The easiest way to perform this task was to re-use existing equipment installed in my home, & power toys to minimize costs.
My favourite expression to utilize cross functional synergies.
Well, I was able to put together the following items
At Home items
a) 2 Batteries (Used for my Motor Boat) 140AH
b) Lawnboy lawn tractor 10 HP (1980s vintage)
Sale Items
a) Xantrex 1000 power inverter ($89.00) Cdn Tire
Regular Priced Items
a) Fan Belt 4L44 Cdn Tire $ 11.00
b) 12V Car Led Lamp Cdn Tire $ 2.50
c) AC Power Monitor (UPM Em100) Cdn Tire $ 25.95
d) Battery clamps Cdn Tire $ 5.95
e) Booster Cables Cdn Tire $ 20.00
Optional: Siemens Generator Panel Box (and Circuit Breakers) $280.00
Note: Extensions cords will do in a pinch!
Scrap (Yard) Items
a) Cadillac Alternator (120amp) with Built in Regulator $ 35.00
b) 4 Position Switch (Scrap from old Battery Charger)
c) 6 Gauge Wire (Old Battery Booster Cables)
d) Panel Mount (For Switch and light)
e) Tie Wraps (Keep all loose wires tight and away from Belts)
Total Cost *Including Electrical Panel $ 469.40
Without Electrical Panel $ 189.40
Remove these ads by
Signing UpStep 1Alternators
Alternators
The cheapest way to connect an automobile alternator is to select one that has a built in regulator. In many instances they are denoted as a single wire connect. If you have external sense lines coming from the alternator (As Below) , wiring can become a little more difficult as you may need a resistor value of approx 35 ohms leading from the Generator Light wire on the alternator to + DC voltage. You also have to have a Power Switch to disable the charging of the stator at initial power up time. I.E. The resistance of the alternator can generate enough force feedback to make it too difficult to start you engine.
An example a Mack truck’s idle speed is 400 to 500 rpm and max rpm is 1800 you might want to run the alternator at 1000 to 1200.
A Chevy Sprint’s idle speed is 1100 and max rpm is 10000 rpm its alternator you might want to run at 3000 rpm.
To connect to house wiring you need a 220 110-volt power inverter with a pure sine wave signal synchronised to the service. The output is kind of like a centre tap transformer. Service transformers have the windings hooked up in ether delta or Y configurations they’re essentially a centre tap transformer. This is a simplified explanation.
I hope this helps.
My reference to using a (Non Bonded Neutral) for the switch panel is a non standard approach to temporarily use (During a power failure) for key switched circuits. By using a non bonded Neutral it is possible to use a less expensive inverter (Square Wave) versus True Sine wave as you mentioned above.They in reality do not use the same methodology for power generation (Center Tap transformer) and hence the need to have the Neutral (NOT Bonded) to the ground line. It is not an accepted standard for household wiring to have the neutral unbonded from the ground line, but is the only way possible to use a square wave inverter on household wiring via a switched panel.
Your assessment above is absolutely correct and is a superior configuration (True Sine Wave Inverter) that meets existing legal wiring codes. In your instance above, with a True Sine wave inverter, the Neutral Line would remain bonded to the Household ground
Element Four
I'm sure the cost of a purpose built alternator designed to 120V would well exceed the intent of an instructible. You'd be better off buying a cheap generator!
