3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade DIY Aquarium Filter
video Homemade DIY Aquarium Filter
This is a very efficient homemade filter. It has mechanical, biological and chemical filtration all in one. Pump will be needed. Maximum time to make(If you have all materials): 15 minutes. THIS VID BELONGS TO QUAQA88 OF YOUTUBE
18 comments
Dec 22, 2011. 11:04 PMHiggs Boson says:
Does the pump ever clog up with debris?
Nov 12, 2011. 8:21 AMdjvanbeat says:
MUUUy bueno Paco!!
good job , i think you need change de plastic tube pieces for ceramic pieces or balls of ceramic ,filter better but your idea is simply and great and dont need spend too money fork give a good life for we little friends the fish :)
Jan 2, 2011. 5:35 AMthisthatandwhatever says:
Good Job! Great Project! Especially if you are on a tight budget! Your fishies must love this! Make something else!!!!
Sep 14, 2010. 9:32 PMRag-Tag says:
I'm sorry, but using Gravel as a bacterial growth medium just won't work. Sure if you want to use an UG filter with Gravel as a growth medium then yeah, sure that will work, providing you have about 3 and a half inches of gravel or so on top of a good under-gravel plate like a Lee's or something similar. There just isn't enough surface area contained within the bendy straws and gravel.
The second issue I see here is the volume of water your filter has to pull through itself. A reliable filter has to be able to cycle all of the water in the tank between 8 and 10 times an hour.
This filter is a very novel idea, don't get me wrong, the idea is running in the right direction, but its not quite there yet.
If I can make one suggestion that would make this work so much better. Instead of using gravel in the filter, use Bio-max or something similar. An unfinished ceramic is no more expensive than aquarium gravel, and it is far more porous. The pores become a breeding ground for bacteria, and would increase the biological effectiveness of this filtration method by about 30% compared to gravel. The only problem here is that Bio-max has a tendency to go septic after about 6 months (All the dead bacteria clog the pores and suddenly its no more effective than the gravel you're using right here).
If you used a larger bottle, a 2L or something similar, you could utilize actual sponge as opposed to a filter pad (Again, more surface area, and easier to keep clean than cotton padding) then a layer of Bio-max or other untreated ceramic, a layer of Bio-balls or something similar (anything with a lot of surface area will do) followed by active carbon, peat moss granules, or other chemical filtration media (I like clearmax a lot) You could even run airline tubing from an airpump with a difuser into the top of the filter to increase aeration to keep temperatures down in cold-water tanks
I don't mean to come of as disparaging, just trying to spread the fishkeeping-love!
(P.S Your Tetra's look nice, consider adding some Blackwater extracts to your tank or Peat-moss to your filter to reaaaaaaally see their colours pop)
Jul 21, 2010. 6:24 AMxenobiologista says:
Can someone explain why the pieces of plastic straw are so much better for bacteria to grow in than the other surfaces that they would cause "your ammonia to shoot all the way down"? Don't the gravel and the filter mesh have more surface area?
Jul 20, 2010. 4:04 PMxxInSAniACxx says:
DUDE, you have the same fish tank, filter and light set up as me!!!
Jan 19, 2009. 2:24 AMhandysmurf says:
OK so the only reason to really ever change a filter is for fresh "physical" filter? Do you ever have to replace the carbon and how often? and on the carbon note ... why not just put it in the foot of a pair of panty hose and throw it right in the top? (cutting the excess off of course)
Jul 31, 2009. 9:58 PMiwade4fish says:
you clean a filter to rid it of debris, which can block or impede water flow which, reduces the filters efficiency. Carbon does add a lot of surface area for the beneficial bacteria to grow on however, it nuetralizes most aquatic medication and therefore should be used accordingly.
Mar 9, 2009. 8:15 AMswaman says:
Not my thread, but FYI, carbon efficiency is rapidly depleted, and shortly after it is installed it does nothing to improve water quality, therefore being a waste of your hard earned money.
Generally speaking, the biological filter within the substrate of your aquarium provide all the chemical "cleansing" you need, while the mechanical filter (that fibrous filter media) removes solids.
This comes from twenty years in the aquarium hobby, both fresh and salt water, and can also be substantiated by pros at http://www.aquariumadvice.com
This is a great article, but you DO want to be careful placing metals (the staple) into your aquarium.
Thanks and good luck!
Remember:FISH ARE PEOPLE TOO!
Swa
May 3, 2010. 2:03 PMnigel da nautilus says:
actually theyre fish, fish=fish
person=people
Mar 2, 2011. 1:58 PMclewynsky says:
a fish can be a person
I think you are confusing the term person with human
Jun 19, 2011. 12:48 PMnigel da nautilus says:
curses, i bow to your superior logic
Jun 14, 2009. 9:54 AMbassmonkey says:
could you use a gravel siphon metod, and not use a pump? (what I'm saying is could you suck on/activate a=the tubing and use it ?)
Mar 11, 2009. 1:52 PMchaffburner says:
Thank you for this instructable video. This really simplifies it for me.
Jan 8, 2009. 6:20 AMSAAbel says:
Great job! Can you explain why this wonderful system is not suitable for a primary filter? My 11 year old son wants to keep frogs from his science fair project and I told him "no" because of the cost, thinking primarily of the water filter (not to mention the delightful diet we'd have to keep on hand!). Thanks.
Dec 25, 2008. 7:31 AMbooyaababe says:
Awesome!... I just set up a small QT tank and dont want to spend 15 dollars or upward on a filter so..im elated that i found your video!.. I'm going to make one of these when i get back from the Christmas hubbub bub!...thanks!
Dec 3, 2008. 7:54 AMgloflyer says:
A very good idea! And also very good for the tank and fish.
Dec 2, 2008. 7:30 PMthixotropic says:
Fantastic. Great idea and choice of materials and execution. You have to make some more things!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:x_xPacox_x
idk you tell me
