Homemade Green Cleaning Recipes
 by jessyratfink
Contest WinnerFeatured
Clean nearly everything in your house with simple and non-toxic ingredients.
Whether you're worried about the chemicals you're using, wanting to save money, or hoping to save yourself from all those horrible added dyes and fragrances - these recipes are for you!
Step 1: Ingredients Used In These Recipes
The recipes use very few ingredients, most of which you should have around the house!
  • water
  • baking soda
  • rubbing alcohol or vodka
  • castile soap
  • white vinegar
  • essential oils
  • unflavored gelatin
  • salt
In addition, you'll need spray bottles and glass containers, depending on the recipe. You can reuse bottles from old cleaners - just make sure to clean them thoroughly! You can also buy cheap reusable ones from most grocery stores.
Step 2: All Purpose Cleaner
What you'll need:
  • a large spray bottle
  • 24 oz (3 cups) water
  • 1/8 to 1/4 C liquid castile soap
  • 2 T white vinegar
  • essential oils, like lemon, lavender or tea tree
Fill your spray bottle with 3 cups of water. Add the tablespoons of vinegar and the castile soap. (Make sure you add the soap AFTER the water, or it will get very sudsy and exciting.)
Now you'll add the essential oils. I like adding 10 drops of lemon and 10 of tea tree!
I use this in my kitchen and my bathroom with great success! It's amazing at getting the stove top clean, and I love how clean it gets my counters and tabletops. Also great for cleaning the fridge.
I recently started scaling down the soap and adding more vinegar. I like it a lot. I'm using closer to 1/8 cup of castile soap now. :) The extra vinegar cuts down on soap scum/residue, and using less soap has been just as effective, but with less bubbles to clean up.
Step 3: Ghetto Febreze
This is a very easy Febreze alternative - I've seen a ton of recipes using fabric softener... but those aren't very "green".
What you'll need:
  • a small spray bottle
  • 1/2 cup rubbing alcohol or vodka
  • essential oil
  • 1 cup water
Fill the spray bottle with 1 cup water and 1/2 cup rubbing alcohol or vodka.
You'll now add the essential oils - I typically start with 30 drops and then work my way up. You can also mix oils to create custom scents. I also like using The Body Shop home fragrance oils in this mix and I've had no problems with them.
Note that you will be able to smell the alcohol, but only for a minute or so... after that things will just smell lovely. Rubbing alcohol has a stronger smell than vodka! :)
I use this on my couch, bed, curtains, dog bed, towels, etc. and the smell lingers for quite a while - for example, I sprayed my couch while cleaning yesterday and it still smells nice.
Step 4: Gel Air Freshener
Very simple to make and very, very cheap! Perfect for bathrooms or closets. Will last around a month.
The instructions for this will depend on the type of gelatin or pectin you use.
What you'll need:
  • plain, unflavored gelatin or pectin
  • water for preparing gelatin
  • food coloring (optional, just for added flair)
  • essential oils
  • small glass jars or bowls  (I filled three with 2 cups of finished gelatin)
  • 1 tablespoon salt (prevents mold)
To make this, place 1-2 drops of food coloring in each of your glass jars or bowls, and then prepare the gelatin according to the package directions, adding the salt during boiling. Once the gelatin has dissolved in the water and it's ready to set, add 20-30 drops of essential oil and mix. Then pour into your individual containers and mix with the food coloring.
Check the strength of the smell at this time and add more oil if necessary.
This will firm up at room temperature, but if you want it to set quicker you can place it in the fridge.
I've got two of these in my closet right now, as well as one in the bathroom.
You can cover these with thin cloth or perforated paper if you like, but I keep mine up high enough that anything that sticks to the surface is out of sight. :)
Step 5: Window and Gloss Surface Cleaner
This one is easy, though a little smelly - but don't worry, the smell goes away pretty quickly and you'll have nice clean windows!
What you'll need:
  • small spray bottle
  • 1 cup water
  • 1 cup vinegar
  • squirt of castile soap (this is optional, but helps reduce streaks)
Pour the water and vinegar in the bottle, and add a tiny squirt of the castile soap. Shake it up and you're ready to clean!
Many people recommend using newspaper to clean your windows, but as I don't get it delivered, I use flour sack towels or old cut up tshirts. This solution takes a little longer to dry than your typical glass cleaner, but don't worry! It'll look very nice when totally dry.
You can also use this solution to clean appliances and countertops. :)
Step 6: Drain Cleaner
This is very simple - just baking soda and white vinegar. You can also use lemon juice if you have that on hand! This works best on drains that are running very slow, but not those with standing water. If your problem is soap scum or other build up, this will break it up and get things moving again. It also works as a good deodorizer for kitchen drains.
Shake a bit of baking soda over the drain - I'd say a 1/4 of a cup or so. Push it into and around the drain, and then pour a bit of vinegar over it until you get a good bit of bubbling and the vinegar begins to pool in the sink.
Let this drain and set for 15-20 minutes and then flush with hot water.
And as a bonus, you can also clean your sink with the little bit of mixture that'll be left at the top of the drain. :D
Step 7: Extra Cleaning for Pots and Pans
If you've burned food to a pan, or if you've made yourself a nice hardened, stuck-on food mess along with your dinner, there's an easy way to get it out. :)
Add about 1/4 cup baking soda to a couple of cups of water in your pan and bring to a boil on the stove for 5-10 minutes. While this is going, it helps to scrape the bottom of the pan with a wooden spoon.
After you take it off the heat, give it a good scrub. You should have a nice clean pan! If not, rinse and repeat with a little more baking soda. This will also help remove stains for things like tomato sauces.
Step 8: Additional Green Cleaning Tips
Try to use cloth towels for nearly everything. If you can't afford towels, a good way to save money is to cut up old tshirts into rags. My mother and grandmother did this when I was growing up, and I think it's such a good idea! Just clean with them, rinse in hot water, and hang to dry. I tend to hang mine on the sides of my recycling bin.
Once you've used them a few times (or for a really gross mess) they're easily thrown in the washer. :)
Also, here are some other uses for the ingredients used to make the cleaners in this instructable:
  • use water and baking soda to make a paste to clean especially nasty messes - a greasy stove top, a spill in the oven, your toilet bowl.
  • vinegar and baking soda can be left overnight in the toilet bowl and then scrubbed in the morning - gets rid of stains and odors.
  • baking soda sprinkled in littler boxes and mixed in helps control all those urine odors... I've been doing this for years with both plant based and clay litter.
  • straight vinegar is awesome at getting rid of hard water stains in showers... simply put it in a spray bottle, spray down the walls and let them soak for a few minutes, and then grab a brush and get scrubbing! I cleaned my mom's shower this way - it was all orange streaks before and the normal cream color after! It takes a little elbow grease, but it so worth it to avoid something like CLR.
  • you can use castile soap as a cheap but effective hand wash - just fill an old soap dispenser with half water and half soap. It might not suds up as much, but rest assured - it's still doing the job.
Anyone else have great homemade cleaning products? Tell us about them in the comments! :D
1-40 of 55Next »
ogorir says: Mar 30, 2013. 7:08 AM
How did you manage to get Meijers isopropyl in Cali?
jessyratfink (author) in reply to ogorirMar 30, 2013. 12:42 PM
Magic!
( actually, this ible was made when I was still living in Louisville, KY :D )
el_lyn says: Mar 24, 2013. 1:56 PM
Hi,
Tried this out for the first time but had a slight problem, I used a lemon oil but it just rose to the surface. Any ideas?
jessyratfink (author) in reply to el_lynMar 25, 2013. 10:37 AM
I had this problem a couple times - I found that if the gelatin was still super hot and liquidy, the oil would rise more often.
If you let it cool and start to congeal a bit, it works better, I think!
It's honestly I little hit and miss. I think sometimes the gelatin just doesn't want to play nice. :)
redorchestra says: Jun 19, 2011. 3:30 PM
I make my own laundry detergent by mixing 1/2 a cup of borax and 1/2 a cup of washing soda in a gallon of water until it all dissolves, then melting 1 cup of grated sunlight bar pure soap into a medium pot of about 1 litre of water.
Mix the dissolved soap and borax/soda mixture together and let it sit for 12 hours.
Laundry soap for about 1 dollar.
uberlazy in reply to redorchestraJul 14, 2012. 9:00 AM
Where do you find washing soda? I can't find it anywhere!
rpguy in reply to redorchestraDec 22, 2011. 4:53 AM
Hi, how much would you use for a large load in a front load washer. What a great idea
Thanks
redorchestra in reply to rpguyDec 22, 2011. 1:40 PM
i use about a cup of my homemade soap for a load in a toploader. it is low foaming soap so it works great for front loaders though
barefootbohemian says: Feb 13, 2012. 5:38 AM
Love the work you've done! I'll definitely be following :)
bluidego says: Nov 5, 2011. 7:13 PM
oh also I use RAIN vodka for this it is the best
bluidego says: Nov 5, 2011. 7:11 PM
I have been doing this with vodka for years. Although I didn't ever see it as ghetto. Essential oils are pricey and way better than anything febreeze puts out!
pmahler1 says: Nov 5, 2011. 6:15 PM
You can order castile soap easily from Amazon.com for $5-$10 =)
mcorriveau says: Nov 2, 2011. 12:55 PM
I would be careful with some essential oils. Peppermint, in particular can be harmful to cats so it's a poor choice to deodorize your couch if you have one that likes to lay on it.
vortexmax says: Jul 21, 2011. 9:19 AM
Better look up the toxicity factor on IPA (Rubbing Alcohol) Is is flammable and toxic,handle with care keep out long reach of children.Vodka to expensive to waste on cleaning.Use it to clean your throat but not to much.Other then this good stuff.
fidgetofdoom in reply to vortexmaxSep 22, 2011. 8:20 PM
actually... Vodka is WAY cheaper then some alternatives... This isn't just a smell good spray, its a deodorizer... and Vodka is brilliant for that oddly enough. I use it to remove sweat stink in shoes, and cat piss smells... great for spraying down furniture that you've gotten of craigslist and whatnot...
You don't need the kinda Vodka you'd buy to enjoy drinking, that nasty bottom shelf swill will work just fine for this.
thefiftyfootwoman says: Sep 10, 2011. 9:49 PM
I just made this with cheap vodka, lavender and grapefruit essential oils. My sheets smell incredible. Thank you!!
Ingridpin says: Jul 20, 2011. 2:14 PM
There is any substitute for the castile soap to make it? I can't easily find it where I live in... :/
fgodwin says: Jul 15, 2011. 2:46 PM
Would vanilla essence work? Because then you could still drink some :D
jessyratfink (author) in reply to fgodwinJul 15, 2011. 11:04 PM
I initially read this and worried about the color of the essence, but I think it would be since it would be diluted so much!
kieRAWR says: Jun 4, 2011. 6:47 AM
Does anyone have tips on cleaning kitchen floors? For some reason my roomate is a messy chef and believes simply swiping at a spill with a papertowel will clean it. The spot is still sticky! They purchased a Swiffer WetJet, but are taking it with them when they move out soon.
Should I just use the all-purpose cleaner? The flooring looks pretty sturdy, not linoleum (sp?)
mrsthursday in reply to kieRAWRJul 10, 2011. 12:17 PM
First off I don't like swiffers. Get yourself a mop & bucket & rubber gloves & a spray bottle of your fav. all purpose cleaner & water. If it's wood DON'T use ammonia & don't over-wet it, it just damages the wood.
1st vacuum - most of the yuck is hair - people moult just like animals- it'll be way quicker to vac or sweep if u prefer.
I go around & clean the edges & corners of the room just spray around the edges wait a few minutes for the yuck to break down then mop - that's the worst area done! .
Then do the remaining area- spraying & mopping & rinsing the mop now & then. When finished make sure u wash the mop in clean water & cleaner, rinse & stand it mop up- outside if possible or in the tub until it's dry & it'll last ages not like those germy sponge mops, don't like them either : ).
jessyratfink (author) in reply to kieRAWRJun 4, 2011. 7:50 AM
I use the all purpose cleaner on my floor all the time - both wood and vinyl - with no problems. :)
A mix of vinegar and water with a little soap can work on most floors too, and especially in kitchens where things can get greasy and nasty.
BluWriter says: Jun 19, 2011. 6:20 PM
Awesome instructable! Thanks so much for this. *-* <3 It's going to be really handy. :D
bluemoon6 says: May 29, 2011. 6:39 AM
I do this but I use an Alka-Selzer tablet and it works wonders----just make sure that the water is almost boiling that you use to flush the solution down the drain!!!!!!!!!!!!
bluemoon6 says: May 29, 2011. 6:36 AM
Amazing this is so...simple-thanks for sharing!!!!!!!!!!!!!!!1111
poori_kanna says: May 24, 2011. 6:14 AM
u can also try water + vinegar overnight in the pot ... the muck comes out cleaner and there's no smell ... :) i also spray my pots in vinegar and rinse if i'd cooked eggs/meat in them. there won't be any leftover smell :D
stretch mark says: May 7, 2011. 10:53 AM
Nice recipes! I also wanted to mention that essential oils are very strong anti viral and antibiotic. Last summer I had a staph infection and I read that tea tree or lemon grass oil kills all staph including MRSA. Using similar ingredients as yours I made a liquid that I used topically that seemed to really work well. Of course I was also on major antibiotics but my topical remedy seemed to work better than the prescribed topical ointment. Thanks!
jessyratfink (author) in reply to stretch markMay 16, 2011. 1:15 PM
Oh, neat. I didn't know that. Good to know just in case, haha. :)
stretch mark in reply to jessyratfinkMay 16, 2011. 8:26 PM
I did not mention that I diluted to an extreme ratio like 1/30 or 40. My illness was very scary and happened very fast. I was in the hospital within 24hours of my first symptom. Essential oils are just that it turns out. If you haven't already, you should check out oregano oil. Used as an antibiotic primarily before penicillin and sometimes rarely referenced in old literature.
onemoroni1 says: May 1, 2011. 9:17 PM
Very good recopies for homemade cleaners. Some unique from other sources I've seen. I have made a window cleaner for years using rubbing alcohol, ammonia (non sudsing), and water in a spray bottle. It is close to the Windex brand. The alcohol makes it dry fast.
jessyratfink (author) in reply to onemoroni1May 16, 2011. 1:17 PM
Good idea about the rubbing alcohol, maybe I'll add a little next time!
capricorn says: May 2, 2011. 3:03 AM
Informative and useful, thanks for sharing.
For what comes to cleaning the drain, it is the same method I use myself, but I tend to fill the soda and then pour the vinegar and the boiling water at the same time.
In fact I create a super heated bubbling foam that falls down the pipes. The pressure it creates is enough to unclog the plumbings and push the grim out, ready to fall in again.
I will try with your 15/20 minutes resting time next time :)
jessyratfink (author) in reply to capricornMay 16, 2011. 1:17 PM
I'm always worried about using boiling water because I always seem to live in places with plastic piping under the sink. I can just see it ending badly. :P
vcramer says: May 3, 2011. 3:41 AM
Great ideas!
jessyratfink (author) in reply to vcramerMay 16, 2011. 1:15 PM
Thanks! :)
iowa_girl says: May 7, 2011. 7:40 PM
These look great and I can't wait to try them. I wonder what you might suggest as a green cleaner and whitener for a porcelain kitchen sink? Or for getting hard water stains off the rim of the inside of a toilet. Any suggestions.
Thanks so much. Great job.
jessyratfink (author) in reply to iowa_girlMay 16, 2011. 1:14 PM
Lemons should work on both of those - but it kinda depends how discolored the surfaces are.
You can just cut a lemon in half and rub them on the spots, or spray lemon juice on them. For the toilet, a lemon half dipped in baking soda should help. You can also do half and half borax and lemon juice and let it sit a bit before scrubbing.
If nothing else works, I'd try the pumice stone that rpatzman recommended. :P
I also did a little googling and there were a lot of people recommending making a paste out of hydrogen peroxide and baking soda, but I've not tried that one.
rpatzman in reply to iowa_girlMay 15, 2011. 3:47 PM
Get a pumice stone for the toilet rust stains. A little elbow grease along with it and you have a sparkling toilet again. Pumice stones are a bit pricey at the hardware store, You can get the kind for calluses at your local drug store for a couple of bucks. Should be just as good for a porcelain sink, though I wouldn't recommend using the same one LOL.
MsJaxFla says: May 2, 2011. 3:39 PM
Hey Jesse! I use most of these and they are GREAT. I don't add the essential oils though, mainly because I don't have access to them without going out of my area. I wanted to ask you if you had tried this one yet or if any of your followers had tried it YET? I have not, because I keep forgetting to get the lemons and/or oranges to use in it. And now my car battery died and have to get a new battery.
2 liter plastic bottle
100 grams of brown sugar
1 liter of water
300 grams (total) of lemon and orange scraps
Sharpie because you have to put a date on it and let it ferment for 3 months.
And I worry about it exploding as well, you need to loosen the lid ever so often, so not real sure about trying it yet. lol
Sheryll & Critters.
jessyratfink (author) in reply to MsJaxFlaMay 16, 2011. 1:03 PM
Oh, wow, that sounds intense! I have not tried anything like that yet. I did do some googling, though, and they seem pretty popular. I saw a couple sites selling them for a ton of money - so they must work pretty well!
I think I'd like to give this a go. Next time I get a bottle big enough to make it in, I think I'll try. :)
1-40 of 55Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
