Homemade Deodorant/Antiperspirant
36,357
91
44
Posted in HomeBeauty
Introduction: Homemade Deodorant/Antiperspirant
About: Aspiring product/package designer trying to improve her band. She loves to play the drums but wishes she had better recording equipment... oh, and more cowbell.
Today, I'm going to show you how to make your own deodorant/antiperspirant with household items.
Cred to scoochmaroo for inspiring me to create my own recipe.
Step 1: Ingredients
Ingredients;
Baking Soda
Talcum/Baby Powder
Rubbing Alcohol
Vicks/Menthol Paste
Materials;
A small air tight jar
Step 2: Combining
Put the baking soda and the talcum powder in the jar first, then the rubbing alcohol, then the Vicks.
Use approx 3 parts baking soda, 1 part talcum powder, 2 parts alcohol, and 2 parts Vicks.
(Perhaps add a little bit more alcohol than Vicks though)
*Thanks ERCCRE123 for helping clear up the ratios.
Step 3: Mix
Close the lid then shake vigorously until completely mixed.
Step 4: Finished
If you have an extra tube for deodorant and you make your paste extra thick then pack it into one of those. If not then keep it in the jar and apply with your finger.
Keep rubbing it in until there is no more baking soda residue.
I find this lasts for approx 12 hours.
Hope you like my Instructable.
Constructive criticism is appreciated.
    • Make it Move Contest
    • Spotless Contest
      Spotless Contest
    • Woodworking Contest
      Woodworking Contest
    44 Comments
    is the Vicks used to bind it all together, for the aroma, both? Neither? Just curious.
    It burns, figuring rubbing alcohol and possibly vicks. But I smelled good, but won't be trying again. Bummed about that.
    question does it sorta smell pleasant? alsowouldnt it be hard to mix the vick together with the other ingredients
    it smells quite good (in my opinion)
    and it isn't too hard to mix the Vicks in.
    Couldn't you also mix this with your favorite cologne/purfume for the desired scent?
    Absolutely, I just personally don't wear perfume or cologne
    True, but other people might, since most commercial deoderant is scented.
    The only problem I forsee with mixing cologne with a deodorant... have you ever smelled that one hopeless human who uses NO deodorant but TONS of cologne? It's bad, Sooooo bad. I believe the commercial deodorants are chemically balanced with their 'smelly good' whereas this method is strictly home made. Might work with some types...
    I wish to hell it was only one human.
    We could all chip in and send him to an island paradise somewhere downwind.
    Well hopefully this prevents smell. So you wouldn't need to add scent, just spray it on yourself like normal. Though the menthol smell may add an odd combo.
    You don't need to use the menthol but I find it works better for smell masking and for a sweat barrier because it keeps the baby powder in for longer and makes it a better consistency especially if you wanted to put it into an old deodorant container.
    why Vicks/Menthol Paste??? can you sub something else instead? outher then that great idea!!!
    You could use straight Pure Glycerin . .
    that should bind everything together that and a little heat. .
    if you do heat up the mix in deep dry pot on the stove be aware (as someone mentioned to me they did not know) heating baking soda too high will change it into oxygen stain fighting powder. ( would kinda burn the pits..)
    one other alternative. . crushed kosher salt . . or no iodine salt, , maybe dissolve into a super saturated solution , , then add your Zinc based or lavender scented powder mint oil? vanilla , favorite cologne or whatever.
    the salt will deter bacteria growth as with natural salt stone deodorants.
    theres is also a foaming hand wash that many dollar stores have its alcohol free and marketed as ALCOHOL FREE HAND SANITIZER by many brands the main ingredient is Benzalkonium Chloride .. a great alternative..
    one more. . another powerful anti bacterial inhibitor / destroyer that goes very very far, is Chlorhexidine Gluconate
    if you ve been to a hospital or clinic lately most use this in their soap, dentist pack in your root canals and later it converts to calcium, a few drops can go a long way.
    i only mention in case some has some extreme allergies and need alternatives good luck to all. .
    maybe eventually there could be a " ible " brand of sundries and household items.
    It would probably be just fine without the vicks in it, it just might be a little bit more watery. Though it would lack the cool soothing sensation of the Vicks and maybe it might not work as well??( I'm not sure about the not working part.) you could probably make a smaller amount and see if it works for you.
    or you could use petroleum jelly as kaypgirl said
    I don't think the Vicks does anything to make it work better, except for the consistency (at least it would still work w/o using it).
    The baking soda and the rubbing alcohol kill the smell. I've only heard about just using rubbing alcohol, but I just mix a thin paste of water and a little baking soda (you should be able to do this in your hand) and apply. It works great for me, lasts at least 24 hrs, though I'm not a sweaty person.
    The baby powder is for the sweat, obviously since that is what it does in diapers (and the obviously is for myself, I've never given much thought to what it does).
    I've been meaning to get some cornstarch and see how that works with the same method to control wetness, maybe I'll just see if I can find some baby powder.
    Vicks has a similar consistency to plain petroleum jelly (or is a smelly version?) so petroleum jelly would probably be an okay substitute. But if you want to use less chemicals it seems rather unnecessary.
    I find that the Vicks works well to keep the baby powder and the rest of it all on for longer and of course as you said it makes it a better consistency for using. I also find that by using just plain old rubbing alcohol it doesn't last as long because it wears off after a while. Some petroleum jelly seems to be very watery these days so i don't know if it would be the best sub but the Vaseline ( not in the tube) is thick and that works just fine but id rather smell like Vicks than like a baby's butt although we might have already achieved that with the baby powder. Essential oils work well added into this formula, such as tea tree oil, seeing as that is already used in many deodorants because of its antibacterial properties and smelly goodness.
    you can use palm kernel or coconut oil for an oil, beeswax if it gets too runny.. then instead of talc you can also use either corn starch or kaolin clay (equal parts to the baking soda). Also for fragrance, and germ killing you can use essential oils.. Maybe lavender or tea tree.
    Great Idea... too bad I don't have any of those things, but if you do then try it out and post back your results!
