Homemade Green Cleaning Recipes by jessyratfink
Contest WinnerFeatured
Step 3: Ghetto Febreze
This is a very easy Febreze alternative - I've seen a ton of recipes using fabric softener... but those aren't very "green".
What you'll need:
  • a small spray bottle
  • 1/2 cup rubbing alcohol or vodka
  • essential oil
  • 1 cup water
Fill the spray bottle with 1 cup water and 1/2 cup rubbing alcohol or vodka.
You'll now add the essential oils - I typically start with 30 drops and then work my way up. You can also mix oils to create custom scents. I also like using The Body Shop home fragrance oils in this mix and I've had no problems with them.
Note that you will be able to smell the alcohol, but only for a minute or so... after that things will just smell lovely. Rubbing alcohol has a stronger smell than vodka! :)
I use this on my couch, bed, curtains, dog bed, towels, etc. and the smell lingers for quite a while - for example, I sprayed my couch while cleaning yesterday and it still smells nice.
bluidego says: Nov 5, 2011. 7:13 PM
oh also I use RAIN vodka for this it is the best
bluidego says: Nov 5, 2011. 7:11 PM
I have been doing this with vodka for years. Although I didn't ever see it as ghetto. Essential oils are pricey and way better than anything febreeze puts out!
mcorriveau says: Nov 2, 2011. 12:55 PM
I would be careful with some essential oils. Peppermint, in particular can be harmful to cats so it's a poor choice to deodorize your couch if you have one that likes to lay on it.
vortexmax says: Jul 21, 2011. 9:19 AM
Better look up the toxicity factor on IPA (Rubbing Alcohol) Is is flammable and toxic,handle with care keep out long reach of children.Vodka to expensive to waste on cleaning.Use it to clean your throat but not to much.Other then this good stuff.
fidgetofdoom says: Sep 22, 2011. 8:20 PM
actually... Vodka is WAY cheaper then some alternatives... This isn't just a smell good spray, its a deodorizer... and Vodka is brilliant for that oddly enough. I use it to remove sweat stink in shoes, and cat piss smells... great for spraying down furniture that you've gotten of craigslist and whatnot...
You don't need the kinda Vodka you'd buy to enjoy drinking, that nasty bottom shelf swill will work just fine for this.
thefiftyfootwoman says: Sep 10, 2011. 9:49 PM
I just made this with cheap vodka, lavender and grapefruit essential oils. My sheets smell incredible. Thank you!!
fgodwin says: Jul 15, 2011. 2:46 PM
Would vanilla essence work? Because then you could still drink some :D
jessyratfink (author) says: Jul 15, 2011. 11:04 PM
I initially read this and worried about the color of the essence, but I think it would be since it would be diluted so much!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
