3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Air-Rifle
Step 4Making Bullets
Making Bullets
  • C:\Users\owner\Pictures\2007-07-17 random\random 015.JPG
  • C:\Users\owner\Pictures\2007-07-17 random\random 016.JPG
There are a variety of ways to make your projectiles, ranging from murderous to fun. However, it is important to use your creativity and not learn just from me.
The easiest and one of the most effective ones are just rocks with enough masking tape to fit down a barrel.
Aluminum foil is always fun, going faster than a hard bullet but they do not hurt at all. Unfortunately, they are limited with accuracy to only ten meters. Don't be fooled, if one of these hits someone in the eye, they're blind.
The one of the deadliest bullets in the arsenal. Three small nuts (nuts and bolts) taped together with a lot of tape so they fit the barrel tightly.
The classic pouring water down the barrel is so intense. It sprays well and has a lot of recoil!
The greatest and evilest bullet here is hardly a bullet but a dart. Take a nail about 4 cm long and put a ball of foil down until the flat part stops it. Then tape it secure. Make sure it snugly fits in the barrel and also has no trouble going down. Then take some more foil and roll it into a compact tube 3 cm long. Then add some tape fins to one end. These fins are angled apart from each other like a helicopter rotor so that it spins in flight. Attach this tube onto the end of the foil ball.
4 comments
Jul 11, 2008. 7:45 PMGZNG says:
would eggs work???
Aug 19, 2008. 1:31 PMcowscankill says:
if they fit? lol idk. i need to find out how to make paintballs for my air gun... and also for the new airgun i am working on
Aug 20, 2008. 3:26 AMGZNG says:
try making a small bowl using paper mache fill with eggwhite mixed with food colouring when the bowl is dry then make another bowl over the first and seal up
Oct 1, 2009. 12:28 PMLegend in your Mind says:
Wouldn't it be easy to make a mold fromsomething resembling eggs or just fasion your own, but make a plaster mold to make egg after egg quickly.. you could even us the same material they use to make greenware in ceramics even though that mud takes a while to dry..basically pour it in, let it dry for a short time then pour out the rest..what's left inside sticks to the walls and whallah! An egg mold!
Oct 1, 2009. 12:31 PMLegend in your Mind says:
Oh yeah..forgot to mention to make the mold so you can open it..basically slice it right down the center with a hack saw, but keep it TIGHT so the mud doesn't just leak out making a huge mess..For that matter you can buy egg molds cheap on ebay i bet...they DO sell large bead molds too you can alter a bit.
Aug 20, 2008. 3:43 PMcowscankill says:
a very small bowl im guessing?
Jun 29, 2008. 1:16 PMcamb00 says:
Im working on a exploding bullet
Oct 7, 2008. 6:11 PMstasys says:
to make an exploding bullet, make a mix of caps and match heads, put it on foil, and then scruch it up - CAREFULLY!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:The_Kangsta
