Homebrew WISP ( Wireless ISP)
Introduction: Homebrew WISP ( Wireless ISP)
I have always been amazed with wireless technology even before. I remember during our high school days. My friends and I were DREAMING on how to propagate data packets using the VHF radio (145.00 Mhz) and a Commodore 64 computer. It did not materialize though, we haven't had the chance to test it because of money considerations, back then a Commodore 64 PC cost thousands of Dollars. Cassette tapes were still used for file back-ups, no Hard Drives and Floppies yet. Well ..... so much with History.
This project is to make a homebrew wireless ISP in your neighborhood, this is to share your internet connection using wireless technology. Although we have questions about security issues but I won't be touching that topic, my reason for this blog is just to show how powerful this technology is and how it can help bring internet connection to rural areas. I will be using cheap materials you can find anywhere.
Step 1: Materials and Fitting
Materials Needed:
Plastic Transhcan - used as enclosure
Access Point
Homebrew POE Injector and Antenna
Power Supply Regulator
a. Fitting the Access Point and Supply Regulator
Using a plywood, cut the desired size so that it will fit inside the trashcan. The wood will be used as the base for your AP and the Power Supply Regulator. I will be using the regulator I made in my previous blog.(https://www.instructables.com/ex/i/BD1BA19AFB3510289811001143E7E506/)
Look at picture #2 and #3,It would look like this after putting the AP and the Regulator. Take note that there's a bolt near the regulator, this will be used to attach the wood to the plastic trashcan afterwards. The RJ-45 modular box is part of the POE I made. You can make your own POE using this link (http://www.nycwireless.net/poe/) as reference, this is a cheap alternative that works well.
Step 2: Putting It All in the Trashcan
I am only using a rectangular plastic trashcan. I live in a tropical country, the only problem is to secure the AP from getting wet. No SNOW or DUST STORM to worry about here... Now,make all the needed holes to bolt the plywood and the trashcan together.
I designed a metal holder for the trashcan with U-bolts for the mast installation (picture #2). Using it to hold the plywood and the plastic together.
As you can see in the third picture,the bolt is holding the plywood, to the plastic and the metal holder... all three of them.
Step 3: Installing the Antenna and Finalizing the Rig
I made a Bi-Quad antenna using Trevor Marshall's (http://www.trevormarshall.com/biquad.htm) design but tweaked it a little bit to make use of my available materials. I will be posting a separate blog for this.
The second picture is a peek of my Bi-Quad inside the plastic enclosure. You can see the Copper Cladded Board or PCB used as the reflector and copper wire for the main element.
I am using an RG-58 (50 ohms)cable from the Linksys AP to the external antenna, compatible connector for this particular Linksys is RP-TNC.
After putting everything inside the Trashcan, I made a plastic cover to keep the Birds from nesting inside. This will also protect the AP and the Regulator from mist during heavy rains.
Step 4: Putting All in the Mast
Using the Metal Bracket that I made, the "loaded" Trashcan can be securely fastened to the mast,installed also the antenna.In the third picture you can see the Trashcan and Antenna in all its Glory. Sweet huh?
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    Love it ! You did excelent using all that you could find and build, and then applying your skills. I have developed hundreds of WISP's and love the idea, and yes folks this will work.
    that would be ok for a point to point application
    If you want to be an access point though you would need to us an omni directional antenna or construct sector antennas
    I have sucessfully established a 40 mile point to point link using 2 parabolic reflectors and 500mw
    Something else that helps is using 802.11b
    It will easily outdistance 802.11g and 802.11n
    hey i have some question id would like to talk you email me justintrags@gmail.com
    Dear Sir/
    I am Internet Cable Service Provider, I cover 2 Kilometer area. I have almost 500 Internet Cable coustumers. I want to convert my whole Cable Network into Wireless Network. I would be very thankful to you if you can help me out from this problem and tell me also about your products which will help me to do convertation.
    - Mohib
    hey drop me a line i would like to talk justintrags@gmail.com
    I really hate to ask this... but is this a method of actually being able to provide access to the internet to others and yiurself... with out having to get it first from at&t or comcast or some other provider?
    It seems like a stupid question but i am trying to wrap my brain around this and an idea i have but there are basics of this i need to understand first.
    Hats off to you for writing
    such an informative piece of work. I must say that I have never seen such a
    fine work. Keep it up.
    I do not see this antenna booster working to well. WiFi uses Microwave frequencies.. RG-58 cable and Pl259 connectors are not designed for those ranges.
    LM400 cabling and sma connections should had been used for max effectiveness
    For the low power outputs here and short cable runs I wouldn't be too worried. More power might damage the equipment or longer runs would cause more signal loss. I'd keep the cable as short as possible.
    Why would you put the access point in the trash can on the pole? could you just have the linksys in the house and run the signal cable up the pole to the antenna instead? Just courious why you did it they way you did..
