Publishing this one in a hurry, in case it is useful to our friends in Japan.  This is a simple Geiger counter circuit.  It does require some specialized parts, in particular a Geiger tube and some high voltage Zener diodes, but the rest of the components are readily available.  If you're feeling like experimenting, try making your own Geiger tube... see the last step of this instructable for some comments on that.
This is the second electronic circuit I ever made, so it's pretty basic, suitable for beginners.
Step 1: The circuit
Click on the "i" in the top left of the picture and select the full image resolution to see the schematic diagram more clearly.  I am assuming you have some electronics experience so you know how to solder and which way to connect a diode etc., but if not or if you have any questions please ask.
I didn't have components to make a high voltage power supply, so I improvised using a transformer from a 10V AC adapter (the little black box you plug into the wall to convert 120VAC to 10VDC).  It is not that important to use a 10V transformer, I'm sure anything in the 3V to 12V range would work.  Just break open the plastic box and remove the transformer.  I used a 1.5V battery (C cell) and a pushbutton switch on the 10V side of the transformer, and the high voltage is generated on the 120V side.  You will have to experiment with which polarity to connect the 120V wires of the transformer so as to generate the correct polarity of high voltage, with the wrong polarity the voltage generated will be much smaller.
Tech note:  How the high voltage circuit works
The output voltage of a transformer is proportional to the rate of change of the input current.  When you press the pushbutton switch, a fairly large current builds up in the low voltage side of the transformer.  When you release the switch, this current instantly drops to zero, and since the rate of change of current is very high (dropping from a large current to zero in a very short time), a high voltage spike is generated on the high voltage side of the transformer.  High voltage generating circuits work in much the same way, but they use transistors to switch on and off the current in the low voltage side of the transformer.  Since the high voltage is generated only when the button is released, you want to press the button for only a short time so you don't waste the battery current.
The generated high voltage is stored on capacitors and is regulated to 500V using three high voltage Zener diodes in series (200V, 200V, and 100V, adding up to 500V).  Such high voltage Zener diodes are not common, you will have to get them at a specialty electronics distributor.  Of course whatever reasonably high voltages you can find (for example 1N5271 through 1N5279 are rated 100V through 180V), just add enough in series to equal the voltage rating of the Geiger tube.  Make sure to use capacitors rated at least 1000V, and put enough in parallel to add to about 0.02 microfarads.  Note that you can't put lower-voltage capacitors in series to get a higher voltage rating, this doesn't work.  The Geiger tube I had required 450-500V, other tubes require different voltages, 900V is common, if so use more Zener diodes accordingly.
The diode labeled "1000V PIV" is a rectifier diode with 1000V peak inverse voltage (or peak reverse voltage), to rectify the high voltage (for example 1N4007).  I actually used two of these in series because with just one the leakage current was too high, and the high voltage decayed too quickly.  If you have lower voltage diodes such as 1N4004 you can put several of them in series.  I opened a compact fluorescent light bulb once and it contained several 400V PIV diodes, 3 to 5 of those in series would work.  The two unlabeled diodes are 1N914 type.
The signal from the Geiger tube is strong enough to trigger a 555 timer.  The 555 timer then drives a small speaker directly, making a 'click' noise each time the Geiger tube detects radiation.  Use an IC socket for the 555 timer chip, so you don't fry the chip when trying to solder it into the circuit, also it makes it easier to replace if you make a wrong connection and fry the chip.
Here is a similar design which you can also refer to for other ideas and information:
http://www.galacticelectronics.com/GeigerCounter.HTML
fyborg says: Jun 26, 2012. 11:52 AM
For the high volts pwr sppy.. what about anused one-use pic cámera, the high tension to charge the capacitor offers about 500 volt and is so little, have a look to this instructable about:
" Build a Pocket Ionizing Radiation Detector (PIRD)" if you like to and how to make some kind of a ¿geiger counter no-tube"?.. and how to use the used cam circuit for the high voltage supply.
Nice instructable, thanks from Spain.
Fyborg
electric_piano_5k (author) says: Jun 26, 2012. 6:26 PM
Using a camera flash circuit to generate the high voltage is a good idea.
mr_man says: Jun 24, 2012. 8:52 PM
http://electronicdesign.com/article/test-and-measurement/simple-geiger-detector-uses-neon-glow-lamp1634
electric_piano_5k (author) says: Jun 25, 2012. 5:36 PM
Cool! I was wondering if a neon lamp would work. I expect that the count rate would be low, but it's certainly an easy way to go.
explodingsodium says: Jun 24, 2012. 9:51 PM
Could I have a better view of the wiring diagram? I can't see it very well. Thank you.
electric_piano_5k (author) says: Jun 25, 2012. 5:30 PM
Did you click the "i" in the top left corner of the picture and select the full image resolution? Then you can see it more clearly.
DrWilliamHorriblePhD says: Apr 18, 2012. 1:36 PM
Would this geiger be sufficient for driving http://www.instructables.com/id/Arduino-True-Random-Number-Generator/step5/Detect-Radiation/
electric_piano_5k (author) says: Apr 18, 2012. 5:22 PM
Yes it would work, but it would be annoying to have to keep pressing the button to refresh the high voltage. If I was going to do something like that I would make a better high voltage source that does not require a manual pushbutton. Check out some of the references in my instructable.
botronics says: Mar 19, 2011. 7:03 PM
Thats a great geiger counter. I made one 20 years ago and got it out to monitor , if any radioactive particles from the blown reactors in Japan. I just got done writing an instructable on how to Ustream the data. Your counter would be perfect if you can add a optocoupler at the output for making pulses. Are you near the West Coast close enough to catch any fallout?
electric_piano_5k (author) says: Mar 20, 2011. 9:21 AM
Thanks for the comment! My circuit is not very well suited for a continuous monitoring application like your project (great project by the way!), because with my simple high voltage generator you have to manually push a button to generate the high voltage. It would be possible to connect a slow 555 oscillator circuit (1Hz?) to a relay to generate the high voltage automatically, or to use a high voltage generator circuit such as in the galacticelectronics link above.
It would be quite easy to connect an optocoupler to my circuit, just connect it to the speaker output through a ~1 kohm resistor.
I am on the east coast so I don't expect to pick up anything from Japan. I think even after Chernobyl it took very specialized equipment capable of detecting the gamma ray energies to pick up fallout in North America and distinguish it from normal background radiation, so I don't expect a Geiger counter would be able to do it. But definitely fun to try!
electric_piano_5k (author) says: Apr 12, 2011. 3:33 PM
Here is a site that has a Geiger counter hooked up to a webcam to monitor any fallout from Japan... http://www.enviroreporter.com/2011/03/enviroreporter-coms-radiation-station/
Biggsy says: Mar 17, 2011. 8:27 AM
Do you often make Geiger counters?.... How efficient is this based with say an off the shelf counter?
I would suggest that when/if you get more time, to flesh this I'ble out abit as it's not fantastically clear... But well done anyway I enjoyed giving it a read
Homebrew radioactivity detector... interesting idea
High Five for you
electric_piano_5k (author) says: Mar 17, 2011. 11:43 AM
Thanks for the comment. Yes, when I get some time I'll add more details. If you have some suggestions on what's especially needed that would help.
This is the only Geiger counter I have made, I did it as a project for an electronics course years ago. With 5 counts/minute for background radiation it is not as efficient as most Geiger counters which will give 15-30 counts, but that's because of the small tube I used, not the circuit.
What' I'd really like to do is figure a way to make a Geiger tube, that's the big disadvantage of this project, Geiger tubes are hard to come by. They are normally filled with special gases, but I think they can work when just filled with air..
electric_piano_5k (author) says: Apr 1, 2011. 5:37 PM
Here is a posting that describes how to make a Geiger tube using a 35 mm film container!  The disadvantage is that an air-filled tube requires >3000V.
azerger1 says: Mar 31, 2011. 10:34 AM
Apparently radioactive particles will ionize the gas to 500v and trip the counter. Found that on, http://www.blackcatsystems.com/science/radiation.html
azerger1 says: Apr 1, 2011. 5:06 PM
Homemade Ion Chambers:
http://www.techlib.com/science/ion.html#Experimenters%20Chamber
onepiece94 says: Apr 1, 2011. 1:26 PM
soo yeah....... did a great job there.....BUT..... it is still too difficult to make (for me, i don't have the parts i mean), and not anyone can make it. i'm trying to make one myself using up to 4/5 parts (yeah sounds unbelievable) i have a tube (that you can find everywhere, and does not have a voltage rating up to 400/500 V its really low,
Taoiseach says: Mar 18, 2011. 2:39 PM
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17365
Reasonable price, too.
Sitnalta says: Mar 25, 2011. 7:17 PM
It's reasonably priced because it's not very useful. It's sensitive to only gamma rays, which means it's more of an ion chamber than a GM tube. So, basically it's only useful in very specific applications that your average civilian isn't going to encounter.
If you want your counter to be interesting, I'd spring for at least an alpha, beta radiation detector. That way you can detect the radioactivity in nature (rocks, cosmic rays, etc.)
electric_piano_5k (author) says: Mar 26, 2011. 8:41 AM
Whether a Geiger counter is sensitive to alpha, beta, or gamma depends on the thickness of the wall of the tube. Tubes with a thin aluminum wall can detect beta, to detect alpha requires an extremely thin wall (usually mica) because even a sheet of paper will stop alpha rays. Probably this one detects only gamma because of the thick glass wall. But that is perfectly fine for general use because almost all radioactive substances emit gamma rays in addition to any alpha and beta.
The example circuit that they provide is a Geiger counter, not an ion chamber type detector, so I think it really is a Geiger tube and will react to rocks, cosmic rays, etc.
electric_piano_5k (author) says: Mar 27, 2011. 11:32 AM
I found an item on e-bay that is very similar and had some specs and comments that suggest it may be an ionization type detector, not a Geiger tube. Copied from the e-bay description:
Russian military Geiger tubes counter Ci-3BG.
Lot of 50.
Plateau > 80 V.
Plateau inclination , % / V, no more: 0,25
Sensitivity countable characteristic Imp/sec //( R/h) > 1,3 * 10-5 (188) > 2 * 10-5 (282)
U on the anode in an impulse mode V 380-460
U on the anode in a current a mode V 382-398
The greatest working current uA > 15, < 20
I'm not sure what all of that means, but the 'plateau' seems to refer to ionization type detectors (see this link), and the apparent mention of 188 and 282 rad/hour suggests it is only sensitive to high radiation fields.
electric_piano_5k (author) says: Mar 27, 2011. 3:10 PM
Another e-bay seller (sovtube) has this description.  Note the spec translation is given here as 188-235 pulses/second per rad/h.  For comparison, a standard Geiger counter such as CDV-700 will give about 600 counts/minute (10 counts/second) at 1 mrad/h, or 10,000 counts/second for 1 rad/h, which is 50 times as many counts for the same amount of radiation.  So this tube may in fact work as a Geiger counter, but because of the very small size (I think the little metal cylinder in the center is the sensitive part), it will give less than 1 count per minute under normal background radiation.  Also such a small tube may not give a big enough signal to trigger the 555 directly, you may need to add a FET as in the example circuit on the electronic goldmine site.
Russian Geiger TUBE Counter SI-3BG
New, old stock.
Lot of 1
Russian made (CI-3BG) glass geiger mueller tube is designed to detect betta and gamma rays.
Working range of Dose POWER 300R/h
Sensitivity to Gamma Radiation 188-235 Pulses/s/R/h
Working Current 0.015-0.02 mA
Plateau Length/ Inclination 80V/0.25%/V
Working Voltage 380-460V
Maximum registering range 300 Roentgen/hour
Length 55mm
Diameter 10mm
electric_piano_5k (author) says: Mar 19, 2011. 12:20 PM
Excellent! Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
