Homemade Green Cleaning Recipes by jessyratfink
Contest WinnerFeatured
Step 7: Extra Cleaning for Pots and Pans
If you've burned food to a pan, or if you've made yourself a nice hardened, stuck-on food mess along with your dinner, there's an easy way to get it out. :)
Add about 1/4 cup baking soda to a couple of cups of water in your pan and bring to a boil on the stove for 5-10 minutes. While this is going, it helps to scrape the bottom of the pan with a wooden spoon.
After you take it off the heat, give it a good scrub. You should have a nice clean pan! If not, rinse and repeat with a little more baking soda. This will also help remove stains for things like tomato sauces.
poori_kanna says: May 24, 2011. 6:14 AM
u can also try water + vinegar overnight in the pot ... the muck comes out cleaner and there's no smell ... :) i also spray my pots in vinegar and rinse if i'd cooked eggs/meat in them. there won't be any leftover smell :D
onemoroni1 says: May 1, 2011. 9:17 PM
Very good recopies for homemade cleaners. Some unique from other sources I've seen. I have made a window cleaner for years using rubbing alcohol, ammonia (non sudsing), and water in a spray bottle. It is close to the Windex brand. The alcohol makes it dry fast.
jessyratfink (author) says: May 16, 2011. 1:17 PM
Good idea about the rubbing alcohol, maybe I'll add a little next time!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
