Introduction: Homemade Acidic Fertilizer
Picture of Homemade Acidic Fertilizer
In fact plants acidic fertilizer is also important as that of organic fertilizers for plants (azaleas,roses,rhododendrons, blueberry, hibiscus and other acid-loving plants) needs acidic fertilizers.For instance,eggshells are almost 100% calcium carbonate, one of the main ingredients in agricultural lime; vinegar has acetic acid; & coffee not only lowers your soil pH ,it also enriches it with nitrogen,magnesium and potassium.
too much use of fertilizer can make soil too acidic so thee fertilizers should be used in a limit.
EPSOM SALT FERTILIZER
COFFEE GROUND FERTILIZER
EGG SHELL FERTILIZER
VINEGAR FERTILIZER
FISH TANK FERTILIZER
are some of the accidic fertilizers wich can be made in home with less cost for plants.
Step 1: Epsom Salt Fertilizer
Picture of Epsom Salt Fertilizer
 Epsom salt fertilizer:use in place vegetable plants,rose plant, peppers,houseplants
ingredients:
1 table spoon Epsom salt
1 gallon of water
combine the Epsom salt and water and use this solution to water your plants.repeat once a month. Epsom salt is made up of magnesium and sulphate-both vital plant nutrients.
Step 2: Coffee Ground Fertilizer
Picture of Coffee Ground Fertilizer
 coffee ground fertilizer:used for rose plant.
ingredients:
 used coffee grounds
newspaper
spread news paper.then spread used coffee grounds out on the paper and allow them to dry completely in sunlight for about 2-3 days.sprinkle the coffee ground around the base of your rose plant.
Step 3: Eggshell Fertilizer
Picture of Eggshell Fertilizer
 Egg shell fertilizer:used for all kind of plants
ingredients:
Egg shells
Blender
save your egg shells and allow them to dry.place the dried shell in the blender and pulse until they are turned to fine powder.Sprinkle in your garden.Eggshells are made up almost calcium carbonate.
Step 4: Vinegar Fertilizer
Picture of Vinegar Fertilizer
 vinegar fertilizer:used for houseplants and vegetable plants
ingredients:
1 table spoon white vinegar
1 gallon of water
combine the white vinegar and  water. use the solution to water your plants.repeat every three months.the acetic acid in vinegar works to increase the acidity of the soil.
Step 5: Fish Tank Fertilizer
Picture of Fish Tank Fertilizer
 Fish tank fertilizer:used for any plants
save the dirty water from fish tank and use it for watering plants.Used fish tank water is full of nitrogen and other ingredients and plants need thrive.
Step 6: Note:
Picture of Note:
 for best results use acidic fertilizers with organic fertilizers or dilute the acid fertilizers.
ibrahimS80 (author)2017-01-06
nice
will1947 (author)2015-07-08
Please don't use marine fish tank water, it's basically sea water.
lemonie (author)2010-05-16
It could do with your own pictures of things you made.
Egg shells are not acidic, you might want to mention that.
L
bobbylion (author)lemonie2010-05-17
 though egg shells are nt acidic they contain calcium carbonate n essential element for plants growth...
lemonie (author)bobbylion2010-05-17
Yes, but under the title "Acidic Fertiliser" you might want to point out that carbonate is a bit basic / alkaline.
L
DIY-Guy (author)lemonie2011-11-29
The title to this instructable is accidentally misleading. It would be a nice gesture if the author would rename it more accurately. Thank you!
Perhaps "Household acid and base fertilizers" would work for you?
lemonie (author)DIY-Guy2011-11-29
Well it's been ~18 months and it hasn't happened. I'm not too concerned.
L
Lemonie: I've taken eggshells and dissolved them in vinegar, got some fine powder and sometimes some crystals precipitated out.
After thinking about it as a way to give calcium to plants I decided that just crushing eggshells into my compost mix would work as well. Time, bacteria, rain, and regular watering should get the calcium into the root systems. I figure this to be true because oyster shell calcium is sold for gardening and that is not precipitated out in fine powder. It seems to dissolve naturally in the environment of the soil.
On another note: If coffee grounds are going to be spread upon the soil, why bother drying them? It seems to work fine dumped onto the base of the rose plants. (Grandma taught me that one years ago.)
kplotke (author)DIY-Guy2013-03-29
I had the same question about the coffee grounds. Thank you!
lemonie (author)DIY-Guy2011-11-30
This isn't my instructable, but I think you could put an interesting/useful one together. Do you think so?
L
DIY-Guy (author)lemonie2011-11-30
I appreciate the encouragement. I've been only partially engaged with the whole Instructables process for some time now. Looking forward to doing a well documented Instructable after I put all the photos and facts together.
kplotke (author)2013-03-29
Can you add egg shells, coffee and epson salt together? Why do you need to dry out coffee grinds?
About This Instructable
135,528views
25favorites
License:
More by bobbylion:MOSS GARDENHomemade Acidic Fertilizer
Add instructable to:
