Introduction: (Homemade Airgun) Bullets V2
In this Instructable I will show you how to make airgun bullets.
P.s. These get great distance, Great accuracy and Can punch a hole straight through a milk bottle of water or a piece of plywood Depending on the power of your airgun.
It necessary to get the closest fitting piece pipe you can get as the bullet shell, but it should not be to tight to get maximum power from your airgun.
Try my new instructable: https://www.instructables.com/id/Long-Distance-Bullets
Step 1: Materials and Tools
What you need:
Tools:
Glue gun
Hacksaw/Anything that cuts metal
Scissors(I used a Stanley knife)
A bowl of water
Materials:
5 nails that fit in your bullet shell(Use common sense for instance if you have 3 big nails you can substitute them for the five nails)
Brightly colored String
Glue sticks
A pipe that fits snugly in your barrel for the bullet's shell.
Tools:
Glue gun
A bowl of water
Materials:
Glue sticks
Step 2: Step 3
First plug your glue gun on. Then take your nails and cut the heads off. Now Cut your pipe to the length you want (mine was about 15 cm). Next insert them into the pipe and cut them so that the are slightly shorter then the pipe. Now fill the bullet shell with glue. Gluing the nail into the bullet shell like in the badly made picture. Don't unplug your gluegun yet.
Step 3: Step 4
Almost done now cut about 5 or six piece of string that are about 9 or 10 inches. Next tie a knot at the top to connect the pieces together. Then glue the knot to the back of the bullet like in the picture.
Lastly take the gluegun and put a bit of glun on the front, then dunk your fingers in the water and use them to shape the tip. As soon as your happy with the shape dunk the finished bullet in the water to cool it off.
Disclaimer
I take no responsibility for any damage caused by these bullets or the making of these bullets
##############!!!!!!!!!!*********!!!!!!!!JUST BE CAREFULL!!!!!!!**********!!!!!!!!!!##############
Disclaimer
