loading
Step 1: Tortilla Chips
Tortilla chips are simple to make, whether you plan on converting them to Doritos or not.  For your tortilla chips you will need:
  • Soft corn tortillas
  • an oil with a light flavor, like sunflower, soybean, canola, etc.
Using a pastry brush, spread a thin layer of oil on both sides of 1 tortilla. Lie flat on cutting board, and stack on another, brushing oil on the top. Repeat until you have a substantial pile.
Take a sharp knife, and cut your pile of tortillas into even sixths. Lay out on an oiled baking sheet. It doesn't matter if your triangles are touching, but try to not have any overlap.
Bake at 350 until they start to lightly brown, approximately 10 minutes. Be sure to watch carefully so they don't burn.
If you're not in the mood for Doritos anymore, salt lightly and enjoy with salsa.
Looks yummy, but I'm afraid Hidden Valley ranch mix is full of MSG, and that gives me a smoking headache. Any alernatives?<br>I will try the chips recipe, as I can eat them without the ranch mix.
I agree with you, silvertank; I stay away from MSG, not for headache reasons, but because it's a chemical. I have just read this recipe and have not yet tried it, but I actually have a packet of Simply Organic Ranch Dressing mix in my pantry which is what I will use. You should be able to find it in most grocery stores (organic section).
MSG is a chemical, as most things are. I presume you mean it's &quot;man made&quot; but it's actually a naturally occurring non-essential amino acid commercially produced from fermentation with yeasts or bacteria.<br>In addition, MSG has never, in scientific tests versus anecdotal evidence, been found to cause any adverse effects in humans, even in &quot;MSG intolerant&quot; people. <br>I would worry more about the salt (5% sodium) and the 200 calories in a 40g bag.<br>ref: <br>http://en.wikipedia.org/wiki/Monosodium_glutamate<br>http://www.weightlossresources.co.uk/calories-in-food/snacks/Tangy-Cheese-Doritos.htm<br>http://caloriecount.about.com/calories-doritos-toasted-corn-tortilla-chips-i83666
MSG crosses the blood brain bearer and causes Alzheimer's. It also opens the blood brain bearer to pass other harmful toxins into the brain, like micro aluminum and fluorine. Keep using it and you brain will be gone by the time you are sixty years old. <br>I point these things out for your own good. Live long and prosper.
This is false, Glutamate (monosodium glutamate) cannot cross the blood brain barrier; even in high concentrations. <br><br>Read the last few sentences of the first paragraph(the abstract):<br>https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3136011/
Blood brain bearer should read blood brain barrior. Thanks to max_brasil for correcting my typo.
I find it interesting that I cannot post a comment about MSG without having someone defend it. After all, high fructose corn syrup is just sugar, so why all the hoopla? Well, because they are not naturally occurring and our bodies weren't designed to process them. Sure, they are cheap, so corporations will dump in massive amounts; and they have stronger taste than their natural counterparts, so we consume more than we should. If the goal of this instructable is to create a Doritos-like chip, then go ahead and dump in the MSG. But I prefer to upgrade the recipe into something that favors more natural ingredients. For that, I will follow BRG8FUL's advice on the organic ranch mix.
I have no idea about any studies, but I DO know when my mother was being treated for migraines, her Dr. told her to stay away from MSG, Nitrites, Nitrates, etc. I know many people who get headaches from MSG. On several occasions after my mother had a horrible headache, she reviews what she ate and when reading ingredients of certain foods, she discovered MSG in the item. Personally, I don't see that as being coincidental. So, it is my personal opinion and choice to stay away from it. :o)
This is a good point I hadn't considered. Thanks for the tip!
What is MSG? Is it bad for you?<p>Answers from <a href="http://www.mayoclinic.org/expert-biographies/katherine-zeratsky-r-d-l-d/bio-20025123" rel="nofollow">Katherine Zeratsky, R.D., L.D.</a></p><p>Monosodium glutamate (MSG) is a flavor enhancer commonly added to Chinese food, canned vegetables, soups and processed meats. The Food and Drug Administration (FDA) has classified MSG as a food ingredient that's &quot;generally recognized as safe,&quot; but its use remains controversial. For this reason, when MSG is added to food, the FDA requires that it be listed on the label.</p><p>MSG has been used as a food additive for decades. Over the years, the FDA has received many anecdotal reports of adverse reactions to foods containing MSG. These reactions &mdash; known as MSG symptom complex &mdash; include:</p><ul><br><li>Headache<li>Flushing<li>Sweating<li>Facial pressure or tightness<li>Numbness, tingling or burning in the face, neck and other areas<li>Rapid, fluttering heartbeats (heart palpitations)<li>Chest pain<li>Nausea<li>Weakness</ul><p>However, researchers have found no definitive evidence of a link between MSG and these symptoms. Researchers acknowledge, though, that a small percentage of people may have short-term reactions to MSG. Symptoms are usually mild and don't require treatment. The only way to prevent a reaction is to avoid foods containing MSG.</p><p>With</p><p><a href="http://www.mayoclinic.org/expert-biographies/katherine-zeratsky-r-d-l-d/bio-20025123" rel="nofollow">Katherine Zeratsky, R.D., L.D.</a></p><p>There is proof that it doesn't not cause Alzheimer's my source is </p><p>Alzheimer's</p>
I say I get a headache from MSG and you post a quote from a Dietitian. Maybe a quote from a real doctor would be better, but most doctors suggest avoiding MSG. I still believe the stuff is bad for you (at the very least it is a salt which jacks up your sodium intake).
Eh-hem, a real doctor?? How about a quote from peer reviewed journals... Which are the basis for establishing our past, present, and future medical (and all scientific) findings.<br><br>Which this dietitian is quoting in probably the first place. <br><br>Don't slander dietitians, they are experts in their field. NUTRITIONISTS generally are not.
<p>mayoclinic.org/healthy-lifestyle/nutrition-and-healthy-eating/expert-answers/monosodium-glutamate/faq-20058196</p>
<p>There are also tons of recipes online for ranch seasoning. It may be cheaper than buying the organic kind in the long run, plus you can tweak it to perfectly suit your tastes.</p>
<p>I'm not gonna lie I just looked this up to get 4 times as much seasoning on my bag of doritos</p>
Kazmataz, have I ever mentioned how much I love you recently?<br> <br> Now all you have to do is make them 3D :D<br> <br> <br>
<p>I MISS THOSE!!!!</p>
OMG!!!! 3D Doritos! I lately have been mentioning these to my friends, and no one believes me they exist! Know anywhere I could find them?
M&eacute;xIco :/
THREE WHOLE D'S?!? THAT'S IMPOSSIBLE!!
MSG is a chemical. So what? So is table salt (NaCl) and sugar (C6H12O6). <br>MSG is a sodium salt of glutamic acid, a naturally occurring non-essential amino acid. The stuff used to be extracted from seaweed. Now it's made from beet or cane sugar.
Arsenic is extracted from seaweed too. MSG crosses the blood brain bearer and causes Alzheimer's. It also opens the blood brain bearer to pass other harmful toxins into the brain, like micro aluminum and fluorine. Keep using it and you brain will be gone by the time you are sixty years old.
First off, it's the blood-brain &quot;barrier&quot; (not &quot;bearer&quot;) Then - could you cite a trustworthy reference for your findings? Please read <a href="http://www.livestrong.com/article/464601-what-are-the-myths-of-monosodium-glutamate/" rel="nofollow">this</a> article for a very different point of view.
Thank you for correcting the typo. Yes, surely you would not argue with Dr. Russell Blaylock and Dr. Andrew Weil. These doctors are world famous for their work in Holistic Medicine. I do not think that Peter Mitchell is qualified to argue with these world famous doctors either. It is my OPINION that if you checked Mr. Peter Mitchell's stock portfolio you may find that he has something to gain by helping the chemical companies that make this chemical. <br>I am still interested in the health of the people and have nothing to gain here.
I guess we'll each keep to our own opinions (and diets) I've done my own research including the aforementioned article and also <a href="http://www.webmd.com/diet/video/msg-myths" rel="nofollow">this </a>one on the highly respected webmd site.<br> So, to each his own. Thank you for taking the time to comment on my comments.<br> Cheers!
i love this recipe! i think the seasoning tastes better than cool ranch doritos. my only issue was that i didnt leave some of the tortillas in long enough..and they had this weird rubbery texture - still ate them with the seasoning. =]<br><br>next time i will make sure to let them brown a bit more, bc the ones that tasted the best were the ones that had browned slightly. my oven is ancient -- my cook time was about 15 mins. <br><br>delicious recipe, will definitely be making much more!
I have always deep fried my cut tortilla chips for making nachos. How do these compare to deep fried?
Had to try this ASAP. I only had whole wheat tortillas. I loved them. Made a spicy sprinkle with salt, chili , chipotle, garlic and onion powder and red pepper. <br>Dang tasty! These will be a dangerous quick and easy snack.
What's the spaghetti sauce pack for? I don't see it in the instructions.
That is just one of the flavorings you can use...I've used the spaghetti seasoning before on some home fries...unusually delicious@@
Gave Nacho Cheese a whirl, and it called for powdered tomato along with some other things I found in the spaghetti sauce pack
Did the Nacho cheese work out?
Still a work in progress. Couldn't quite get the right cheese flavor, but will be trying again!
Tim loves Doritos...
Yes!!! I can finally eat the ranch Doritos! (I'm allergic to the red food coloring they add.)<br><br>Thank you!!!!! XD
Y'know... my doctor told me to cut my salt intake, but this recipe has me sorely, SORELY tempted!!! It just looks too delicious!
Is that 350 Fahrenheit or Celcius?
fahrenheit
YUM, YUM AND YUM! I've made the cinammon sugar chips before, but never anything like this. I'm with jwolff6 - they kept disappearing before I could coat them with more flavor!
This is sooooo great! I love it. Doritos are my favorite snack, and I love knowing that I can make them myself. Thanks so much! Tamara ;)
These look much nicer than Doritos! Do they taste better, or the same? Since this still relies on highly processed ingredients, how much better are these nutritionally than Doritos? I'm sure this is not as terrible for you, but it seems more of an awesome reverse engineering experiment than a healthy alternative. <br><br>Did you try the powder on popcorn yet : )
Unfortunately you've left out a key step, which is not refraining from eating the tortilla chips before adding the seasoning. I had far less chips to season because they kept mysteriously disappearing...into my mouth. These taste uncannily like Doritos - excellent instructable!
AH-MAZ-ZING! I would venture to say these are amazing... I would ask though if you could put the measurements of the ingredients up because I had to guess, since I have a container of hidden valley ranch, and i used the white cheddar popcorn flavoring. I didn't add the extra salt, but these are soooooooooo yummy!! Nom Nom Nom indeed!
I went shopping for the ingredients!! Now off to the kitchen to try this out!
simply amazing...(bows)
You complete me....
Looks delish tho I feel bad for those pore tortillas :C taking a wrap and turning it into a a snack food ,those pore little guys.
you don't actually have to take the cheese from the white cheddar mac and cheese....Cabot makes a shaker that looks like a Parmesan cheese shaker and it's actually white cheddar for use on popcorn and stuff like that.=o) Love the recipe for the cool ranch though!
Yum! These were delicious, Karen. Thank you for taking on this project in the name of junk food lovers everywhere!
Shivers & Palpitations & Excessive saliva production & Unhealthy desire to rub DIY cool ranch powder on my gums.<br /><br />(Noticeable effects of this project on my body so far.)
About This Instructable
280,942views
272favorites
License:
Bio: Former Instructables employee. Living in San Francisco amidst the fog. I love getting my hands dirty by taking on new projects, developing unique skills and ... More »
More by kazmataz:Kraftwerk Costume Featured Author: emilyvanleemput Featured Author: eric3dee
Add instructable to:
