Introduction: Homemade Drill Bench Mounted Stand DIY Press Drills
Drill Bench Mounted Stand is ideal for holding your drill steady during use and allows for much more accurate drilling than hand-held operation. Introduction: This is a new adjustable press drill stand perfect for hand made, and important are you can home build it very cheap and easy with old hand drill and more slide raider CNC liner
Designed for use with power drills with collar diameter of 43mm or 35mm with option make hole.It is nice work make by aluminium alloy
More Good Projects Homemade Nice Work for DIY Handmade here:
About This Instructable
2,825views
9favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
