Homemade Flower Hat
12,861
245
12
Published
Introduction: Homemade Flower Hat
It’s a French tradition dating back to the 1800s where a couple would preserve mementos from their wedding and marriage together in a glass cloche bell jar. One of the many sentimental items included, besides jewelry, photographs and locks of their babies hair, is the bride’s wedding crown which made from wax orange blossoms and flowers. I mean, is this just the most romantic thing you’ve ever heard of? So when the crepe paper experts of the Castle demonstrated how to make a waxed floral crown, I knew a tutorial on how to create a bigger, more dramatic version would be the perfect thing to share with you, especially with weddings, festivals and midsummer celebrations in full effect. Plus, I love the idea of coating the paper flowers with wax – with the amount of time it takes to make a paper crown, you want it to last forever! So without further ado, here is the how to:
You’ll need:
Please note: I worked hard on making this instructable. The links are
Amazon affiliate or Ebay links, so if you are planning on making your own and are going to buy the materials, please do through my links so I can afford to buy more materials myself and keep creating these instructables! Thanks you so much and God bless!
Step 1:
Start by cutting the 22 gauge wire into quarters, to about 4-5 inches long.
Step 2:
Cut a handful of 1/4″ strips of green crepe paper against the grain.
Step 3:
Apply the tiniest drops of tacky glue onto a strip and start wrapping around the top of the wire.
Step 4:
Crepe paper works a lot like floral wire. While holding the top end of
the wire, pull and twist the crepe paper around at a downwards diagonal. Wrap tightly!
Step 5:
Finish with a dab of glue before trimming any excess. Your stems are finished!
Step 6:
For a daisy, all you need is a small strip of orange crepe paper to make
the stamen. Wrap around the tip of the stem, just as you did with the green crepe paper. But instead of working your way down, just twist the paper onto itself, creating something that resembles a small cotton swab.
Step 7:
Cut a 2″ x 4″ piece of white crepe paper, with the grain going along
vertical, short edge. Fold into an accordion to create 5 layers.
Step 8:
Lay the bottom of the daisy petal pattern along the bottom edge of the accordion and cut along the pattern.
Step 9:
Cut a point on the bottom – this will allow it to wrap around the stem
easier. Open up the accordion and then put a tiny dab of glue on the bottom left corner.
Step 10:
Lay the stem on the left side and start wrapping.
Step 11:
Take the tightly wound bundle and wrap another green strip of crepe paper around the base of the flower and onto the stem.
Step 12:
Then fan out the petals, one at a time. Bend or curl them over a chopstick or pencil.
Step 13:
Them use your fingers to spread out each flower petal.
Step 14:
To make a poppy, we’ll start with a 1″ x 3″ piece of crepe paper for the
fringed stamen. The grain should go vertically, along the shorter edge of the paper. Cut a fringe, leaving about a 1/4″ base.
Step 15:
Roll the fringe between the index finger and thumb, creating a twisted
look. Place a tiny dab of glue in the lower left corner and place the stem on top of it.
Step 16:
Roll it several times around the tip of the stem and finish with tacky glue.
Step 17:
Then, cut a 3″ x 5.5″ piece of orange paper and fold it into a 5 fold
accordion. Use the poppy pattern to cut out the petals, leaving the base intact.
Step 18:
Open it up, run a thin line of glue long the bottom and place the stamen at the end.
Step 19:
Roll the petals around the stamen pleating the petals as you go.
Step 20:
Add a strip of green crepe paper around the base of the flower – pulling, wrapping and twisting downwards.
Step 21:
Finish it with a drop of glue and trim away any excess.
Step 22:
Pull the petals out one at a time, using your fingers to expand each petal.
Step 23:
To make a bell flower, start with a 1 x 1″ piece of crepe paper. Cut a 1/4″ fringe along the grain.
Step 24:
Wrap the fringe around the top of a stem.
Step 25:
Ruffle the fringe with your fingers. Then cut another 2 x 2″ piece of
white crepe paper. Run a very thin line of glue along the grain.
Step 26:
Close square to form a tube and place it over the stem.
Step 27:
Pleat and pinch the base and wrap a strip of green crepe paper around the base.
Step 28:
Peel the top of the tube away from the stamen.
Step 29:
Spread open with your fingers.
Step 30:
To make leaves, use the patterns to cut the shapes out of green crepe
paper. Remember to align the petal patterns lengthwise, along the grain of the crepe paper. Run a line of glue along the top of the stem.
Step 31:
Place it onto the bottom of leaf. Put another tiny tab of glue at the base of the leaf and roll it between your fingers.
Step 32:
Use a chopstick or pencil to give the leaf some bend and curve.
Step 33:
Now, it’s time to coat the flowers into beeswax. This step is optional and can
be skipped. The wax, however, will preserve the flowers while giving them a transparent, realistic appearance. Turn on the melting pot and add the beeswax pellets. Careful when working with melted beeswax. It’s hot!
Step 34:
Dip the paintbrush into the melted wax and gently brush evenly over
the entire flower. You don’t want to add more than a couple of coats per section since the wax will build up and dry opaque.
Step 35:
Set aside to dry and harden.
Step 36:
You’re ready to assemble the crown!
Step 37:
Cut several 1/2″ strands of dark green crepe paper. Glue and wrap one
strip tightly around the bottom 3 inches of one of the 18 gauge wires.
Step 38:
After a couple of wraps, lay the other 18 gauge wire next to it and
continue to wrap the two wires together. You now have a single piece of thick wire that is long enough to wrap around your head. Form the wire into a large U shape.
Step 39:
Bundle a flower and a couple of leaves together and attach it to the
center of the U shaped wire with a strip of crepe paper. Make sure the flowers are pointing towards the center of the U shape. Continue adding more flowers as you work down the wire, wrapping them along the way.
Step 40:
Continue adding and wrapping. Once your green strip has run out, simply glue it closed and start with another strip.
Step 41:
Stop adding flower about 5-7 inches. Trim any excess stems and wrap the bottom tips.
Step 42:
Now repeat on the other side. Start at the center again with the flowers facing towards the middle of the U shaped wire.
Step 43:
Curve the ends in, creating a circle. Lay it on top of your head for a
proper fit. Bend one side of the wire back in the opposite direction.
Step 44:
Use a strip of crepe paper to create a small loop. Trim away any excess wire.
Step 45:
Now thread the other side through the loop and bend backwards. Trim the
wire. Your crown now has it’s own closure! Go back and bend the flowers outwards from the center and adjust the leaves.
Step 46:
Voila – your crepe paper flower crown is finished!! Add a ribbon . Wear it year after year.
I hope you enjoyed my instructable. Don't forget to leave me a comment!
Please support me by purchasing you materials through my amazon affiliate links so I can afford to make more instructables for you! :)
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    Hi this is great flower hat
    do you have the pattern, size and shape of leaves anywhere I would like to make it but I can’t find the paper design
    Thank you
    12 Comments
    Wow it is amazing!!!
    I had no idea that the French traditions did that in the 1800s, that is very cool! It shows how through time we still cherish the little memorable things that are sentimental to us. Thank you so much for providing all the materials needed to make such a beautiful flower hat, hopefully mine could turn out as pretty as yours! I was also looking at this DIY that is quite similar to yours, this could be helpful for a cute Coachella accessory, let me know what you think!!
    https://omghow.com/articles/1502
    ❤️❤️❤️AWESOME❤️❤️❤️
    ❤️❤️❤️AWESOME❤️❤️❤️
    This is just absolutley astounding...I love how precise you were and it looks so delicate. I also really love how you covered the hooks too! No more pulling hair! This is wonderfully inspiring! I can`t wait to start making my own! Thanks for sharing this. c:
    It looks soooo pretty and great instructions! I can't wait to make one :)
    How many flowers an leaves did u approximately use?
    This is great that you can make it yourself, other versions i've seen you have to buy the flowers, i'll be doing this when I have time :)
    This is beautifully photographed with super clear instructions. Love it!
    Thank you! Glad you like it!
