loading
Step 5: Step 5: Line up the dividers in the box
Now what you will need to do is line up the dividers in your box in order. First you set in the quarter slot then tape it in. Next goes nickel then penny then dime. Remember they go in order of size biggest to smallest not by money value. Try to space them as evenly as possible.
<p>I remember I made this a couple years ago before I had an Instructables account. Now I can't find it <strong>:(</strong></p>
<p>(Except I made mine oput of placstic)</p>
It seems appropriate on so many different levels that separating loose change is being done in a box emblazoned with the name of a member of the Rothschild banking dynasty. <br> <br>It's a practical tool, social commentary and parable all rolled up in one. <br> <br>(I imagine the lightweight dividers might be a bit flimsy for larger fistfuls of change. Perhaps some thin plywood or balsa with holes drilled and then glued into place would do the trick there.)
This is neat! You could use that extra space for the dollar coins or the 50 cent pieces! You don't see them as often anymore, but they do pop up now and then :) <br /> <br />It is nice to have coins organized. I hate digging through my coin jar trying to find the quarters :)
After building this I noticed you don't need 4 dividers, you only need 3 (Nickels, pennies and dimes). The quarter divider is redundant because the quarters won't fit through the nickel divider anyway. You're just going to be left with an empty space. <br> <br>I guess the empty space could be useful for pouring in new coins if you're going to keep them inside the box. But if you do this eventually the cardboard will snap from the weight of all the coins in the box.
About This Instructable
35,443views
10favorites
License:
More by globogym: 6 Pack Coaster Homemade Coin Sorter
Add instructable to:
