Homemade Electric Screw Driver | DIY
Published
Introduction: Homemade Electric Screw Driver | DIY
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this instructables i will show you how to make a electric screw driver. This electric screw driver has both clockwise & anti clockwise rotation function, which means i it can tight the screw or loosen the screw.
Please vote for me for the Maker Olympics 2016 contest by clicking the VOTE button.
Step 1: Making Video
To make your own electric screw driver please watch the video or continue reading
Also please subscribe to my YouTube Channel for more projects & videos : https://goo.gl/ctc8l9
Testing begins @ 6:50
Step 2: Things Required
1. PVC Pipe with 90 degree bend
2. 12 Volt Geared DC Motor
3. 2 Pole Switch
.4. Old Pen
5. Some Thin Plastic
6. Metal Paste
7. Some Screw Drivers with open end
8. Wires
9. Insulation Tape
10. Some Cardboard Sheets
11. Spray Paint
12. Soldering Rod, Soldering Wire, Soldering Paste & Stripper
13. Scissor
Step 3: Construction - Drilling Holes
Measure the dimensions of the switch and mark them on the PVC Pipe. Once marked carve a hole using a cutting tool or with a help of soldering rod.
Step 4: Construction - Painting
Paint the PVC pipe to give it a good look
Step 5: Construction - Switch Wiring
Connect the wires as shown in the image 1 & Image 2.
There are 8 pins, so Connect 1 & 5 (Blue Wire), Connect 4 & 8(Green Wire), Connect 2 & 3 (Black Wire) & Connect 6 & 7(Red Wire).
Step 6: Construction - Screw Driver - Part 1
Cut the pen using a knife or a cutting tool so it can fit both the motor shaft & screw driver. After cutting take a piece of waste plastic sheet and cover the motor shaft & then insert the chopped pen as shown in the image 1 & 2.
Now mix some metal paste and insert it to one side of the chopped pen as shown in the image 3.
Now insert the screw driver and add some more metal paste to secure it as shown in the image 4 & 5
Note : Leave the metal paste to dry for some time
Step 7: Construction - Motor Wiring
Insert the switch inside the chopped part of the PVC Pipe and then connect the motor as shown in the image 2. Please refer the image 3 for wiring reference.
Once everything is connected & soldered insert the motor into the PVC pipe. You can also add glue to secure the motor to the PVC Pipe (optional, mine was a perfect fit so did not use glue)
Step 8: Construction - Covering Back Side
Take some cardboard sheet and mark the dimension of the pipe on the sheet and remove the excess with a help of a scissor.
Once cardboard sheet is cut make a hole in the center of the cardboard sheet and insert the wire through the hole and then glue it to the pipe & secure it with a insulation tape
Step 9: Construction - Screw Driver - Part 2
Once the metal paste is dried make a hole in the pen matching the hole in the motor shaft and then secure it with a screw.
To watch the testing video please CLICK HERE
If you want to support my projects please buy things from my Amazon Store. This way I get a small commission which will help me produce more videos & projects. Please use the link to visit my store : http://goo.gl/gKjns4
Totally Optional :)
Buying Links :
Amazon IND
Geared DC Motor - http://amzn.to/2bkIjb3
Amazon US
Geared DC Motor - http://amzn.to/2b8sMtT
To read my other instructables please CLICK HERE
Follow Me On :
Please subscribe to my YouTube Channel for more projects & videos: https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
