Wort (pronounced Wert) is the hot malt liquor that beer is made from, before the yeast can be pitched (added to the Wort) it must be cooled down to around 30°C other wise the yeast will be killed. This cooling process if unaided can take hours which besides being impractical exposes the the freshly made beer to airborne bacteria and undesirable wild yeasts. For this reason the Wort is cooled down to a practical temperature using a Wort cooler or Wort chiller.
There are two common types of Wort cooler counter flow and immersion, this instructable details the build process for the doommeisters twin coil immersion Wort cooler. Immersion Wort coolers as the name suggests are immersed in the hot Wort and cold water is passed through the cooler thus bring the temperature of the Wort down.
For small batches immersion coolers are much easier to clean and sterilise than counter flow coolers, this is because they can be sterilised in the hot Wort itself by adding the cooler in for the last 15min.
There are many plans and photos on the Internet for this kind of cooler so this is not really an original design more an interpretation.
Remove these ads by
Signing UpStep 1You Will Need
Metric sizes are shown, American imperial sizes in brackets.
1.5m of 15mm (1/2”) OD copper pipe.
15 – 20m 10mm (3/8”) OD copper pipe.
2, 15mm (1/2”) copper Tee fittings, sweat or solder ring.
6, 15mm (1/2”) copper elbow fittings, sweat or solder ring.
4, 15mm (1/2”) to 10mm (3/8”) reducing fittings, sweat or solder ring.
Solder, 99c lead free.
Flux
4” pipe and 6” pipe or similar to use as coil formers.
Pipe cutter.
Gas torch.
Heat resistant mat.
A selection of other hand tools.
Additionally you will need some hose or food safe tubing to connect the cooler to cold tap and back out to drain.
I would expect based on similar designs that it would cool the Wort in 15 - 25 minutes for a 5 gallon batch.
I look forward to hearing how it does, it looks really cool!
I would not recommend leaded solder for any potable use, but am unsure whether lead is even soluble in alcohol (if someone knows than let me know 'cause I would want to poison myself either). Most cases of lead poisoning in homebrew seem to be attributable to the use of older enamelled vessels with lead based pigments.
As for flares or compression fittings I decided against these as they would be more difficult to sanitise.
With regard to condensing Alcohol then if someone wanted to do this then they should make them selves cogisent of ALL the risks involved with that particular process.
I think the best option if anybody was concerned about this would be just to use a loop of copper or stainless and not submerge any fittings. I have gone back to thinking this isn't much of an issue.
L
I estimate the build cost around £35 including the fittings
L
When I get round to putting my shed up I think I might well be reading your instructable, for information purposes only of course.
well ill post mine in a bit anyway as its a solder free version. keep up the homebrew!
Chard
For homebrewing (>23L), what's the benefit of this method over letting it stand to cool before pitching?
Nice job!
I use the same method of coils for synthesizing liquid oxygen through liquid nitrogen!
Great idea, and great instructions...
There are a TON of uses for this
