No longer do you need to be a slave to the Altoids empire! Now you can make curiously strong candies in your own kitchen. I started with peppermint, cinnamon, and sour apple. What's next? Clove? Coffee? Bacon?? The sky is the limit!
These can be stored and gifted in your own personalized tins. How thoughtful!
Remove these ads by
Signing UpStep 1: The Secret Ingredients
- Gum Paste
- Powdered Confectioner's Sugar
- Flavored Oils
- Citric Acid (to add to flavors to make them sour)
- Bubble tea straw (or small round cutter)
Scoochmaroo is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com.
Visit Our Store »
Go Pro Today »
I"m excited to try this, but I'd like to incorporate xylitol into this recipe. Any thoughts on the best way to do it? Ideally, I'd like to make it so that eating 3-5 mints throughout the day would end up having 2tsp of xylitol.
http://www.drellie.com/Xylitol.php
http://www.xylitol.org/dental-benefits-of-xylitol
http://www.healingteethnaturally.com/xylitol-dental-care-frequently-asked-questions-faq-4.html
Because as much as I adore the 'toids, it IS rather an expensive addiction. I noticed that on the Altoids tin, their ingredients are sugar, gum Arabic, artificial flavors, gelatin, and dye. Do you have an opinion on the use of gelatin or doesn't it make a significant difference?
One of the perks of using a powdered gum paste mix like Wilton's makes or making your own is you can use tea or coffee to make the stuff, and that gives you more options of flavors. I like to make chai ones.
Glad it worked out for you. Your 30 days of Instructables is brilliant! I absolutely love it.
Thanks.
You might end up with squashed shapes simliar to these:
http://upload.wikimedia.org/wikipedia/commons/1/19/After_dinner_mints.jpg
or if you rotate the rolled dough 90 degrees per cut you could get e triangular sharpe like these:
http://www.thesweetiestall.com/chocolate%20mints.JPG
I suspect that using scissors will enhance the look.
Suzanne in Orting, WA
http://answers.yahoo.com/question/index?qid=20080906001555AAfNYFT
haven't tried it yet but it appeals to me since we have about 20 Lbs of confectioners sugar left over from over ambitious holiday plans.
The problem is while caffeine is pretty harmless in its proper dosage, it can be pretty dangerous if you take too much. So my question is what would be the safest way to introduce caffeine powder? My worry is whether or not the caffeine gets distributed through the entire mix and each pill has the proper amount. It would be scary if it all ended up only spread out among four or five mints.
I used to make my one soda pop. I wanted to add caffeine. I was faced with the same dilemma of dosing small amounts. So I dissolved the caffeine in water. You can make the mixture however dilute you want and when it dissolves it is very evenly distributed. And since you dry the candy all that water will evaporate.
I was torn between making my mixture 10mg per 1ml or 10mg per 10ml. Well I mixed it at 10 to 1 but added it so my soda as if I mixed it 10 to 10. So I accidentally added 10 times what I meant to. What made matters worse is that I mixed the soda with alcohol and so didn't notice the effects until early the next morning when the alcohol had worn off but the caffeine was alive and well in my system. My heart was racing, my skin was crawling, and I couldn't sit still. I ended up going to the emergency room. I was in no real danger of dying and the doctors thought it was rather hilarious but it was terrifying. They gave me drugs to calm me down 24 hours later I was fine.
So go ahead and do this if you want, I don't mean to dissuade you. Just let me repeat, because it bears saying twice...
BE CAREFUL
If you buy bulk caffiene, like at purebulk dot com or amazon dot com, you should know that 1/8 th of a teaspoon equals 215 MG of caffeine, so don't eyeball it. Work the math to target 100 MG per mint, or whatever you want. Add the caffeine to the second batch.
Warning those who will eat them that eating more than 600 MG in one sitting will make them ill (more or less per person). Excessive amounts will make them dead. One Red Bull has 80 MG, in comparison.
Another easy option for this is to make Butter mints (the no cooking kind).
The Penguin Caffeinated Peppermints say they have as much caffine as a 12 ounce cola. Coke and Pepsi have about 35mg of caffine in a 12 ounce can.
You probably could do this with the gum base you buy as a paste and not a powder, but it would be more difficult to get an even distribution of caffine.
Let us know how it turns out. Just don't eat all of your homemade mints at once!
One thing I would caution is that the peppermint oil is some heavy duty stuff. I managed to drip a bit on a bamboo bowl and it removed the finish on that spot. (And I got myself into trouble with my habit of rubbing my eyes, but we won't go into *that* ridiculous story...)
awesome 'ible thanks a ton i am going to look this up again this week or next i think . ( lots of time home from work right now )
Is that a misspelling, meant to be "1 gram flavoring"? As in the gram, unit of mass? Or is it really a dram? I only ask because both amounts are small and not outside the realm of possibility. :)
1 Dram = 27.34375 Grains
1.771845 Grams
0.0625 Ounces
There are also troy drams should you wish to measure precious metals.
1 Dram (troy) = .1371429 Ounces
.125 Ounces (troy)
I know, way more than anyone wants to know, but hey that's the way my head works.
I guess it's one of those archaic units of measurement that persists due to one particular usage, like furlongs in horse-racing.
Thanks.
The fondant does dry hard if exposed to the air for a while and still tastes nice. It doesn't have quite the Altoid consistency but instead reminds me of the inside of a Charleston Chew bar. It snaps into pieces like one too. I might have to make some Charleston Chews with it for the candy contest.
BACON FLAVORED!?!?! **glitter** 8- D **fairies** **world peace**
And the best part is, it's dirt cheap and can be used in recipes.
http://www.bodybuilding.com/store/sf/caffeinepowder.html?MCID=F-GOOG-SF272
the amount contained in that bottle is equivalent to 877 16.9 ounce Redbull drinks.
which saves you about $3,000 of redbull purchases :D
And it won't include bull intestine.
Red Bull does contain something called taurine, which is an amino acid which occurs naturally in the human body. But rest assured, you're not drinking anything that came from an actual bull. :D
It was isolated first in bull bile so they named it with the Latin root. Biochemists don't name things like chemists do so their discoveries aren't named after the chemical structure.
And anyways, I don't drink red bull or the other energy drinks, it can't be healthy after a while.
This seems much more logical to me than them using bull intestines. That just makes no sense. However, you're welcome to believe whatever you like, regardless of how strange or incorrect it is.
Have a great night!
Hours!
Errr, no.
I remember the day of drinking 3 pots (as more than 3 liters) of German style drip coffee (has more caffeine per cup than espresso) in an afternoon. Was in preparation of an exam....
Suddenly the heart started racing, the hands started to shiver almost out of control, a general feeling of uneasiness - not nice. Just an intoxication. Nothing more, nothing less. After all, caffeine is a toxic substance, so take care, if you play with the pure stuff.
Just saying.
On the other hand, if I could find a source in Europe... ;-)
Phifft! It would give me more days being awake!
lol
Dram is in the apocathary system of measurement and is still actually used in medicine....for example..10 grain tylenol= 650 mg.....and 1/150th grain nitroglycerin is 0.4 mg!
=D i am a nurse btw =D
loved the Ible!
Gashlycrumbtiny
I love this idea of making your own mints! Great job as always smooch!
Make things out of altoids tins
Make Altoids...
The next logical steps would be:
Make an altoid tin maker
Make a home made Altoid tin :)
One more local source before hitting up Amazon: Try Beer and Whinemaking suppliers.
Thanks!
