3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Cutaway Guitar - Of an existing one!
These are instructions how to make a homemade cutaway guitar of an existing one.
CAUTION: Not for beginners!
You must be able to handle with wood etc.
Get a guitar
http://www.ebay.com
http://www.ricardo.ch
A Guitar
http://en.wikipedia.org/wiki/Guitar
General documentation
Acoustics for violin and guitar makers
http://www.speech.kth.se/music/acviguit4/
Step 1What you need
What you need
Ok, here is what you need:
1 existing Guitar. (cheap one!)
1 Hotair gun
1 Saw (here japanese)
1 thin small saw (here a automatic). Needed for make small radius cuts. [german: Um sehr enge radien zu sägen.]
1 glue
1 paring chisel (small one, here 6mm) [german: Stechbeitel]
+ Lot of patient and time ;-)
25 comments
Oct 4, 2010. 6:20 PMsartor says:
This mod will dampen your guitar's resonance and tone! That wood is there for a reason.
A test to see how much the soundboard's resonance affects the sound of a guitar: put a guitar on your lap and strum the open strings. Listen to the vibration, sustain, overtones, etc. Now press your other palm down on the soundboard (not too hard, as you don't want to damage it) and strum again. Hear the difference? Try this with the sides and back, too.
If you MUST have a cutaway (do flat-top guitars sound good that high up anyway?), consider a Maccaferi-style that's not too invasive:
http://upload.wikimedia.org/wikipedia/commons/7/7c/Guitares_type_Selmer_Maccaferri.jpg
Aug 3, 2010. 12:57 PMlooperted says:
Thats the same guitar i have if its an alvarez! =P
Oct 16, 2007. 10:45 AMWario says:
I personally would not do this, it would deminish the value of the instrument. Besides, i don't notice a diffrence between the two types of guitar. Other then that a brilliant instructible.
Oct 22, 2007. 1:59 PMRamnosity says:
You said you did't notice a difference. I cutaway lets you get down to those really high strings. Mostly seen on electrics or electric-acoustics
Jul 6, 2008. 3:06 PMWario says:
im actually used to reaching over the noncut region of the guitar.
Oct 12, 2008. 10:46 AMdownhilldman says:
me too
Jan 22, 2008. 2:12 PMWario says:
Oh yeah, i forgot
May 20, 2008. 1:10 PMsendez says:
oh my god...poor guitar....
Mar 10, 2007. 4:57 PMmrmath says:
I'd be willing to bet that this would be a much better instructable in your native German. You speak far better English than I do German, by the way. I just mean to point out that there is no rule (that I know of) that says you have to post in English. A suggestion for the project. Perhaps a peice of string taped to the guitar to mimic its original outline would help in making the cut out the same length so when you bend the wood, it's the right length.
Jan 29, 2008. 3:26 AMjimmyhavok says:
Good idea with the string...but a piece of flat plastic strap would work even better, and give you a smooth curve. Mark the end points of the cutaway, measure the strap against them, then bend it on the top of the guitar between the end points until you get a nice looking shape.
Dec 10, 2007. 1:45 PMsploge says:
this is cool but apart from looks why would you do it I know that a cut away is so that you can play high notes on the fret board but on a Spanish guitar the don't sound good I recommend buying a guitar with a cut out first of
Jul 18, 2007. 9:40 PMguitarman63mm says:
wow, you really screwed up with the back edges! you should have sanded it down first, so they were smooth then used your wood, then filled, the sanded, and i would have added tung oil. maybe that's a bit too much work though?
Mar 10, 2007. 9:16 PMLasVegas says:
How severely did this effect the acoustics of the guitar? I'm assuming, being a very inexpensive guitar, it didn't have much quality to start with...
Mar 11, 2007. 9:52 PMtrebuchet03 says:
Strings are going to play a large role in tone etc. Similarly, reeds will do the same for woodwinds. Etc. etc. But the nice little resonant nodes that come from a great design make an instrument valuable.
Instrument materials, shape, construction will play a huge role in resonance (as you probably know). Sure, you can get decent sound out of almost anything by being a good player and using quality (not necessarily expensive) consumables. But comparing the same consumables on two different designs can show a big difference, if you know what to listen for :P But don't get me wrong, I spent a decent amount of money on a euphonium mouthpiece :P
Kinda like speakers.... Pay hundreds for the driver speaker... and a few dollars on an enclosure -- and you're not going to get as great a sound out of it. The Bose wave thingamabober is all enclosure (instrument), less driver (strings) - for example.
Nice instrucable though :)
Apr 19, 2007. 10:35 PMbinnie says:
you can have cheap speakers but a well built enclosure and the speakers will sound alot better than they realy are
Apr 19, 2007. 11:08 PMtrebuchet03 says:
Yep, that was my point :)
Mar 11, 2007. 8:09 PMcpotoso says:
Come on michi, if this was the case there would be no difference between a Guarnerius violin and a "el-cheapo" one... The box does have an effect!
Mar 11, 2007. 11:41 AMmrmath says:
I don't know much about acoustics, but I do know that the shape and structure of the guitar has A LOT to do with acoustics. Then again, I don't know if I would hear the difference.
Sep 26, 2007. 11:11 AMSynthezoid says:
I'm sorry to criticize, but I have a degree in acoustics (and have also been a guitarist for 22 years), and I can tell you that you are completely wrong in your thinking. The tone of a guitar is produced by the properties of the internal air volume of the body as well as the construction qualities of the box. People think sound production in a guitar or piano is simply a matter of a vibrating string being amplified; this is not how it works. The string provides the initial "push" but much of the sound comes from resonances arising out of a complicated mass/spring-type problem involving the mass of air in the body cavity, as well as that of the bracing, the back, and neck, and is strongly dependent on that cavity's shape and the guitar body's construction. Your statement #1 about the $9000 guitar with bad strings versus the $90 guitar with good strings is not just untrue, it is factually impossible because of the differentces in construction.
Strings and connection points affect volume, partials and sustain greatly, but not so much the overall tone (at least, as long as you're not comparing strings with two completely different vibrational properties, like nylon vs. steel and wound vs. unwound or roundwound vs. flatwound.) I use the exact same set of D'Addario medium strings on my old beater Epiphone and my beautiful tobacco sunburst Simon & Patrick dreadnaught, but both guitars have a *completely* different tone from each other, owing to their different construction.
A lot of this can be found right in the "part 6" pdf on the acoustics page you linked to above (http://www.speech.kth.se/music/acviguit4/). (See in particular where it talks about how important the back and neck of the guitar can be to the resonances that shape the tone.)
Generally speaking, the smaller "bulb" of the guitar's body (near the neck) produces a high-frequenecy resonant peak, and the bigger bulb produces a lower peak. Together these produce a full sound. (This is why you rarely see "teardrop" shaped guitars, like an "A-style" mandolin.) Change the volume of one part of the cavity and you change the mass of the air that occupies the body, which shifts the resonant peaks and changes the tone. Ditto for removing mass or changing the shape of the front or back. Even the mass of the guitar's neck makes a difference. (See the PDF again. Or, if you want to try an expensive experiment sometime, stick a Stratocaster neck on a vintage Les Paul and see what it comes out sounding like.)
The reason cutaway guitars are more expensive than non-cutaway guitars is because of the extra work required to compensate for the acoustical losses of changing the body cavity volume and the area of the top, the necessary extra load-bearing bracing for the neck, etc. True, the losses may not be that huge to untrained people's ears, but they are there, and in a fine guitar it can create a noticeable difference.
These are not my opinion, they're simply the scientific facts of how sound production works in a guitar.
If your guitar sounds the same to you after doing this mod, I'd argue you probably have either a pretty cheapo guitar or a fairly untrained ear. Nothing wrong with that, except that it's incorrect to say on the basis of it that this won't change your guitar's tone.
The upshot is - thanks for this instructable, it's great (and a bold move!) but people should be warned not to do this to an instrument they care about, because the results will be unpredictable. Real cutaways are designed much more carefully than this, they're not just a regular guitar with a chunk taken out..
Apr 1, 2010. 8:35 PMRC-Roi92 says:
Where does one acquire a degree in acoustics? That sounds like an awesome field of work :D
Jul 3, 2008. 9:13 AMinfoplus007 says:
The basic idea is very good, ans Iwill try it on one of my cheap guitar ( classical Spanish), Sure the tone will "move" but if you think twice when the guitar is open you can take à look at the "brassing" of the guitar and make it better, to add some high frequency. For the low end cutaway under $500.00US, they don't redesign al the guitar simply adjust the bracing and add/remove the cutaway. Over 800.00US now the guitar plan take in account that's will be a cutaway guitar. That's my point of view. Great Idea on cheap guitar but not for my Takamine ;-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:michi
