Homemade Chuck Spindle Collet ER11 DIY Press Drill Tools Drills Milling Router Mill PCB CNC Slide
Published
Introduction: Homemade Chuck Spindle Collet ER11 DIY Press Drill Tools Drills Milling Router Mill PCB CNC Slide
Materials:
1 pcs motor 50 watt take from old hand drill
1 pcs aluminium alloy tube 45 mm x 10 mm 19 mm hole
1 pcs aluminium alloy tube 45 mm x 80 mm 25 mm hole
1 pcs 25 mm 220 mm linear shaft Cylinder Liner Rail Linear Shaft axis cnc parts
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler Encoders Engraving
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    Video links are broken. This indestructible is also too vague.
