Homemade Annoy-a-thing (Annoy-a-tron)
Step 2Nitty-gritty
nitty-gritty
the circuit diagram is shown below. hopefully it is readable.
if you've got a breadboard, lay one out first and make sure it all works!
AGH sorry! Revised schematic 4/4/09 (thanks dad)
8 comments
Jul 11, 2009. 8:47 AMUnit042 says:
I don't think the MOSFET is needed. Most versions of the 555 (made by different manufacturers) are able to handle bare minimum 50mA (100mA typical for mine).
Last I remember, t=r*c has time in seconds, resistance in ohms, and capacitance in farads....
Hey, wait, why is the diode on the threshold pin and not the discharge pin? Does your 555 have a different pinout from the LM555 or the (radioshack whatever)555?
This gives me an idea...
Jul 12, 2009. 5:54 PMUnit042 says:
It doesn't have to be mind-boggling. A cup of capuchino(sic) will help with some things in life.... Now, what is the diode doing, is it supposed to be delivering a voltage drop to the threshold/trigger pin? Or was it supposed to be on the output/discharge pin?
Apr 4, 2009. 9:22 AMTXTCLA55 says:
What does the Mosfet do? Are there any other components that could possibly replace it?
Jul 1, 2009. 2:50 PMraykholo says:
as you can see below, the mosfet is used to amplify the output signal from the 555 IC. transistors will do the same thing, im pretty sure u should look for an NPN one --> pretty cheap... the mosfet used here is not as common, but it is the same thing as the 2n7000 which u can find on digikey.... again, the answer the your question is that any NPN transistor should work as a replacement...
Mar 11, 2009. 9:25 AMsp33dstix says:
Hi there, In the circuit diagram what is the halfcircle thing with the + and - on it?
May 24, 2009. 6:22 PMFreeBaseBuzz says:
Are you talking about the electrolytic capacitor? to the right of the 10uF marking?
Mar 12, 2009. 4:38 PMjerrystearns says:
heheheheheh a battery
Mar 19, 2009. 10:40 AMSagar Gondaliya says:
dude. get ur symbols right.
Mar 16, 2009. 9:17 AMsp33dstix says:
I know which one was the battery, I was asking about the half circle. Never worked with piezo buzzers. Thanks
Apr 20, 2009. 8:53 PMtheangrytomato says:
So...I'm don't know much about electronics, as you will probably be able to tell in a second.
If t = r*c, then that would mean that this device beeps for a split second every (about) 16.5 minutes. Am I correct? Trying to make sure I actually understand this before I go out and build one.
What exactly is the diode going into pin 6 doing?
Last question - do you know if there is a way to randomize the length of time between beeps without using a microcontroller? Sorry for all the questions.
Apr 20, 2009. 9:53 PMtheangrytomato says:
Yeah...its not 16.5 minutes. Whoops. What am I doing wrong?
Mar 20, 2009. 1:27 AMThe Lightning Stalker says:
I believe the 2N7000 would work as well. It won't handle quite as much current though.
Mar 19, 2009. 10:39 AMSagar Gondaliya says:
(removed by author or community request)
Mar 19, 2009. 1:04 PMkscience says:
If you google mosfets you can learn what the 3 elements are. Pin 3 goes to the gate, not the drain or source. The schematic is clear if you know what components are.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:let_it_out_org
