it easier to see in the pipes and tank.
Fingers crossed.... *power on*
http://www.youtube.com/watch?v=-4PhwMVDDg8&hd=1
As you may have seen, it seemed to perform quite adequately for the purpose it was intended for.  The only slight problem (not caught on camera) was that there was a tiiiiiny leak coming from the outlet valve.  This was not a major problem to fix, I just removed the sugru and re-applied some more.  I should have taken a bit more care at first when inserting the valves - I did not ensure that it was stuck down as well as it needed to be.  I have since tested it again with the newly sealed valve and it functions fantastically.
Step 5: To Be Continued...
That's all for now - once I get a chance to do some actual etching I'll add a new video and some pics no doubt.  Bring on the real chemicals!
Any feedback at all is welcomed - either regarding the build, or this instructables post as this is my first time.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    "to be continued"
    where?
