Homemade Gel Laundry Detergent
This is a great recipe. I have been using it for a while now and absolutely love it! It leaves your laundry smelling clean and soft without any fragrance. You can add fragrance if you would like. But it is great as is. It cost about $1.25 for 2 gallons of this detergent of the amount used in this recipe. Of course all ingredients cost about $7.50. You will have alot left. Probably enough for the entire year (with the exception of the zote).
Step 1
Measure 2 cups of this arm & hammer super washing soda and put it in a large bucket. 5 gallon bucket with lid works good.
31 comments
Sep 21, 2011. 6:54 PMFlatLinerMEDIC says:
Just bought zote at 99 cent only store...for 79 cents. they have it at food city too for Az people
Sep 18, 2010. 10:22 PMzidakano says:
search amazon for zote and you get a few different options,
zote, fel naptha, octagon being the ones I remember off the top of my head.
I found all these products at Kmart if there is one close to you that could be an option.
Washing soda goes by a lot of names and you may be able to find it cheaper by one of the others.
washing soda, soda ash, sodium carbonate, PH up/+ (pool chemical), supposedly from farm supply stores such as atwoods too.
whatever you end up buying should have sodium carbonate as the only ingredient.
Nov 5, 2008. 2:22 PMroboguy says:
What is Zote? Could I use other soap, or is there something special about Zote? Also, why might there be a legal issue about what kind of washer you use?
Nov 5, 2008. 5:03 PMroboguy says:
ah, ok. I was wondering if it was a water quality law related to something about too much detergent in your grey-water, kind of like dumping chemicals down your sink!
Nov 7, 2008. 12:51 PMseandog says:
Would this 'awsome damn cheap elixer' by chance be biodegradable ??? Which would make it even more awsome!!!!! inquiring minds would like to know.
Jan 1, 2009. 4:57 AMThenicholas3 says:
I don't know about the Zote soap, but I make this recipe with fels naptha laundry soap and it's biodegradable. Both washing soda and borax are naturally occuring elements. I will also add lavendar oil to some to use on my sheets and towels, it's a nice touch.
Jan 2, 2009. 1:17 PMseandog says:
Thanks for the info...I am trying to convince my hubby to create a grey water system for our garden- Seandog
May 14, 2010. 6:08 AMmangomerle says:
I know this is a response to a comment from a long time ago, but I'd hate for someone to have to learn the hard way. You don't want to use borax if you are going to be using a greywater system. Borax kills most everything; plants, insects, it's poisonous if ingested by mammals, birds, etc. Washing soda is also not recommended for use with greywater systems. I'm not sure about the washing soda in reference to greywater systems. Brad Lancaster has some books I've been meaning to read about rainwater collection and use of greywater. More info can probably be found there.
Nov 5, 2008. 1:39 PMgoodgnus says:
Very cool, with the recent increase in price and decrease in quantity of arm & hammer detergent I may have to give this a try. Would be nice if someone with a chemistry background could chime in and come up with an ingredient that will allow this to really "gel" as in become like jello so that it does not settle and need to be mixed before using each time.
Dec 27, 2008. 5:15 PMgloflyer says:
I make a similar soap. Sometimes it gels good, other times it doesn't. If it doesn't, I just put some of it back into the pan, heat it up, and then stir stir stir into the bucket. I don't think that you want to add any kind of thickener. This stuff works good, and the clothes come out feeling really soft. However, this soap does not have the optical brighteners that are in commercial laundry detergent. About every 3 loads, I use regular detergent. This stuff is actually preferred for high efficiency washers. I have had both kinds, and it works in either.
May 2, 2010. 5:22 AMgirrrlychild says:
if you want to stay away from the regular detergent but still whiten and brighten, you could add some OxiClean or similar product when you put the stuff in the wash.  DON'T MIX IT IN with the soap to store it unless you're doing a dry mix (powder) instead of the gel.  it will lose it's effectiveness if you mix it with water and let it set more than a few hours.  :)
Nov 5, 2008. 7:45 PMdondangler says:
I'm not sure of sources outside of pharmacies, but there is a dietary thickener that uses a very small amount to thicken a great deal. It is a fine starch. I have been using this soap recipe for a few years with good success in both front loader and top loaders. The only caveat I would mention is that you will want to spend a some of your savings on a good pretreatment for stains as this recipe works poorly on food stains, but you will still save buckets of money.
Nov 6, 2008. 4:27 AMnachobobs says:
I might sugest a thickener called "Agar Agar" it is used lots in asian food and is made from ocean algae. you would need to heat about a litre of water then add the agar agar to the water and "cook it out" for five or so minutes before tipping the hot liquid into the remaining ingredients. As a general rule for a hard, cuttable jelly, we use around 10 grams per litre of liquid. For a more "gel like" consistancy you could try 6 or 7. Agar Agar can be bought from good supermarkets over here in Australia or maybe try Asian supermarkets or grocers. As it sets at 80 degress agar agar is better suited to room temperatures than geletine, which we all know needs to set in the fridge. Hope this helps and good luck
Nov 5, 2008. 9:03 PMhernanai says:
Regarding that dietary thickener: (It is just very fine ground up corn) You may want to monitor how much you use though in your washer. My grandmother uses "Thick-It" liquid thickener and somehow she managed to clog the sink with that stuff when she rinsed her cup to mix some more. As far as I know it still needs to be stirred even after a few hours because it does start to settle. Have you tried a gelatin based solution?
Apr 25, 2010. 4:37 PMlaborspy says:
 I looked all of my area in PA and couldn't find Zote.  I had to order it on the internet, bellow are the links that I can share with everyone as it took me a little but to find it.
Links:
-Amazon (case of 25 pink)
-Amazon (case of 25 for whites)
-TheLatinProducts.com
-Mexgrocer
-eBay
I also heard that the Fels Naptha has some bad ingredients in it, while Zote is a little less harsh.  My 2cents if your trying to stay more Eco friendly.
Nov 21, 2009. 7:24 AMtahine says:
no suds from the homemade detergent..is this normal?
Mar 30, 2010. 2:34 PMtigereye64 says:
Yes it's normal, the suds don't really do much of the cleaning anyway and make it harder to rinse clean. Another good soap to try if you can't find Zout is Fels Naptha.  Also, try adding 1 cup of baking soda to the mix for deodorizing.
Mar 11, 2010. 2:50 PMchantellepolson says:
hear  in canada   they sell 2  bars  of  laundery  soap  for  a dollar a t the  dollar store
Jun 24, 2009. 2:34 AMyourtubemeera says:
hello !! im from india.......and i dont find any of ZOTE or FELS NAPTHA......so kindly tell me wat r the ingredients of a detergent soap so that i can compare it with the soaps i find here..........washing powders are so costly here........and i must say this is a good recipe.........well i was wondering if we can use copper II sulphate (blue vitriol).......so that it disinfects d clothes as well and also works as a whitener.......watsay ??
Nov 5, 2008. 2:54 PMautolycos says:
You could probably add 1/2 cup of corn starch to help it gel more. Add it to the boiling water. Sorbitol (thick-its) is likely what is used in a commercial detergents.
Nov 5, 2008. 1:24 PMdchall8 says:
What is Zote and where do you buy it? Is it really a gel? It looks dimply in the picture. Do you have to mix it every time you use it?
May 11, 2009. 3:48 AMkstrohpaul says:
We use the same recipe. Washing Soda is kind of hard to come by at your local store, so, if you have a swimming pool, PH Plus is basically the same as washing soda and it works great. My wife also makes our hand/body soap, so she has alot a scented oils, if you put a little in your laundry soap i will make your clothes smell good along with being clean.
Apr 9, 2009. 8:56 AMladylissa says:
I make this all the time. I cut the recipe in half and make just 1 gallon at a time. Sometimes I just use it in powder form (1 Tbsp. Per load). It's pretty awesome. I use cold process lye soap, but zote is good too!
Jan 27, 2009. 6:27 AMnaturallydreadful says:
Zote is a large, pink, laundry bar of soap. I buy mine for 80c a bar at Big Lots. I have heard that Fels Napa works better, but I can't find that in Arizona. Zote is easier for me to find living so close to the border, since it's made in Mexico. I make this recipe but only use 1 c of the washing soda, 1 c of the borax, and one grated bar of Zote. If the soap mixture and the water added aren't around the same temperature when adding them together then they like to separate and on top is this big sheet of soap and water at the bottom. The first time I made this I had to re-heat it up and then I just stirred it throughout the day and it made a wonderful jelly-like 4 gallon bucket of laundry soap that will last our family of 6 a while.
Dec 28, 2008. 11:50 AMGemmee says:
Is there a substitute for this soap? don't think I can get it in my region
Nov 16, 2008. 3:45 PMballougal says:
If you don't have Zote you can use Fels Naptha Soap
works just as well.
I make my own laundry soap..whether it be gel like this or powder type...I will never purchase laundry soap again...I love this stuff....
you can find the recipes here
http://www.thesimpledollar.com/2008/04/09/making-your-own-laundry-detergent-a-detailed-visual-guide./
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:kar1m
