Homemade Bandage
Introduction: Homemade Bandage
Need a bandage and you don't have anymore? Make this homemade bandage from things around the house!
Step 1: You'll Need....
What you'll need to make this bandage is tissues, tape, and a marker.
Step 2: Time to Make It!
Fold Tissus until a bit bigger than wound.
Step 3: Time for Marker! Part 1
Hold tissuse down while drawing whatever you like on what you want to be the front of the bandage.
Step 4: Time for Tape! Part 1
Cut a little piece of tape & put it on the 1 end on the middle of the side. Do this 3 more times on the other sides. When your done you will have a little pad of tissuse on the back middle
Step 5: Time for Marker! Part 2
On the back of your bandage. Draw a line right by the tape ( the side closest to middle.) you will get some marker on the tape. ( Don't worry, you're supposed to do that.)
Step 6: Time for Tape! Part 2
Now cut a little piece of tape fold it so it's like a piece of double sided tape ( it will be sticky on both sides ) put tape on the edges diagonally. Do the same thing on the other 3 sides.
Step 7: How to Put It On
Put on so others can see what you drew. Make sure on the back that the pad is on your wound.
Step 8: Enjoy!
Now you've made your homemade bandage! Enjoy everyone!
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Non-stick dressings are best for a wet wound, but protecting a sealed, healing wound is still important. I prefer Viva table napkins and cloth tape as a soft pad to protect from re-injury.
    Infection? Pfft. Germs build the immune system.
    I really wouldn't recommend this.
    If you put tissue paper on an open wound the tissue paper will get stuck in the wound causing a route for infection.
    When you come to remove the tissue it will pull the scab off reopening the wound and/or leave bits of tissue paper in the wound.
    neat thanks for sharing
