Homemade Cheap R/C Boat From Things You Can Find at Home
377
4
Posted in TechnologyRemote-control
Introduction: Homemade Cheap R/C Boat From Things You Can Find at Home
In this instructable, i'll show you how I made this cheap and easy to build R/C boat. For you to make it, you'll need only and old/broken rc toy that has two motors and some things you can find at any handcraft shop.
Step 1: Materials
For this project, you'll need:
- An old control board (for two motors) from a R/C toy
- Two straws
- Two straight thick wires
- Two small rubber tubes (Needs to fit toughly in the motors' shafts and on the wires!)
- Two propellers (Needs to fit toughly in the wires' s ends!)
- One battery (Of the aproppriate voltage of the system!)
- Two motors (Aproppriate voltage of the system!)
-Styrofoam plate (Thick)
Step 2: Straws Inserted
Insert two straws in the styrofoam plate. One on each side, at a angle of about 45° , at the back of the styrofoam plate.
Step 3: Motors and Shafts
Glue the motors in a way that their shafts are both alligned with the straws. Then, put the rubber tubes on the motors' shafts. Insert the wires on the rubber tubes and finally, place the props at the end of the two wires.
Step 4: Soldering
Here comes the dangerous part: Soldering. Be careful to not burn youself!!!
Solder the motor wires and the battery wires to the control board appropriatly.
Step 5: Mounting Electronics
Place the electronics in the styrofoam plate (hot glue recommended).
Step 6: And It's Done!
Now turn on the transmitter and put the boat in the water! Have fun with your cheap and simple homemade R/C Boat!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
