Homemade Band
351
Posted in PlayInstruments
Introduction: Homemade Band
This is an homade banjo
Step 1: Step 1a. Getting the Wood
Aquire a 70cm piece of wood, preferably 2-3cm thick, and 6-7cm wide. Get 4 pegged screws and screw them in 1cm lower from the highest leavings some of the screw sticking out. Add a fret holder out of any extra wood that you find. (Just cut 4 indents in it.) Your wood is now ready
Step 2: Step 2. Preparing the Tin
For the tin all you need to do is get a can opener and run it along the edge enough so the wood would fit through. Get a chisel or other sharp object then just cut it all out.
Step 3: Step 3. Fitting the Banjo
When you have the wood and the tin ready. Insert the wood into the tin and screw it down so it stays. Add 4 screws at the very bottom of the banjo. Add another fret on the cookie tin. After all of this then you are able to string the banjo with strings.
Step 4: Step 1a. Gathering Materials
8 5-6 inch long pvc pipes
5 elbows
Blue tape (or any color)
2 funnels for the horns
Step 5: Step 2: Piecing the Tubes and Elbows
Start by taking 6 pieces of tube and building them into a field goal kind of shape then use the elbows to fix them together
Step 6: Step 3: Attach the Horns
Fix the horns on the two prong type ends of the pipes and wrap tape around them for added support
Step 7: Step 4: Mouthpiece Pipe and Elbow
Add the last
Step 8:
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
