Homebrew WISP ( Wireless ISP)
Step 1Materials and Fitting
Materials Needed:
Plastic Transhcan - used as enclosure
Access Point
Homebrew POE Injector and Antenna
Power Supply Regulator
a. Fitting the Access Point and Supply Regulator
Using a plywood, cut the desired size so that it will fit inside the trashcan. The wood will be used as the base for your AP and the Power Supply Regulator. I will be using the regulator I made in my previous blog.(http://www.instructables.com/ex/i/BD1BA19AFB3510289811001143E7E506/)
Look at picture #2 and #3,It would look like this after putting the AP and the Regulator. Take note that there's a bolt near the regulator, this will be used to attach the wood to the plastic trashcan afterwards. The RJ-45 modular box is part of the POE I made. You can make your own POE using this link (http://www.nycwireless.net/poe/) as reference, this is a cheap alternative that works well.
3 comments
Aug 13, 2008. 12:24 PMNozeDive says:
I was thinking of doing something similar, but on a smaller scale. I have a wired Linksys router, as I originally had no need for WIFI . Now I would like to give some of my WIFI enabled devices access to the internet, but not all of them have an RJ-45 jack to plug into my router.
I also have a WIFI-G USB adapter that I can use to connect a PC to a WIFI network. Is there a way I can use my PC as a bridge? I mean, since my PC is wired to my router, can I use the USB WIFI adapter to let other devices and computers connect to my wired router through the WIFI USB adapter?
Mar 19, 2009. 11:36 AMBlackHatCracker says:
Nope. Not unless you have a WiFi G router connected to a computer.
Aug 19, 2008. 9:33 PMDillon02003 says:
That is EXACTLY what I have been searching and searching this site for and not finding anything. Someone please answer our question!!
Aug 25, 2008. 5:19 AMDerin says:
It is possible...i will try to search windows help for how to set it up
Aug 25, 2008. 5:24 AMDerin says:
WINDOWS HELP ABOUT MAKING BRIDGE: To bridge connections You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure. Open Network Connections. Under LAN or High-Speed Internet, hold down the CTRL key and select each of the private network connections that you want to be part of the bridge. Right-click one of the highlighted private network connections, and then click Bridge Connections.
Aug 28, 2008. 12:14 AMDillon02003 says:
Thanks for trying, but I don't believe that answers the problem, Thanks anyways.
Apr 8, 2007. 6:36 PMGigglesworth says:
If you don't feel comfortable building your own POE (Power over Ethernet) adapter, Linksys, Netgear & other vendors sell 12-V POE adapters for around $30-40. I like the idea of using a Linksys adapter to subvert my DD-WRT firmware-based Linksys router ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Talking Electronics
Do-It-Yourself electronic projects I've made. Read it, Learn it, Use it....spread the word! About the Author: This is the Geeky side of my personality.I graduated Electronics and Communications En...
more »
