3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade 63 Watt Solar Panel
I am a young person interested in solar energy. I decided to build a solar panel. I am young and if I can do it then anybody else can to. I will take you through everything from building the frame to soldering. When this is completed this will give you 63 watts of free energy that is good for camping or for small household items. Lets get started!
Step 1Tools and Materials
Tools
1. Soldering Iron
2. Drill
3. Caulk Gun
Materials
1. Solar Cells
2. Bus Bar
3. Tabbing Wire
4. Solder
5. Flux Pen
6. Plywood
7. Trim Pieces
8. Primer
9. Super Paint
10. Silicone Caulk
11. Wood Glue
12. 14 Gauge Wire
41 comments
1-40 of 41next »
Jan 8, 2010. 9:59 AMbudiyanto says:
hello sir.sorry i cant speak inggris. but i have very much guestion.for you sir.I from Indonesia.my guestion like this :
1. do you can make silicon solar for step by step
2. what from
Iam Sorry sir
Sep 3, 2011. 1:31 PMJustinKubicek says:
Walmart has to get it from somewhere. This guy made a homemade solar cell with copper http://www.youtube.com/watch?v=g5Edw99PgzQ
Mar 4, 2011. 9:42 AMimajem says:
Does anyone know how to feed the energy back into the grid? That would be helpful?
Aug 29, 2011. 1:43 PMhenry32008 says:
Grid tie inverter.
Apr 10, 2010. 12:11 PMkktwags says:
I made 4 60 watt solar panels , they work great for the most part , we installed them on our awning with 2x4's unerneath for air to get through however we are having major moisture issues.  when we built the first two we thought it was because we used to much silicone and didn't seal up the sides good enough but we just built two more with alot less silicone and we sealed the sides with aluminum tape however there is still alot of moisture in the panels.  It always starts with a fog and then turns into alot of water droplets.   Do you or anyonelse have any suggestions on how to fix this or why this is happening. Wehaven't been able to come up with any other reason.
Jul 19, 2011. 10:46 PMpaqrat says:
It sounds like condensation to me. Perhaps moisture laden air, trapped in the panels is condensing on the glass during the cooler times of the evening? If it was mine I think I'd see about opening some holes, perhaps underneath so rain coming in would not be a problem.
Feb 15, 2011. 3:20 PMEARTHFORSOLAR says:
If you have the solar panel sealed good and you are still getting moisture,water or fog,then the next thing is vent holes to let it out, i would try at the top of the panel under the panel, OR two sets of air holes and a little fan to dry it up this is good in the summer to keep the solar cells cooler becouse they work much nicer when they are cooler ANY WHAY!
you may not have a moisture issue in the winter as much
but with the wood panels most need the vent holes not big but small to get it out
So far i my all glass diy solar panel is doing good with no water,or moisture getting in i have made two so far,i have made the wood frame diy and i still like them they just need a little more work but they are fun to build
this is my all Glass solar panel
https://sites.google.com/site/earthforsolar/glass-frame-diy-panel
David
Jan 16, 2011. 6:03 PMGrey_valentine says:
have you thought about mounting a computer fan in the box? It shouldn't be any drain at all on the power. If you got some air flow through the box I don't think you would have a problem.
Oct 1, 2010. 1:19 PMrcisneros says:
Professional panels have cells that are encased in a polymer. The most popular is called SLYGARD. You pour it over your cells and they are completely protected. It's not cheap though. But will it cost if your cells get damaged or corrosion destroys them?
Oct 4, 2010. 12:01 PMrcisneros says:
I think your right. That stuff is too expensive for me, but that will solve the problem
Apr 16, 2010. 8:20 AMtalonsblade says:
not sure if this will help but have you thought of a way to maybe make it vacuum sealable?  you are getting fog and water droplets for the same reason we get dew.  the air inside has moisture in it, especially if it is made on a warm day.  warm air can hold more moisture than cold(why you get dew when it starts to get cold).  if you seal it up, and the air temperature drops then the moisture come out(fog and water droplets).  not sure if it will help but i think if you wait till a cold day to make it, then vacuum out as much air as possible before you seal it up it might help.
like i said, not an expert, just what i think is happening and a possible fix
Apr 16, 2010. 8:21 AMtalonsblade says:
just spit-firing ideas but maybe make in a room with dehumidifier? never used one and have no idea how effective they are but just another suggestion.
Apr 10, 2010. 6:42 PMkktwags says:
andrew thanks for your info, however i didn't drill any hole and we did unscrew them and air them out and still fogs up.  I know it really don't seem to affect the output however it did rot the wood at the bottome and corode the one bus wire.  Any other suggestions
Apr 13, 2010. 10:02 AMkktwags says:
andrew i already did that  this past weekend with the aluminum tape and airing them out and it still does it
Jul 1, 2011. 11:18 PMmcarrell says:
Try filling the air-gap between glass and panels with clear epoxy (the type that doesn't yellow). That will solve the moisture issue for certain.
Mar 16, 2011. 9:29 AMrocketman20 says:
How much did all the solar cells cost
Feb 17, 2011. 11:59 AMEARTHFORSOLAR says:
I added this page to my link page. This is a nice looking solar panel
this is the link
http://www.solarcells101.com/index2.php
Thanks for sharing you DIT Solar Panel
David
Jan 24, 2011. 6:06 AMhardwarehank says:
You can reduce the cost by buying surplus windows at a community recycling center (waste transfer station, BRING, Community Forklift - if they have surplus toilets, you're in the right place...). Also, sealing the cells with Through The Roof seems to work pretty well to keep moisture away from them - it's cheap and it dries clear. I'll do an instructable on my method once it's all proven out in the summer heat. Nice instructions though!
Apr 27, 2010. 1:42 PMPal says:
I'm curious if there's a good reason for trying to seal these up to be airtight? If you could make the panel strong but leave say most of the back side open, so the top was solid and the sides flashed to prevent rain from hitting anything, would this cause trouble over time?
Plywood will absorb the moisture in the air over time even if primed and painted, so eventually there will be moisture inside the panel. Fogging will be an issue over time if the system can't be ventilated, just like a double paned window where the interior seal fails.
Apr 16, 2010. 10:59 AMourmoneypit says:
You know those little silica gel packets that come with so many things these days to protect them from moisture during shipping?  Maybe tucking one of those into the unit along the side somewhere, where it wouldn't interfere with the operation/sun capture would address the moisture issue?
I always save them 'just in case' - our cottage is damp and I use them to protect things (like a vintage clock I love).
Dec 25, 2009. 9:34 PMGreenD says:
Rather confusing - you just stated that you connected your positive and negative tabs to the same bus bar... You should (have) take(n) a picture of the overall layout - and indicate where your positive & negatives are going, justa  thought.
Feb 3, 2010. 5:28 PMPyrotechnic-Robot says:
You connect each cell in a ceries wiring so the cells are connected from +  to  -.
[-+] [-+] [-+] [-+] [-+] [-+] [-+] [-+] [-+]       ([-+] solar cell)
each cell only puts out .5  volts so this type of wiring gives you a higher voltage.
Dec 7, 2009. 4:36 PMtjmalek says:
Where are you feeding your electricity to? I've thought of using Li-ion batteries to store the energy then using that to charge other things, but LI batteries aren't cheap. Rechargeable NI-Hydride batteries seems bulky and impractical. And, after buying a meter, array DC disconnect, inverter and an AC breaker panel, feeding the energy back into your grid can cost quite a bit also.
Nov 10, 2009. 7:14 PMdonald7777 says:
how are your solar panels still working?
Sep 27, 2009. 2:36 AMChiana_Rei says:
Any wood will split if you just try to slam a screw into it. Just predirll a pilot hole a little smaller than your screw, it will prevent splits and also help with getting the screw in straight, I would go back and at least tack the trim down with brads. I don't think I would trust that much money in parts and that much time to glue alone. Also a few more pics of the process and more detailed instructions would benefit this ible greatly, Good start just needs a bit of polish.
Sep 26, 2009. 4:18 AMfegundez1 says:
where and at what price did you get the cells? A few pictures of the process will be great as well. The panel looks great
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:airsofter1
