Remove these ads by
Signing UpStep 1: Tools and Materials
1. Soldering Iron
2. Drill
3. Caulk Gun
Materials
1. Solar Cells
2. Bus Bar
3. Tabbing Wire
4. Solder
5. Flux Pen
6. Plywood
7. Trim Pieces
8. Primer
9. Super Paint
10. Silicone Caulk
11. Wood Glue
12. 14 Gauge Wire
Visit Our Store »
Go Pro Today »
1. do you can make silicon solar for step by step
2. what from
Iam Sorry sir
Let me give you some insights about what you are asking for..
1. It would be more expensive to build your own silicon solar cells. Only consider doing that if you're thinking about building a factory for it, considering that you will have to procure machinery, equipment, and materials. And I assume that you will never find materials sold on a retail basis at a good price. If you want to make a solar cell, follow the link below. However, it is not using silicon and it is not that as efficient.
http://www.instructables.com/id/My-home-made-solar-cell-1/
2. If you're looking for pre-made solar cells or solar panels, I suggest you check look for local supplier in the internet and not from overseas. Importing items from overseas could have heavy taxes (just like in my country) but it depends so you better research and consider that as well. Buying from a local supplier means that you will get the items fast, gives you the opportunity to see the items personally prior to purchase, and benefits your country because a local businessperson will be the one to earn the profit.
I hope that helps! :)
This should tell you what you need to know.
you may not have a moisture issue in the winter as much
but with the wood panels most need the vent holes not big but small to get it out
So far i my all glass diy solar panel is doing good with no water,or moisture getting in i have made two so far,i have made the wood frame diy and i still like them they just need a little more work but they are fun to build
this is my all Glass solar panel
https://sites.google.com/site/earthforsolar/glass-frame-diy-panel
David
like i said, not an expert, just what i think is happening and a possible fix
this is the link
http://www.solarcells101.com/index2.php
Thanks for sharing you DIT Solar Panel
David
Plywood will absorb the moisture in the air over time even if primed and painted, so eventually there will be moisture inside the panel. Fogging will be an issue over time if the system can't be ventilated, just like a double paned window where the interior seal fails.
Fogging is not a huge issue for me because my panel has holes in the back of it, so as soon as it warms up a little bit it un-foggs.
I always save them 'just in case' - our cottage is damp and I use them to protect things (like a vintage clock I love).
[-+] [-+] [-+] [-+] [-+] [-+] [-+] [-+] [-+] ([-+] solar cell)
each cell only puts out .5 volts so this type of wiring gives you a higher voltage.
