Intro: Homemade Airsoft Grenade Launcher Powered By Co2
This is a homemade grenade launcher for your airsoft guns. It has an inner high pressure chamber. This launcher uses 12g Co2 cartidges to pressurize t...
For this instructables you will need the following materials: -2 piece of 1.5 inch abs pipe (1 feet long each) -2 1.5" coupler -2 1/2" metal ball valv...
Disassemble the dollarama party popper and keep only the tube. You need to remove the bumps and line inside the tube. Mesure 8 lenght of toillet or si...
You need to assemble the plumbing parts in this configuration. ADD A LOT OF TEFLON! In the bottm of the 3/4" cap, glue the thumb tac with the hot glue...
Step 5: Cutting the Abs: The Co2 chamber and valve
The lip of the 3/4" cap must be on the edge of the abs pipe. From there draw a mark like in the picture. Once you noted the edge of the bolt, cut a pi...
Step 6: Cutting the Abs: The pressure chamber, firing valve, shell
Now that the first half of the launcher is done. It's time to do the other half. Be sure to refer yourself to the pictures below. The step for cutting...
Your launcher is finally complete. You can either glue the shell down or make a locking mecanism. Insert a 12g Co2 cartridge in the Co2 chamber like i...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
