Step 2Build the Frame
iImage Information
The frame is the easiest part of the solar panel. Take your 2 by 4 piece of plywood and glue your trim pieces to it. Now predrill some holes and screw it down with fairly skinny screws. Screw down gently and slowly. Now use primer to coat it 2 times and paint with Super Paint. I recommend Super Paint because it is high quality. Finally you should caulk with silicone on the inside edges for a good seal. I now suggest that you add 4 quarter inch holes for breathing. The holes are important so that if any moisture gets in, it can get back out easily. It is important that they are drilled on the bottom so if your panel is out in the rain, huge amounts of water won't get in. You could also seal the panel off completely, but if you don't make it in a dry room water could be trapped inside your panel. Make sure to seal the panel well or otherwise water can get in but not get back out nearly as easily.
