Homemade 0-25V 3.5A Variable Power Supply (even Charges Batteries)
1,853
33
4
Posted in TechnologyElectronics
Introduction: Homemade 0-25V 3.5A Variable Power Supply (even Charges Batteries)
This Power supply can charge batteries or just power things. It goes to 25V and 3.5 Amps. It is variable and has an indicator light
Step 1: Connectors
These are alligator clip connecting to the power Supply
Step 2: Parts and Components
Simple Layout
Step 3: Top
Top view
Step 4: Both
Step 5: Solder Points
Solder in this sequence
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Wht s input voltage? pls attach circuit diagram
    it is a simple PWM. Google "555 PWM" for schematics. however, this won't survive long under a load of the advertised 87 watts. you can give this ability, but you would need to use a FET for switching and add some cooling to it. the 555 would only act as control and not as switch.
    What components did you use?
