I'm a computer programmer and this is the first time I've done anything like this. I made it happen, so I think anybody armed with minimal carpentry skills and these simple instructions could get as good of results!
Finally, if you're looking for similar wood ideas, check out this site. I'm not affiliated with, nor have I even done business these guys (yet). I just find the projects are quite inspiring!
UPDATE: Looks like I didn't win anything. :_(
Oh well, many thanks to everyone who voted!
Also I should add that these doors have survived the winter well, including several heavy wind storms. It appears that the design is sound and should last for quite some time. (Unlike my shed roof which, well... lets just say there's never a dull moment around here.)
Remove these ads by
Signing UpStep 1The Boring Backstory
Having heard the horror stories of the limb-rending power of garage door springs I opted to shelve my DIY nature and hire a guy to come out for this one. The dude looks it over and says, "I could probably fix that if you really want me to, but these kind of doors are such junk that the manufacturer has gone out of business". Spiffy.
I had him rip them out, but that left me with gaping holes in my house in the middle of winter. Uh oh. Now what?
As you know "hind site is...." and like you, I have learned from many mistake in the past so not to dis your work I have a couple of suggestions for anyone considering building there own.
Toward the end you show the post sitting directly on the concrete. A sign your concerned about it too. At your typical box hardware store you can purchase a 1in. square galvanized post base.
Like this: http://www.lowes.com/pd_108719-72913-ABA44Z_0__?productId=3006427&Ntt=simpson+strong+tie+post+base&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dsimpson%2Bstrong%2Btie%2Bpost%2Bbase&facetInfo=
Cut off the post short and slide the block underneath. The reason is the lumber will absorb water from the concrete and the wood will rot. Using Pressure treated lumber would help in this regard but it is still not the best.
Next, even though the door frame doesn't touch the ground "now" they may sag in the future. It looks like you used Douglas Fir or Pine (just a guess) in the frame neither of which is particularly resistant to water damage. It maybe wise to make the frame a little shorter by maybe an inch or even two and let the clapboards fill the gap. That way if the door sags you can trim the clapboard without reducing the strength of the frame and still clear the ground. That keeps the frame clear of water and away from critters.
Many years ago much if not most of the lumber was kiln dried and therefore it shrank very little over time. Today most wood unless specifically purchased as such is not dried. I purchased 8" dog eared redwood fencing, then it was very close to 8" but today it it's more like 7 1/2" to 7 5/8" and redwood normally shrinks from end to end(dimensionally) rather than side to side. Most other woods shrink from side to side more than end to end.
What is the point? I would butt the clapboards together rather than leave a gap or at the most I would leave a nails width between the boards. When the boards shrink the gap will still be covered.
By the way I grew up in and around the mountains and I really took to heart the outline where you mentioned why you move to the area!! Great work!!
Two things come to mind; the use of CCA or "Yella Wood" for the 4x4's would eliminate the need for tar, and the use of safety cable inside garage door springs GREATLY reduces the danger of them injuring anyone (or just replace them every 20 years or so...they don't fail that often).
A little chilly in the winter, but even so I'm enjoying it more than smog and suburbia. :)
where do I vote ?…
Alternatively, it's on the contest page as well.
http://www.instructables.com/contest/shopbot/?show=ENTRIES&sort=RECENT
Thanks for the vote!!!
I want to actually build a gate for my deck and your doors are helping me think about my gate. Thanks.
I hope you win!
