First: Attempt at your own risk, don't hurt yourself and I am not responsible for any damages from anything that may occur.
Motivation: I just recently purchased a 18V cordless tool set and couldn't find a radio to run off the batteries (as some of the big brands make such radios), so i decided to make one.
Parts: (some are optional, all depends on what exactly you want it to do)
-Car Stereo (I had an old Pioneer laying around)
-Speakers (I got 5.5" Boss Marine speakers on Amazon, they shouldn't be bothered by a little water)
-Antenna (Pyramid 3800 from amazon, keep in mind how to mount it, I had to buy a longer screw for the thickness of the wood)
-Fuse Block (protect all those delicate components, ebay)
-12V Power Supply (I got a 5A light supply from ebay, just search for "12V 5A Power Supply" they are like $10)
-120V Relay (once again ebay, make sure it has 3 separate sets of contacts)
-Switches (1 toggle, and 1 push button)
-Wood for the box (I had some OSB with Mossy Oak print on it laying around)
-Digital Panel Mount Voltmeter (ebay for up to 20 Volts, to keep an eye on the battery)
-12V outlet
-18V drill battery charger
-Corner braces
-hinges
-window lock
-handle
-misc Screws
-Extension cord to use as a power cord and plug for the charger
-Metal to mount the switches in etc (I had the metal inserts from old Radio Shack project boxes)
-Aluminum tape (cover the edges of the box, mainly for aesthetic reasons)
(these parts are for the circuit to knock the 18V down to 12V)
-3x 100n ceramic Capacitors
-100uF Electrolytic Capacitor
-4.7uF Electrolytic Capacitor (I used a bigger one but this is the one the circuit called for)
-1N4007 Diode
-7812 Voltage Regulator IC
-2N3055 Power Transistor
-Heatsinks (one small one huge)
Remove these ads by
Signing UpStep 1: 18V to 12V voltage regulator circuit
(I know I soldered the components on the wrong side of the board, no need to remind me, noob mistake. Still works fine)
-1N4007 Diode
-Heatsinks (one small on huge)
Visit Our Store »
Go Pro Today »
Anyway, they will have much better efficiancy than a linear regulater.
Also I dont know about putting line voltage on the same fuseblock that you have low voltage on. i would seperate it out and use a mains rated fuse holder, not a car style one.
