Introduction: Homemade Emergency Power Bank for Smatphone With TP4056 Li-Ion Charging Module
Homemade Emergency Power Bank for Smatphone with DC Voltage Step-up Boost Module and
TP4056 1A Li-Ion battery Charging Module, 2 cells laptop batteries, mini box toy, and few times
Model: TP4056
- Material: PCB + plastic + iron
- Board TP4056 lithium charge management chip
- Mini USB head can link directly to the computer USB port charging
- The charging board can also power supply from (IN + and IN-) pin
- Setting aside the the TEMP pin interface can be used as lithium battery temperature detection
- Input voltage: 4V~8V - Maximum output charging current: 1000mA
- D1 indicator lights on when in charging, D2 lights on when charging completed
More Homemade External Power Bank Backup Battery for Smart Phone here:
Thank for watching
FrancescoL25 (author)2016-06-19
There is no diagram and no way to understand how you wired it all. Just music and nothing to make it really understandable. Too bad.
kimdats (author)2016-05-02
for this battery protector module
how all of this parts
wesley007x1 (author)2015-09-14
do you have a circuit diagram for this??
There is no need for a diagram, these 3 items cost less than $4 from eBay.
The price of these things have nothing to do with whether or not a wiring diagram is needed.
Koyozene123 (author)2015-04-15
Please post circuit diagram - thank
dasimpson1981 (author)2015-04-13
here is my unit over several changes you will see the protection circuit on the battery with the 2 crock clips attached https://www.youtube.com/user/1981dasimpson/videos
you have not connected the protection circuit correctly the 3 terminals is were the output and input should go one will be + the middle withh be the temp sencer the other will be -
About This Instructable
13,299views
33favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
