What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
Using the Metal Bracket that I made, the "loaded" Trashcan can be securely fastened to the mast,installed also the antenna.In the third picture you can see the Trashcan and Antenna in all its Glory. Sweet huh?
I do not see this antenna booster working to well. WiFi uses Microwave frequencies.. RG-58 cable and Pl259 connectors are not designed for those ranges.
LM400 cabling and sma connections should had been used for max effectiveness
ok, good one, but.. this is not a wisp project, this is more or less access on the net. you need a lot more to make wisp.being N.A.S the first. (not storage but the Network Access Server) to justM: I have build a phased quad antenna reflected by a 90cm parabola & established connection (with the same gear at the other end) in 7Km range and 100mw lasted 3 yrs then i took it down. but still works,
I'm newbie in this kind of Tech , a 'll be gracefuller if you give us a simple tutorial to built a phased quad antenna reflected by a 90cm parabola. thanks at all
