Step 4Final thoughts
hopefully all has gone well and your annoy-a-thing works! this set up i've just layed out should last about a month.
as with all little projects like this, a magnet can be added to the bottom. this will, however, add thickness, so i prefer using double sided sticky tape.
one of the things think-geek's annoy-a-tron has that this one lacks is a different length of time between beeps. this particular "annoy-a-thing" will beep about once a minute (+/- a few seconds depending on battery life).
ALSO: note that you can change the time between beeps by changing the value of the 10M ohm resistor. if i'm not mistaken, i believe a value of 20M ohm will make it 2 minutes, 30M ohm is 3, so on. (you wouldn't want to go too crazy and make it 10 minutes or something, i don't think that would work. but hey, nothing stopping you from trying!)
your comments are appreciated!
comments
Add Comment
Add Comment
