Introduction: Homemade Air Freshener Gel
I wanted to share my experience with making these easy and useful Air Freshener Gels. A relatively low cost Do-It-Yourself room air freshener, you may have all the ingredients already!
I keep one in each vehicle and at my desk at work.
The total time it takes to make is about five to six (5-6) minutes and then twenty-four (24) hours to solidify.
Materials & Equipment:
Prepare:
Boil and Mix:
Can you believe that's it?
The scent and solid mixture will disintegrate over time. The one in my car has lasted over a month. The one in my bathroom has lasted over a month but probably will be ready to clean out in another week. I estimate that one jar would last from four to six (4-6) good weeks of scent dispersion. Make sure the lid is off the container to enjoy!
Thanks for reading and I hope you post pictures of your gels.
The original Pinterest pin for this is here: DIY Air Fresheners.
- Three (3) to four (4) jars, capable of holding 1/2-cup of fluid each. I used four (4) clean and recycled baby food jars, and each jar holds 1/2-cup of mixture.
- Food Coloring
- Essential Oil or Room Fragrance drops (Can be purchased at a craft store, but I found one on sale for $2 at Wal-mart.)
- Two (2) cups of water, divided into two 1-cup amounts
- Four (4) envelopes unflavored gelatine (one 1-oz box)
- One (1) tablespoon of salt
- Kitchen equipment such as a whisk, a pan to boil the water and spoons (plastic or metal) to mix the concoction
Prepare:
- Pour a few drops of food coloring of your choice into each jar.
- Next, pour one (1) teaspoon (minimum) of essential oil into each jar. You may want to add more if you desire a stronger scent emanating from the end result. I did not use more than two teaspoons and was pleased with the one teaspoon result.
Boil and Mix:
- Bring one (1) cup of water to a boil.
- Add all four (4) envelopes of gelatine to the boiling water and whisk until dissolved. (I estimate it dissolved in about a minute.)
- After the gelatine dissolves, add the remaining cup of water and then the salt.
- After the salt dissolves, remove the pan from the heat and pour into the prepared jars. Try pouring the mixture into the jars within a few minutes of removing the pan off of the heat.
- NOTE: Please be careful as the mixture will be very hot! My husband held the pot with a steady hand for the photo. However the second time I did this by myself, I made a mess everywhere and spilled the gelatine mixture on the counter. You may want to use a funnel to put the gelatine mixture in the jars.
- I used a broken clothespin to stir the gelatinous combination, but suggest using plastic spoons. Use them quickly as the heat from the water could make them melt slightly.
