Homemade 'Easyrig' Overhead Camera Support
45,016
135
36
Posted in TechnologyPhotography
Introduction: Homemade 'Easyrig' Overhead Camera Support
This device is an overhead camera support system that is designed to transfer the weight of the video camera from your arms and shoulders to your hips. The rig is basically an overhead arm that you attach the camera to. The other end of the arm is attached to your back by way of a backpack or dedicated brace..
The commercially-made equivalent is an effective device, but at over $1000, it's well out of the reach of most hobbyists, me included. So I decided to make my own with parts I had at home.
Step 1: The Parts You'll Need
 My Homemade Overhead Camera Support is made up of just a few parts. and in my case, most were recycled and FOP (Found on Property).
1. Laptop-type Backpack - The type that has a separate sleeve area for a laptop. Mine's an STM.
2. Straight pole - salvaged from a kid's wading pool.
3. Curved pole - Salvaged from the same pool.
4. Base section - Piece of wood roughly the same size as a laptop.
5. 2 x Hoop Brackets and screws - Same diameter as the straight pole
6. 1 x Threaded hook.
7. Some type of strap to hold your camera - Mine was salvaged from a old babckpack.
Optional
- Hook packing. I've used old bike innertubing.
- Pipe joiner bolt. Not needed if you use a one-piece pipe
Step 2: Building the Overhead Camera Support
Building the Overhead Camera Support is a matter of simple assembly.
1. Attach straight pole to board using the hoop brackets. You may need to put some packing under the bracket to ensure a tight fit.
2. Drill and attach the camera hook to the end of the curved pole.
3. Attach the curved pole to the straight pole.
4. Slide the Rig into the backpack and zip up.
5. Put on the backpack and adjust.
6. Attach the strap to camera.
7. Attach the camera to the hook and adjust if needed.
Use and enjoy!
Step 3: Using the Rig
Using the Homemade Overhead Camera Support is very easy, and best of all, very comfortable. All the weight of the camera is transferred down to your hips, leaving you to concentrate on keeping the camera pointed and steady.
This rig is really designed for static shooting and I found it bounced when I walked. But that wouldn't be any different on the commercial version. The main difference between built and bought is that you have to manually adjust the height of the camera, but that's no real hassle when you consider the price advantage.
The Homemade Overhead Camera Support is great for extended shooting without a tripod, and is far more portable.
My rig is shown here next to the commercially-available version. Hope you enjoyed this Instructable.
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
  • Science of Cooking
    Science of Cooking
36 Comments
We built something similar! Comfortable, durable, and half the cost of the big commercial products. Check out: www.aviatorrig.com
doesn't the commercial version have a cable that pulls down and is loaded to kill up and down movement?
I think it's more of an adjustment than a movement dampener. The rig is more to save your back and shoulders rather than to stop camera movement when walking about. Great for sports shooting and places where you can't place a tripod.
You could ADD some WEIGHT at the bottom to make the camera more stable. :)
You could possibly add in something to stop the camera bouncing up and down so much, im not entirely sure how but someone around might know.
Or you could always get a video camera with the movement canceler.
I would reccomend suspending the camera between bungee.
I've found that standing still is the best solution so far. ;)
At the end of the day, it's a great rig for relieving back strain and it's just about a substitute for a tripod.
The concept is really suited to "move, stop, shoot", and honestly, unless you can walk like a ninja, it won't replace a steadicam rig.
I've found that the biomechanics mean that your 'bum' will move the camera up and down no matter what you do. :)
Hope this helps.
 what if you replace the belt holding the camera with some stretcy material of soem kind? or even find some weakishspings
 I think it would just bounce.
which one is which? Can you add a video with and without the rig please? Thanks.
 Yours looks much better!
 cool but i got the one on a car like thing you know the one they use in the movies and it can extend and do all sorts of trick its wicked
 Sort of. A traditional Steadicam is all about letting you walk, whereas this rig is more about replacing a tripod and taking the stress away from your arms and neck.
Nice 'ible. I am going to try this, however I'm going to use a back brace I kept after a spinal injury-It's just collecting dust...I'm thinking it will work as well as this and maybe even look like pro-grade equipment when I'm done.  If it works, I'll post an 'ible on it. Very cool!
A back brace is a brilliant idea! I'm going to look up medical salvage companies in my local area and see if I can score some. Fantastic!
They do show up at your local thrift from time to time as well, give them a try.
 I wouldn't trust my construction abilities on this project with my $1600 camcorder.
You could just attach a long strap (long enough to wear it while using the rig) to your camera just in case your handywork fails...
