Check out http://ecomodder.com/forum/open-revolt-open-source-dc-motor-controller.html
if you want to read about the whole story!
Experience in soldering is important. If you want to really keep costs down, a mill is helpful, but that work can be outsourced to a local metal shop.
Remove these ads by
Signing UpStep 1: Get/Make a power board and control board.
http://cgi.ebay.com/25-shts-Copper-Clad-Laminate-FR-4-060-9-x-12-3oz-/310244821519?pt=LH_DefaultDomain_0&hash=item483c084a0f
You could print the picture from this link and somehow transfer it onto a piece of heavy blank PCB, and etch it with a dremel if you have a ver y steady hand. The dimensions are 8"x6". This link also has the G-code that you can use to etch with a CNC mill or you could give the G-code to a machine shop.
http://ecomodder.com/wiki/index.php/Open_ReVolt/Fab_Files
Picture 2 and 3 below is an example of an early power board I made with a Dremel.
You can get a control board from me or you can make the control board in your favorite PCB layout software using the schematic here::
http://home.cogeco.ca/~tkooistra/Cougar_Controller_Rev2C_Schematic.pdf
And here are some pictures of the PCB layers:
http://home.cogeco.ca/~tkooistra/bottom_layer_rev2C.pdf
http://home.cogeco.ca/~tkooistra/top_layer_rev2C.pdf
http://home.cogeco.ca/~tkooistra/component_layer_rev2C.pdf
A predone control board is Picture 1.
Pictures 7 and 8 are the power board top and bottom. The 8 solder spots are just where vias were added.
Once you have the 2 boards, you can go to step 2.
Visit Our Store »
Go Pro Today »
My email address is anriocarver@yahoo.com
I leave in Mauritius.
I can not download the schematics for the control board. Please help.
I need a motor controller for 24 volts that will run the thing either from a wired throttle or eventually a servo output from an RC receiver OR an actual servo mechanically coupled to a pot that is wired to the controller (This should give perfectly isolated power from the vehicle's 24 volt system and the RC's 6 volt system, yes?)
I WANT to have the option to run it via RC or to be able to plug in a wired controller because the vehicle will be large enough to sit on when complete.
Can someone please suggest a source for such a controller? I DO NOT have the original controller from the Mobility Scooter, or I would gladly just use it. I know I could buy another controller for the chair or a similar model, but I would like to see what else gets suggested, first.
Thank You!
DieCastoms.
I'm working on electic car project in Algeria.
Many thanks,
Steve
A quadrant is the measure of motoring and generating, in forward and reverse.
1st quadrant. is motoring forward, 2nd quadrant is motoring backwards, 3rd is generating backwards, and 4th is generating forwards.
You can implement 1st and 2nd quadrant with a relay, you can't do 3 and 4th without a full bridge.
So essentially, can you do regenerative braking ?
Steve
Steve
Lets not let small things like that derail a movement to the right direction
You won't be tootin' the horn enough to make an appreciable difference in battery pack life, they tend to be under 75W and that for a second or two, but it is possible you could be doing it often enough to be a nuisance. ;)
The main way to be safe on a motorcycle is not by making people hear you, it's by making them see you. People have to look around to drive while their ears may be occupied by a cell phone, stereo, etc.
Is there a full circuit of it ?
http://home.cogeco.ca/~tkooistra/Cougar_Controller_Rev2C_Schematic_All.pdf
Although that was a older schematic that used 24 470uF ripple caps. Now I use 16 1000uF ripple caps.
If anyone would like to buy it, drop me a note. sidcranston@yahoo.com
I have no idea what shipping would cost, but it is pretty hefty.
716-525-4900
Just a thought, you could eliminate a lot of voltage spike issues by mounting the controller as close to the motor as possible. Any time the length of the wire between the motor controller exceeds the diameter of the wire, the collapse current becomes significant. Since Vpeak = di/dt, and you have a peak current of ~500 amps, if your switching time is <1ms which I'm guessing it is, this will result in a spike of 500 000 volts! These voltage spikes can damage the control circuitry. This is assuming that you are having voltage spike issues to begin with. Regardless it is typically a good idea to mount the power control board as close as possible to the motor.
-alex
I'm pretty sure every wire I've ever used was longer than it's diameter.
Not that I doubt you, but where are you measuring the spikes. The ones that I am referring to is the reverse against the driving fets from the motor and supply cables to it. If you're getting results around 25 volts then you have done a damm good engineering job and kudos to you sir.
--alex
ps awesome response time
Another issue is that the voltage spikes are a result of firing into a reactive load, which is more like a motor prevented from spinning. A freewheeling motor (which I heard) will not cause inductive kickback as much as if you lock the parking brake and do it, you should try that.
A wise teacher of mine who makes giant stepper-motor controllers (and Aerco pre-amps) says that the key to protecting your fets is a combination of small and large diodes (they have different properties) and resistor-capacitor snubbers and most importantly, MOV (Metal Oxide Varistors) which are your first line of defense.
But i definitely know that the spikes are worst when the motor is stalled.
It's my senior project for college. Great excuse to rip around campus with a less than legal electric car!
Between you and the Soliton 1, you guys are all the inspiration i need!
