Homemade Coffee Burr Grinder
 by spike3579
Featured
This project was inspired by jeffkobi's Coffee Burr Grinder Attachment for KitchenAid Mixer.  I was perusing past contests and discovered his winning entry in the coffee contest.  I loved it.
The power take off on the Kitchenaid mixer is definitely an underutilized resource and his use of it was inspired.  I decided to make my own version of the same concept...well...because I wanted to.
 Let's proceed shall we?
Step 1: Stuff to get it done
I used the head of an angle grinder to transfer power from the mixer to the coffee grinder.  My coffee grinder was hiding as a peppermill right under my nose!  Some copper sheet did the job of connecting the grinder head to the coffee mill.
Chinasaur says: May 20, 2012. 2:23 PM
Hey, I started a Google Group to try to get people together to share some notes on DIY Kitchenaid attachments. Seems like there are a handful of people playing with this now (mostly thanks to jeffkobi's winning Instructable).
https://groups.google.com/forum/?fromgroups#!forum/kitchenaid-diy
spike3579 (author) in reply to ChinasaurMay 21, 2012. 3:31 AM
Great, I'll check it out.
rimar2000 says: Apr 11, 2012. 5:12 AM
Both you and me had the same idea: http://www.instructables.com/id/Grinder2grater-de-amoladora-a-rallador/
But your work is more careful, neat.
spike3579 (author) in reply to rimar2000Apr 11, 2012. 6:04 AM
I love your grater Osvaldo. Very ingenious.
I bet we would come up with some interesting inventions if we lived closer together.
I have to admit I'd been hanging onto that broken grinder for a few years because it seemed like it would be useful for something.
Any ideas for broken paper shredders? I have three of them :)
rimar2000 in reply to spike3579Apr 12, 2012. 6:48 AM
My grater has some shortcomings:
  1. I should have used the head in the opposite direction, because as it is I have to turn the handle very quickly.
  2. Many cheese flakes fall outside the container, it is easier to solve and I will finish as some other more pressing projects.
spike3579 (author) in reply to rimar2000Apr 12, 2012. 7:41 AM
I noticed how much the motor speed of the grinder is geared down compared to the output of the disk. Guess they need the extra torque. Since the disk max is 10,000 rpms I wonder how fast the motor is turning? (rhetorical, I'm sure I could look it up...)
Sorry about your hand. Power tool accidents happen so fast they are usually over before you can react to them. I'm very paranoid about damaging my eyes and ears. I rarely keep the guards on grinders. I may have to reconsider that.
We still get to see the chulengo on Sat right?
Yum... Barbecue
rimar2000 in reply to spike3579Apr 13, 2012. 8:10 AM
Yes, on Sat, but not next Sat ;)
My hand is healing, but I can't do certain movements because it hurts.
Thanks for your concern, and put the disc cover to your grinder, soon! "Don't be stupid as me"
The Green Gentleman says: Apr 12, 2012. 6:41 AM
I like the design very much. The pepper mill burr grinder seems pretty apt for the job.
I have one caveat: consider using a pipe section made out of something other than brass. Brass looks awesome, and is esthetically an important part of your project, but brass is frequently - almost always - made with a small percentage of lead as part of the mix. This allows the alloy to deal with harsh or corrosive environments, but the lead can and does leach out of the metal. Heat exacerbates this, which is why it is a bad idea to drink hot water out of the tap. Using brass in a hand turned peppermill is potentially okay, but when you add speed, you add heat, and your coffee may end up with significant amounts of lead.
I apologize for being a buzzkill.  This really is a very cool and clever project.
spike3579 (author) in reply to The Green GentlemanApr 12, 2012. 7:27 AM
That's a good point. It seems like there are always unintended consequences to everything we do aren't there?
The actual grinding mechanism is steel. The grounds are not warm to the touch as they emerge from the grinder. In addition, the grounds are sitting in the lower chamber for maybe a minute. Not much time for any lead leaching to occur I think.
If lead leaching still seems like a concern the lower chamber could be removed and the grounds could fall right into a filter cone directly from the burr grinding mechanism.
The Green Gentleman in reply to spike3579Apr 13, 2012. 7:26 AM
Also a good point!
Mostly, I'm just bummed that brass so frequently incorporates toxic metals like lead and antimony in it. It's one of those things where I just go "huh?" We took it out of our gas because it was toxic, took it out of solder because it was toxic, but leave it in our plumbing, food processors, keys, espresso machines, jar lids and door knobs because it's pretty?
Anyway, once again, this is a cool build!
Naomii says: Apr 11, 2012. 9:17 PM
Nice! I have to try building one when I have time. I have a few electric grinders, but it's cool to do it the old fashioned way too. I usually check up on Coffee Grinder Reviews to see their grinders, but most of those are electric.
spike3579 (author) in reply to NaomiiApr 12, 2012. 7:46 AM
I think you are just linking your niche site up here but if you do make a grinder post some photos.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
